Question about HP Pavilion dv1000 Notebook
Built in michrophone setup
How do i turn on the built in microphone in order to use it with webcam?
    Problem Solver:
  • 8 Answers
1)Double click on the speaker icon in the system tray to bring up windows volume control.
2)Go to options, then properties.
3)Select Microphone from the "Show the following controls at the bottom" then click OK
4)From Volume Control window untick "mute" for the microphone
Your microphone should now be on.
Posted on Feb 22, 2009
Does an acer aspire one have a built in microphone
If it has a built in webcam, then it has a built in microphone (usually a hole next to webcam). Otherwise, use a cheap headset.
Dec 25, 2014 | Acer Aspire One PC Notebook
Where is the michrophone on del inspiron 6400?
Unfortunately the Dell Inspiron 6400 is not equipped with a built in microphone.
You can use an external microphone having a 3.5mm jack by connecting it to the microphone connector found on the right side of the laptop.
Hope to have helped you.
May 16, 2011 | Dell Inspiron 6400 Notebook
I can hear people on msn but people can not hear me
The Dell Inspiron 1501 has a set of internal speakers but doesn't have a built-in microphone. You need to plug an external microphone into the microphone jack on the right side of the notebook as shown below. You can open Messenger and click on the Tools tab then select Audio and video setup. (note as there is no built-in webcam, it will just be an audio setup). You may decide later to add a USB webcam with a built-in microphone in which case the plug-in external microphone will no longer be required.
Mar 26, 2011 | Dell Inspiron 1501 Notebook
I have a acer with the acer crystal eye webcam built in it. do it have a microphone with it. if so how do I get it to work?
The Acer with crystal eye webcam will also have a built-in microphone. The webcam is in the center at the top of the screen. The built-in microphone is typically half-way between the edge of the screen and the webcam. It is a little opening with a microphone logo beside it. You can test both audio input with the built-in microphone and the audio output with the built-in speakers by doing the following....
1. click start > Control Panel > Sounds and Audio Devices
2. in the Sounds and Audio Devices Properties click the Voice tab, then click the Test hardware button
3. in the Sound Hardware Test Wizard window click the Next button, if required, click unblock...
4. speak into microphone to do the Microphone Test. Recording meter will show movement if it works.
5. click Next button to do the Speaker Test. Microphone input is now output on the speakers.
6. click Next button when finished doing the readings and click Finish to close the wizard.
Mar 20, 2011 | Computers & Internet
Do toshiba satellites c655 have a built in mic?
The Toshiba Satellite C655 does not have a built in microphone, but it does have a mono microphone jack.
The following website has microphones that are compatible with the microphone jack. http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100007675%20600011221&IsNodeId=1&name=3.5mm
You may verify at Toshiba's C655 website. It says "No Webcam and microphone built into LCD bezel". http://us.toshiba.com/computers/laptops/satellite/C650/C655-S5049
Compared with the L670. It says "Webcam and microphone built into LCD bezel". http://us.toshiba.com/computers/laptops/satellite-pro/L670/L670-EZ1710
I hope this answers your question.
Sincerely, Nathan Hicks
Mar 01, 2011 | Toshiba (P000257700) Microphone
Does my toshiba l300 have an inbuilt microphone because it has failed to work with my skype calls?
The L300-ST2501 and the L300-ST3502 are built with Webcams and there IS a microphone built into those webcams.
The L300D-ST3501 and the L300D-ST3503 are NOT built with webcams or microphones.
Hope this helps!
Dec 16, 2010 | Toshiba Satellite Pro L300 Notebook
I have a toshiba l305-S5957 and can't find an internal mic for use with skype
While most laptops comes with a built in webcam and microphone, this particular model does not. If you don't see a web cam built in to the top of your screen, chances are you also won't find an internal microphone. You'll need to purchase additional accessories in order to use your laptop with Skype.
Mar 08, 2010 | Toshiba (P000257700) Microphone
Webcam when connected they can see me but cant hear me
When you bought it, did you check to make sure it has a microphone built in? Also, do you have the microphone volume turned up loud enough?
If your webcam has not got a built-in microphone then you need to purchase a separate microphone or you could go back to the shop and swap it for one that has one :)
Jul 20, 2009 | Microsoft Life Cam Vx-5000 Webcam
Feb 22, 2009 | Dell Inspiron 1420 Notebook
HP Pavilion dv1000 Notebook Logo
123 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
