Question about GE Profile Spectra JGBP90 Gas Kitchen Range
GE Spectra XL44-Oven doesn't keep the correct temperature. If I use an oven thermometer to get the correct temperature, the temperature doesn't stabilize to a constant value. Everything else works fine. Is this an easy problem to fix? About ho much should it cost to have repaired?
  • kevinbe53 Feb 23, 2009
    The thermostat protrudes from the back wall about 8 inches. It doesn't look flexible. It looks like it is where it is supposed to be. The oven ignites just fine but the temperature is about 50 degrees off.
  • GE Master
  • 3,361 Answers
Check to see if the thermostat sensor is hanging down in the oven and not in its' holder..
Make sure the ignitor is cycling and bringing the burner on.
Posted on Feb 22, 2009
  • steve
    steve Feb 23, 2009
    It should be mounted to the back wall or the side wall up high.
Xl44 spectra oven temp very low
Fixya does not sell parts and cannot recommend sources.
Jul 18, 2017 | GE Spectra JGBP35 Gas Kitchen Range
Describe your GE Profile Spectra XL44 Oven
My GE Profile Convection Microwave Oven will beep and display a F2 for no apparent reason. What is this?
Mar 09, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven does not get to temp when it says its preheated
More than likely, its your oven thermometer thats taking a half hour to read correctly. The oven is probably getting there sooner. If you had a digital thermometer, the read would come quicker. So save your money,nothing wrong with your stove.
Feb 10, 2010 | GE Ovens
I have a ge profile xl44 oven and do have the
I just converted aXL 44 from natural gas to propane and I don't have a manual for it do I need to do anything for the oven part?
Also how do I light the pilot light or do I need to?
Greg
Jun 28, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE XL44 gas range, oven dial doesn't have "lite"?
Set the oven for the desired temperature. It will cycle on and off at that temperature.
It will lite automatically.
Feb 27, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven temp control not working
you need to calibrate the oven.
go to this web site
http://genet.geappliances.com/geasearch/Dispatcher?REQUEST=GETSEARCHRESULT
the second in the list is your solution
Dec 02, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven
Same here, my wife freaked cause Christmas turkey took 6hrs.
I read somewhere that its internal thermostat. GE should offer to look into this seemingly wide spread problem
Dec 26, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Oven does not maintain temperature. Part 2
sometimes when they get hot that is when they fail
Sep 18, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge spectra xl44
check your Measure oven temperature sensor circuit at oven temperature sensor (should be approx 1100 ohms at room temp); check for cut or pinched wire or loss of contact and /or Replace Electronic Range Control (ERC)
Dec 18, 2006 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
886 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
