Question about Maytag PAV2300 Top Load Washer
Tub will not spin - Maytag PAV2300 Top Load Washer
  • 1 more comment
  • annicka1361 Feb 22, 2009
    No blockage, the water is draining completey. Should the agitator be agitating during the spin cycle?
  • protec50 Feb 24, 2009
    motor turns and lid switch good and belt not slipping and pulleys are turning.The tub will not turn in a spin cycle but the motor ,belt and pulleys turn,what is my problem,help.
  • carlstaz Feb 27, 2009
    like a brake comes on
  • Maytag Master
  • 3,361 Answers
Make sure the lid switch is good.
No blockage in the pump.
Belt is not worn.
Posted on Feb 22, 2009
  • steve
    steve Feb 22, 2009
    Agitating during spin requires you to change the main pulley and cam riser on the bottom of the washer.
    The large pulley the belt goes around.
    These parts come as akit with instructions.
LG Model WP-9241 Washing Machine - Wash tub spins in only one direction
wash tub spins in only one direction it cannot spin in other direction
Dec 21, 2014 | LG Washing Machines
Why does the inner tub for the LG washing machine tub not spin when the tub is full?
not sure I understand you, but ur drum should or does not spin when full as it is set that way, first the drum drains most of the water then it goes into spin?
Jul 29, 2014 | LG Washing Machines
Mah 6500 spins but leaves som water in tub. if you
they have a balance ring on the front of the tub and it's full of water
Jul 03, 2009 | Maytag Neptune MAH5500B Front Load Washer
Kenmore Tumble Action Washer won't go to spin cycle
im a repairman,lets reason this out.if washer wont spin because the tub is so warped that when it spins its so out of balance then ok new tub.or the tub welds are broken and some part is dragging and not letting it spin then ok new tub.or spin bearing has failed and ruined tub support shaft,ok new tub.but why else would you need a new tub for a no spin problem,not sure,and to answer your other question , can you fix the tub if any of the above problem you would have to replace tub.i hope that helps,God bless , if i have been helpful please remember to help me with my ratings,tom
Jan 06, 2009 | Kenmore 43142 Front Load Washer
Tub bangs and seems to be spinning out of round
One of the support arms on the back of the spin basket (stainless steel tub) is broken and causing it to spin in the fashion you describe. The only fix is to replace the spin basket. Using it in its current condition will cause serious damge to the outer tub shell. Let me know if you decide to replace it or need assistance locating a replacement tub. I can assist you in how to disassemble the washer and how to reinstall a new tub. Sorry...I wish this was better news.
Oct 03, 2008 | Kenmore Elite 45986 Front Load Washer
If you have removed the drive belt from the rear pulley and the inner spin basket does not spin freely, you either have a drum bearing seized up on you, or something binding between the spin basket (stainless steel tub) and the outer tub shell. First, you need to reach inside the wash tub with the washer empty. Place the palm of your hand at the 12 o'clock position and push straight up. There shouldn't be any play in the spin basket. If you can feel the basket wobble up and down, you have either a bearing problem, or a spin basket support (spider arm) broken on the back of the spin basket. If there is no play at all, you probably have something caught. Small articles of clothing can sometimes get pulled between the tubs and usually ends up around the support shaft in the rear. This will obstruct the basket from spinning freely and could eventually cause damage to the drive motor, spin basket and/or tub bearings. You can use the instructions for replacing a rear tub bearing that I have posted under my Tip and Tricks for instructions on how to disassemble and inspect the tub. The bearing may not be bad, but you still need to check to see if anything is binding the spin basket against the tub shell and inspect the spin basket supports. Unfortunately, you have to disassemble the washer to be able to inspect any of these items I mention. I hope this helps you.
Jul 25, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Amana Washmachine (not all water removed during spin) ALW780QAW
you may have blockage in the drain pipe several feet from washer. if you can run spin cycle with hose in different location ex. tub,sink or outdoors. if this works run long snake down washer drain pipe to clean gypsum residual.
Jan 28, 2008 | Amana ALW780QA
Maytag PAV2300 Top Load Washer Logo
46 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
