Question about Microsoft XBox Controller S ( Brand) X-Box (XBOXNAC006)
MY X BOX CONTROLLER (WIRED ) IS COMPLETELY DEAD. ANY SUGGESTIONS.
  • pterrell17 May 11, 2010
    does it still work on your xbox?
  • 4 Answers
If you can see visible damage to the wires, try using a wire cutter (the ones with the special insulation stripper-thingy) and remove the insulation. if any of the wires are broken, solder them back together (WARNING: Make sure the wires you are soldering together are the right ones, or else you can screw it all up). Then wrap the individual wires you soldered in electrical tape, and then wrap all the wires in electrical tape. If there is no outward damage you might need to unscrew it and look inside for any missing components. If you can't find any, you could consider replacing the cord or the controller.
Posted on Jul 30, 2009
  • 4 Answers
Aha! You will need a new xbox controller. I had the same problem once. It's because the wire is broken inside the rubber. My solution depends on if it's new or old. If it is new then report it to the shop you bought it from. If it is old you will have to buy a new one! I had this problem with the PS2 controller. From Jake @ Dudey-Dreamz.piczo.com
Posted on Feb 23, 2009
Jennair 48" refrigerator completely dead, absolutly no power, no life. Had it repaired, replaced controller board once a year ago cost me $600 but now suddenly just shutoff. Any suggestions
probably the same fault again
call a technician to properly diagnose the fault and a quote and if it is the same fault , consider replacing the unit with a more reliable machine
a money saver here is to run the unit through a surge protection unit as program boards are subject to failure from any power surges
Aug 17, 2016 | Refrigerators
Dishwasher starts cycle then shuts off
That's a tough one. Really need more info, like how long does it runs before it stops? And are any lights on steady or flashing when it stops? Or does it go completely dead? You could have a loose wire in the junction box; a bad door latch or switch, a bad controller, or other possible causes.
Sep 03, 2014 | Kenmore Dishwashers
Ps3 will not recognize wired or wireless controller
does the screen come up at all??? if not it maybe a board issue or even GPU, PSU fault
Dec 29, 2013 | Video Game Consoles & Games
Ps3 unknown usb device
yes! because maybe your os3 controller batteries are dead get a new one
Oct 24, 2013 | Video Game Consoles & Games
I need help with a ps3 polaroid wired controller it wont connect
How do you connect it, wired or wireless? Check these settings out.
Make sure the Power Save Settings are turned off: XMB > Settings > Power Save Settings > Controller Auto-Off > Off
If the Power Save Settings were on, then that was your problem. The controller only charges for 5 minutes and then turns off. That is not long enough for the controller to charge. Turning the Power Save Setting off will allow the controller to charge correctly.
If the Power Save Setting is not on, then do a Reset (http://faqsmedia.ign.com/faqs/image/arti... ) on the controller, then connect with the USB cable and press the PS button. If this doesn't work, then I would say the controller is going dead, and you are in need of a new one (make sure to actually press the Reset button, sometimes it can be missed if you are using something too small, like a needle).
Aug 21, 2011 | Video Game Consoles & Games
How to use xbox controller on pc games
You must have the wired version of the controller. This does not mean the play and charge kit, if the wired version's cable can be removed then it is the wireless controller. Once you plug it in, it should find the drivers automatically and install them. Using it in game is something you will have to see if your game supports and can be usually set-up in the game menus.
Apr 03, 2011 | Electronic Arts LEFT 4 DEAD for PC (9855)
Spilt drink on ps3 controller. now it is completely dead
use another controller, you will have to take this one apart, and dry it completely.
Jan 03, 2011 | Video Game Consoles & Games
My controller isnt working for pc
First you need to download this driverupdate us software (for free) and scan your PC. after scanning, driver will be found and you will be able to update in couple of seconds. best of luck
Jul 17, 2010 | Computers & Internet
My ps3 controller wont turn on
the battery might be dead if its wired its probably a loose cord in the wire
Aug 22, 2009 | Sony Playstation 3 (PS3) Console
Controller stopped working completely
Did you charge it ????
Will it charge when plugged in ??? (Blinking red light on controller??)
Jul 27, 2009 | Sony Playstation 3 (PS3) Console
Microsoft XBox Controller S ( Brand) X-Box (XBOXNAC006) Logo
137 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
