Question about Tomtom ONE GPS Receiver
Tom Tom One Doesn't Turn on
I have used it only once since I bought it new and it was working fine. But now it wouldn't turn on. I have tried to connect it to the mains charger,car charger and even my pc but its green light comes up and it doesn't turn on. The charger is of UK specification and I live in England. Can some one tell me what's the problem with it? and how to fix it? Does not turn on but green light is on. this happened after I bought a cheap charger from ebay and it just turned off after 10 minutes, coincidence???
  • curlydeb Mar 02, 2009
    Well thanks but I am no electrician and I started to think as soon as I was born thank you!
    I have already contacted the seller but he is not going to admit responsibility now is he? I need to prove the charger caused the fault.
  • ctaylor-munr Mar 06, 2009
    drove all the way to fort myers florida fromm toronto canada and had neary a problem. next morning green light is on while plugged into the cigarette adaptor, but unit not turn on. pushed reset button on bottom next to SD card slot with no results. frustrating indeed.
    ct-m
    Habit-Forming:
  • 40 Answers
You should learn some elecricity and change some parts that broken, or buy new one, because it is out of waranty, or you can apply the problem to the ebay seller, start to think!!!
Posted on Mar 01, 2009
  • soras46 Mar 03, 2009
    well, how can you prove it?
    If you know you can use the law sales of goods 1979 and get all compensation for it.
    And, i'm not ebay user, but i heard that if you notify it to administration that user can be disabled.
All of a sudden all three keyholes didn't work. When you try to turn the key, it doesn't turn so you can't unlock the car. Its the same problem for all three keyholes including the trunk. I...
Hello
If the keyholes were not used for some time - then the grease in there could turn into stiff mass. Try put some wd40 in the keyholes and try to turn around with a key - watch out so that the key wouldn't break and stay inside the hole. Good luck
Jul 13, 2011 | Buick LeSabre Cars & Trucks
Can the Tomtom recharge wheh the car is not in use - eg in the garage
No, then tom tom cannot recharge when the car is not on. You need to turn on the car before your tom tom can charge. The battery gets to charge the tom tom when in use. Once the car is turned off the gps will not charge. You can try out a practical by turning off your car and plugging the gps to see if it will work. Or the cigarette lighter, does it work when the car is turned off. Since the cigarette lighter does not turn on when the car is off, then it means it gps cannot charge once the car is turned off.
Hope this information helped you!
Jan 10, 2011 | GPS
I just bought a GPX MP3 player (ML651B) I put music on it and was charging it. It now doesn't even want to turn on. I looked at the GPX website and I couldn't even find this one among their products. Now,...
The power button (more like a slide) on the bottom right side will turn it on once it's ejected from the computer. Hold the slide in, and let go after a second or two. Give it a few seconds (like 10) and it should power on. I got mine as a gift and am still working through the interface.
Nov 24, 2010 | GPX ML648B MP3 Player
I bought the new maps from website, and can not install
If the software crashed whilst updating, you will find that if you try to restore from a complete backup when you switch on next time it will either say you cant use the map or will just freeze, fix re format both the internal memory and the memory card, then find where tom tom home had stored the files, then using windows copy the contents from the 2 folders back into the relitive internal and external card, you will then find that you will get the mesage that you cant use the map, this is because tom tom home doesent always put the map data into the correct folder, to fix this find the licence data and the map data that has been stored on the sd card instead of the internal memory and copy it into the internal memory, before switching off press the reset button, when you switch on you should find that you have a working tom tom
Aug 25, 2009 | Tomtom ONE XL GPS
Tom Tom Go 730
trying to find how to got pin tom tom go 730
Jun 27, 2009 | Tomtom GO 910
I bought a Sears edger #536 796526. It dies on me.
Hi Tom. You are not doing anything wrong. That being said, your edger has a slightly gummed up carbeurator. I would go to an auto parts store and get a can of a product called seafoam. this is a gasoline additive. Add one ounce per gallon of gas and use this as the fuel for your edger. You will solve your problem in just a few minutes after using this product, I believe. Give it a try and let me know.
Jun 13, 2009 | Craftsman Gas Mini - Tiller/Edger
Tom Tom go 910 screen get frozen every time I turn it on
Sounds like your firmware is corrupted. I have fixed a few 910's with this same problem. If you have the Tom Tom Home program installed, try to reinstall the firmware using Tom Tom's website.
Make sure you always select to disconnect the device before unplugging it. You might have unplugged it from the PC while it was still writing data. This will certainly corrupt the firmware.
- Jim
Nov 14, 2008 | Tomtom ONE 3rd Edition GPS
Seeking the repair of my tomtom Go 910
One suggestion is to plug the Tom Tom using the temporary power cord to you home circuit (not the power source from the car). That worked for me. Sometime the Tom Tom shuts down when left in the hot car requiring a reset. Then the best way is to plug in at home and restart. Try it, otherwise I can't help.
Jim
Aug 19, 2008 | Tomtom GO 910 GPS Receiver
in that case you will have to take off 4 screws on back the navigation system
easily take the back piece apart and unplug the battery wait couple a seconds then plug it back
it should work
Apr 20, 2007 | Tomtom ONE GPS Receiver
Tomtom ONE GPS Receiver Logo
185 people viewed this question
Top Tomtom GPS Experts
LP
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
