Question about Sony KP-51WS500 51" Rear Projection Television
Can someone tell me what the potentionmeters look like?
  • 10,594 Answers
Please see image of potentiometer HERE
Posted on Feb 22, 2009
  • Shahid Electronics
    Shahid Electronics Feb 22, 2009
    Generally it is called variable resistor.
Dfg100 oven will light , get to temp, shuts off but wont light by itself again
to confirm check the Ohm draw on the temperature probe, i am not sure what is the correct one but you can check online at blodgett if probe okie then you will have an issue with the temp controller there possible the potentionmeter is worn out.....good luck
Apr 16, 2014 | Blodgett DFG-100 Gas Single Oven
My healthrider s300i softstrider treadmill doesn't incline anymore do you know what i can do to fix this?
1)See if flexible cable from display board is bending to lower board.
2)main motor board is faulty by worn deck belt.
3) burn motor faulty.
4) adjust the Potentionmeter from the motor (incline).
5)Defective gear in inclination motor.
Aug 31, 2011 | HEALTHRIDER S300i Treadmill Motor Control...
My pitch control goes slow when u push it up to - but goes even slower when u push it down to + is it nackered please help thank you Emmalene
You can try to recalibrate it by using the potentionmeter or 'pots' as they are sometimes called. There are two of them. One is on the main circuit board and one is on the pitch control. Either way you will have to take it apart to get to them.
Important*** When you have the platter off, do not hit the start/stop button!! This will ruin your motor.***
The easiest thing to do is order a new pitch control. They are relatively inexpensive and they are easy to replace.
Mar 24, 2011 | Technics SL-1200MK2 Turntable
Hi, i've got an astatic mobile max echo chamber but the echo and echo volume controls are very faulty. The echo volume is just a normal potentionmeter but the echo control is more like a balance control....
just replace with same ohms.....replace example--- 100k with 100k 5k with 5k etc......any old C.B. ....stereo...dont matter...what matters is the ohms
Jan 25, 2010 | Radio Communications
Yamaha RX-V800 volume control
i would say that the component that controls the sound level (called a potentionmeter) or (varible resistor) is either broken or will need to remove the cover and inspect the area around the volume control just to make sure it is not broken or that any wiring has just become dry jointed....if all is good then what i would suggest to do is to find out the value of the pot...normally there around 10-50K then youll need to get a replacement...if this still dosen't fix it or your confident enough to look or fix it yourself i would take it to a local electronics repair shop....remeber to disconnect unit from power before removing cover hope this helps,ben
Jan 09, 2010 | Audio Players & Recorders
I have Audi A3 1.6 2001 model with automatic gearbox and it just doesnt want to change gears, from 2nd to 3rd it changes only at 70km/h and it doesn't change from 3rd to 4th at all. Any advise?
well i had thesame problem with my 1995 m A6. its the potentionmeter switch which sits on top of the engine and connects to the throttle assembly. if its not working then the gearbox wont change gears until very very late, easy to come off ..only 2 screws.
Nov 14, 2009 | 2005 Audi A3
Sony KP-51WS500 51" Rear Projection Television Logo
29 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
