Question about Kenmore 79012 / 79014 / 79019 Gas Kitchen Range
When everything is set to come on,the oven will not come on.
When you turn the oven on an set the temp,the oven go's to preheat. The oven will not engage or in other words will not come on. Help me please.
  • Anonymous Mar 12, 2009
    When I set oven or broil on.Sometimes it will come on and sometimes will not.
My oven don't stat
Posted on Mar 31, 2009
  • Kenmore Master
  • 3,361 Answers
Make sure the glow bar ignitor is working in the oven.
They can glow and still be bad because of poor resistance.
Posted on Feb 22, 2009
How do I preheat this toaster oven
Set your temp. Turn oven on. Wait. That's how you pre-heat a toaster oven. There aren't any that I have seen with a specific "preheat" setting.
Dec 31, 2015 | Toaster Ovens
Ran the self cleaning cycle and now the preheat light will not turn off when it gets to the temperature I set it to. It just keeps preheating. Example: I set the oven for 375. It seemed like it had been...
Sounds like a circuit board issue. If in Warranty, contact the manufacturer and have the controller replaced. A routine cleaning has noting to do with the normal operation of the baking or broiling function. Cleaning is disengaged after the door is unlocked and ready for general aplications.
Feb 20, 2014 | Ovens
Oven takes forever to preheat
The way the oven works is like so:
1) User sets the desired temperature
2) Power is sent to the ignitor
3) The ignitor is then energized, drawing 3.2 amps of current
4) When the 3.2 amps is drawn, the gas safety valve is allowed to open and gas flows into the burner assembly in the oven.
5) This gas is then ignited, causing the oven to heat.
6) As the oven heats up, the oven sensor, which is the metal rod located at the top on the rear oven wall, converts the heat into an electrical signal, relaying this information to the main control which in turns displaying the temperature.
(In models with a dial thermostat, there won't be a sensor, though a metal wire with a bulbous end will be present, which is actually connected to the thermostat.)
Jun 21, 2012 | GE Kitchen Ranges
Oven preheats but will not maintain heat
Hi you have a bad thermostat for the oven , I would guess that everything else is working ok on this unit correct ? if you send information i will look up the part for you this is easy to replace , as always turn the power off before service or unplug
Nov 25, 2011 | Maytag Ovens
The oven pre heats to desired temp and then loses
SOUNDS LIKE THE TERMOSTAT IS FAULTY REPLACE IT AND YOUR OVEN SHOULD WORK FINE.
Nov 09, 2009 | Thermador SMW272 Electric Double Oven
Oven does not reach set temp
What are using to measure temp ? Are you using a grocery store bi-metal or professional thermal probe ? and further to that, how long are you waiting to check temp. after range "beeps" or announces preheat complete ? The bi-metal type thermometers do take several minutes longer to reach actual temp as opposed to the ranges temp. probe. Does this unit have the "hidden" bake element ? That sounds like a huge temp difference. These units do require an additional 10mins of wait time after announcing ("BEEP") the preheat is complete (check your manual, it should confirm this) Elements don't go "bad" it either comes on (amp draw) or it doesn't.
hope this helps.
good luck
Sep 26, 2009 | Frigidaire Ovens
Amana oven doesn't heat
IS it gas or electric? If it's gas, you may need to have a technician regulate the air and gas. If it's electric your t-stat may need to be replaced. Hope this helps! :>)!
Aug 14, 2009 | Ovens
Preheat takes forever
http://www.applianceaid.com/nuker.html
click the link  Oven temp sensors sense the temperature is the oven cavity and the temp sensor changes resistance, this change in ohm resistance tells the oven control what temperature the oven cavity at and tells the control to shut off the element or turn it back on. The most common temp sensors used today ( *not all ) are approx 1000-1100 ohm resistance at room temperature ( 70�F )
Some ohm readings and there temperature:
Degrees F    -   Resistance
            100 - 1143 ohms
             200 - 1350 ohms
             300 - 1553 ohms
             350 - 1654 ohms
             400 - 1753 ohms
            500 - 1949 ohms
click this link
http://www.applianceaid.com/elecrange.html
Mar 01, 2009 | GE Ovens
Temperature control
sounds like a bad bake ignitor(uneven heat,long cook times, long preheat times, perhaps even gas smell while cooking)
Sep 29, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Kenmore 79012 / 79014 / 79019 Gas Kitchen Range Logo
147 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
