Question about Canon PowerShot G2 Digital Camera
Canon G2 flash causes weird orangey-brown shadows around people
When I don't use the flash outside, all is fine. Inside, especially where light is not great, using the flash causes pictures where the color balance is really off. The overall photos are yellowish and there are orangey-brown halos around people What could be causing this?
    President:
  • 423 Answers
Sounds like your shutter speed is set too low. If you are in manual exposure control, check that your shutter speed is at least 1/60th or higher. If the camera is in automatic, check to see that you ARE NOT in the "slow-sync" flash mode.
Posted on Feb 22, 2009
Canon G2 digital connector is loose inside the camera. Cannot connect.
You have to go like a surgeon, get the loose part and resolder it back on the board. Sounds easy but it is not - working on those cameras is a bear because they are so small and have so many screws and ............G2 is a great camera - I have 2 of them / go for it. Good luck.
Sep 16, 2017 | Canon PowerShot G2 Digital Camera
When pictures are taken outside during the day they are unclear with some white horizontal lines and when taken indoors its ok.tried everything the manual said but still no changes
White shadow or white lines may occur if the light was too bright when you take the picture, especially in strong sun light. Have you turn off the flash light when you taking those picture ? If you haven't, then you should try to turn off your camera flash light manually. And I must remind you not to take a picture with your lens faced the sun light or other light (lamp etc) directly. Even if you take a picture outdoors, try to make your lens shaded by something, you can even use your own shadow to shade them.
Hope this help and be kind to rate please.
(^_^)
Jan 08, 2011 | Cameras
Harsh shadows
to avoid harsh shadows moveaway from the bright light,or move object/people close to the backdrop that will reduce the strong shadows.
Apr 10, 2010 | Canon EOS Rebel XSi Digital Camera
Canon 40D
Hey D1ppy,
There are two ways to get rid of shadows behind a subject, but both require you to use a hotshoe mounted flash. The first way is to bounce the light off a ceiling or some other white surface by turning the flash head towards that surface instead of your subject. The second way would be to connect the flash to the camera using a off camera flash cord and hold the flash above your head when your taking the picture, and by doing this you are able to aim where the shadows show up in the image. Bounced flash is what is called soft light and generally is more pleasing light. I of course am assuming the shadows are caused by the built in flash on the camera. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
May 30, 2008 | Canon EOS 40D Digital Camera
Oven not cooking evenly, outside is getting brown but inside is undercooked
Sounds like the igniter is not operating at full capacity. What happens is that the oven does not light when it should. Instead, the oven is cooling down much too far so when the oven does light it has too heat more rapidly. This causes the outside to brown/burn long before it should.
Jan 24, 2008 | Whirlpool SB160PEE Gas Single Oven
Shadow across photo
Shadows, especially circular shadows, are pretty common with the pop-up flash. What you are seeing is actually the shadow cast by the end of the lens. This happens especially on wider angle shots.
The solution is to find a way to get the lens out of the way of the flash. You can get an external flash, like a 430ex or 580ex, which elevates the flash far above the lens. That is an expensive option so first you might try making a diffuser for your pop up flash, which softens the source of light and helps eliminate some shadows:
http://www.diyphotography.net/diy-built-in-pop-up-flash-diffuser
http://www.flickr.com/photos/natuurplaat/10362363/
Dec 25, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Battery Charging light doesn't flash and battery doesn't charge
I have the same problem. Worked for 3 years and now the battery charges to green but goes dead immediately. I've changed batteries. Its the camera not the batteries. Works fine plugged in. Obviously the cameras are not charging the batteries. Canon must know but I cannot find a fix and warranty is over. I guess buying the expensive camera of the day isnt always assuring you of quality.
Dec 25, 2007 | Canon PowerShot G2 Digital Camera
Dark shadow on right side of picture
sounds like a shutter leaf dropping into the image. however, they are usually horizontal and more likely to manifest when in landscape mode. (horizontal, normal)
try using flash pointed up to ceiling.
also, could need to check for auto sync speed setting. usually 1/125 to 1/60. if its off, it could be catching the shutter in the wrong place.
check manual for settings for using flash.
mark
Dec 09, 2007 | Canon EOS 400D / Rebel XTi Digital Camera
Green shadows surrounding bright whites
finally a consumer that gives us plenty of info :)
sounds like an overdriven green tube, the only thing you can try is to find the G2/Focus block assembly, either behind front speaker grill or remove back of set and look for a black box approximately 5"X5" , this box will have 6 philips type adjustment screws(plastic) 3 are for focus, do NOT adjust these,
the other 3 are marked "screen" the center screen adjustment screw is for green, turn it VERY slowly counterclockwise while the set is running and pray that your problem dis-appears, be advised that this is a HIGH VOLTAGE device so one hand in your back pocket the other hand turns the screwdriver, if the problem does not go away you have a poor green tube, good luck, sorry I can`t give you the exact location of the G2/Focus block, manufacturers move them to different places every year.
Nov 29, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Canon SpeedLite 220EX
The two types of Camera refer to the SLR's. I doubt the G2 will support FP flash as it probobly does not have a focal plane shutter like a SLR.
Oct 07, 2007 | Canon Speedlite 220EX TTL Flash
Canon PowerShot G2 Digital Camera Logo
56 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
