Question about Dryers
TROUBLE SHOOTING 4 DRYER MODLE # 2704689 - Dryers
  • Anonymous May 07, 2009
    when i push the start button on the dry all it does is buzz
  • 547 Answers
Http://www.partstap.com/ please use this site and thank you for useing fixya please rate me
Posted on Feb 22, 2009
MDE5500AYW Maytag Neptune not heating. Heating Element, both high limit thermostats and thermal fuse have been replaced. What could be the problem?
Firstly, you have not mentioned that you have verified the presence of a power source of 240 volts, so make certain of that issue. If you have proper voltage, then the motor centrifugal switch could be at fault
Below is a link for trouble shooting your model.
http://www.repairclinic.com/RepairHelp/How-To-Fix-A-Dryer/8-4-563862-/Maytag-Dryer-not-heating-MDE5500AYW?r=%2fShop-For-Parts%2fa8b4d563862%2fModel-MDE5500AYW-Maytag-Dryer-Parts
Sep 28, 2016 | Maytag Dryers
Tip
Trouble shooting
for trouble shooting an air conditioner or heater its always important to ask your self one question before getting your hands in their-What is it doing and what is it not doing.This is the fundamental question to ask yourself no matter what machine your working on(washer dryer,dishwasher,microwave etc).If your unit is blowing air but not cooling 90% of the time your problem is in the condensor section of the unit.
on Sep 22, 2011 | Amana Heating & Cooling
Aeq6000es2 fridgidaire dryer
May be a bad safety thermostat. Or, the thermostat may be working as it is supposed to, but you have excess heat in the dryer drum. Check for lint buildup.
Dec 13, 2013 | Dryers
Fix error code amana dryer
The best method is to do your home work and find error code list and service manuals inside dryer or Google it online with your model number find error codes as most are online and you must do total trouble shooting procedure and replace defective parts if necessary and after you plug the dryer it should reset it self
If dryer did not reset in other hand if error code persist you still have problem and problem could be main board issue
Best way is visual check and check for any faulty component and parts and check all thermostats and sensors and look for clogged vent or any damaged or rusty or cracked components and use step by step deduction method for trouble shooting
Dec 08, 2013 | Amana Dryers
Strange odor coming from dryer during operation
It could be clogged vent or as I always say The best method is to do your home work and you must do total trouble shooting procedure and replace defective parts if necessary and could be dead rodents inside vent
Best way is visual check and check for any faulty component and parts and check all thermostats and sensors and look for clogged vent or out side vent or any damaged or rusty or cracked components and use step by step deduction method for trouble shooting
Dec 07, 2013 | Kenmore 400 6943 Dryer
Kenmore washer Model 110.5072010, lid light keeps blinking and will not start.
Sorry! Your Worng ! There is 4 wires on the lid switch for
Modle # 110.5072010 The wires are in the right corner as you remove the control cover (puddy knife works to remove this) there they are all 4 wires Blue , Yellow, Green and White. .. makes 4 wires 1,2,3,4 like that.
Now how do you BY-BASS that one?
I would like to know this answer because the lid switches are a bunch of junk and cause me lots of down time and repair/trouble shooting time I don't have for a washing machine that is only 1-2 years old.
Sep 22, 2013 | Kenmore Washing Machines
61"RCA Scenium modle number d61w136d When turning
You are on the right track, if the lamp is not lighting bright enough it could do this exact thing, the three tries is standard on RCA products, called the 3 strikes and your out---set will try 3 times to make it on and then shut down.
The color wheel while possible usually makes a high pitched fan like sound and with lamp out you should be able to see it to know if missing parts of the wheel or shattered.
12_18_2012_8_04_57_pm.jpgtypical color wheel.
Dec 18, 2012 | Televison & Video
My maytag dryer runs but no heat is coming out. What trouble trouble shooting problems can it be?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 19, 2010 | Dryers
I have an upright washer dryer unit from whirlpool which is about 4 years old. The model number is YLTE623DQ3. The dryer is not heating up. I performed all of the trouble shooting as per instructions. ...
hi thanks for the question the heater is part # 3387750 and no its not hard to change the bottom panel comes off and the heater is on the right did you check to see if you had 240 volts coming in thanks the appliance doc
Sep 24, 2008 | Whirlpool Dryers
Dryer shows f44 error
007, F44 is a motor control electronic failure. Couple of things you can try. 1. Unplug the dryer for 1 minute. Plug it back in and see if the error stops. 2. Under the consol there is a 3 wire harness that runs between the two control boards. Try reseating this harness. If that doesn't work, you will either have to call for service or do some detailed trouble shooting. Catriver, post back.
Aug 17, 2007 | Kenmore 67082 Electric Dryer
Dryers Logo
56 people viewed this question
Top Dryers Experts
