Question about Dell 924 All-in-One InkJet Printer
Put in a new refilled cartridge and still reads X and won't print telling me to order ink
  • Ginger24 Feb 24, 2009
    My Dell 924 has been working well and suddenly it tells me that the black ink cartridge is missing, or unsupported, I have replaced the cartridge with a new Dell one, uninstalled and reinstalled the software, cleaned the contacts on the cartridge and machine with alcohol, unplugged it, and it is still the same, is there anybody out there who can help me or do I have to buy a new machine.
  • 514 Answers
Go to page 49 of the manual ("http://support.dell.com/support/edocs/systems/924/en/om_en/om_en.pdf" if you don't have it) good luck!
Posted on Feb 28, 2009
HP black ink cartridge and HP deskjet pritner 1055
end of life.
buy a real laser jet like hp1102w.
or better
inkjets stink, imo
Mar 02, 2017 | HP No 60 Black Ink Cartridge
U051 error message. Won't print
Well, you must be using PG30, CL31 cartridge for your printer.
Did you refill your cartridge?
For error 051 means printer is not reading the cartridge. (cartridge is not readable)
When you put refilled cartridge, that's what it happens.
(after 3~4 times of color refill, color cartridge is no long to use, only applies in Canon
and there is no solution for it.)
Pls replace with new one.. and will work again.
Or if you need to refill again with other cartridge, pls....unplug your printer before you taking out the cartridge. In this way, you can re use your cartridge. Little trick... but no solution will work, once cartridge is not readable.
If you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
May 11, 2011 | Canon PIXMA MP470 All-in-One Printer
How to install the ink
Open the front cover on the printer. The print cartridges should slide on a conveyor belt from one far end of the print chamber to near the center. There should be one black ink cartridge and one color cartridge.
Remove the cartridges from the printer. This should simply involve grabbing and pulling the cartridges out. There may be a flap holding the cartridges in place that you need to flip up first. Or you may need to press down on the cartridges to spring them out of place.
Decide on replacing the cartridges with a brand new ones or refilling the existing cartridges. Refilling the cartridges can cost less money in the long-term and reduce waste, while new cartridges will guarantee to work and have the most ink up front.
Refill the cartridges with fresh ink in order to reuse them. With black cartridges, you need to drill or melt a hole in the cartridge lid, while you will remove the lid to find the color cartridge's holes. Inject the correct color ink with a plastic syringe bottle. Reseal the lid on a color cartridge after refilling.
Dispose of the cartridges properly after you purchase new ones. Take the old cartridges with you to whichever store you get the new ones from. Not only will this help you find the correct replacements, but the store may also take the old cartridges for recycling.
Insert the new or refilled cartridges into your printer. New cartridges likely have protective tape over the print head that you'll need to remove. Run a test print on the computer to make sure that the cartridges properly work
Check to see if the printer still reads the cartridges as being empty (if you are reusing a refilled one). This will be due to a chip in the cartridges that the printer reads for the ink level. It doesn't change just because you refilled the cartridges. You must purchase an electronic device that will reset the chip for you.
Chris Thrash
B52Computers
Jan 21, 2011 | Canon Office Equipment & Supplies
How do i change the ink cartridge on a canon mp560 printer
Chris Thrash
B52Computers
Jan 21, 2011 | Canon MP560 All-In-One InkJet Printer
Why won't my canon printer MP460 read my ink cartridges? It keeps saying "Cannot read ink cartridges" on the black ink.
Hi, are you using Canon or refilled cartridges? If you are using Canon, there's a problem with the cartridge. If you are using refilled cartridges it's because the cartridge has been used. When you first put a Canon cartridge in, the printer reads the cartridge and knows it's a new one, I'm not sure of the mechanics of it, I don't know if it blows a chip or fuse in the cartridge but it can read a new one. If it's been used, it can't read it so you get the message that it can't read it.
Turn off the staus monitor and the message will go and you can carry on printing, it won't tell you when the cartridges are empty, you'll just notice the print quality going downhill.
Jul 05, 2010 | Canon PIXMA MP460 All-In-One InkJet...
Bland and color cartridges have been refilled but
Ink level counter (program) didn't read actually ink at ink tank. Brand new cartridge ink level counter 100% (full), and ink 100% (about 10 ml). After may printing, ink will dry out, and ink level counter reach zero (ink out). Printer will not allow print anymore, even have refilled, because ink level read "ink out". For canon type, you just to release ink level counter, and counter just stop, but printer will allow to print. Press stop/reset button for about 30 second.
Mar 15, 2010 | Canon PIXMA MP190 All-In-One InkJet...
Refilled ink cartridges, printer reads no ink and
This printer has a sensor that can tell how much ink is left, what you need to do, is cover the ink tank with a black tape, that way the sensor thinks the tank is full...
Dec 08, 2009 | Brother DCP 130C All-In-One InkJet Printer
Printer slow after putting in a refilled cartridge
Sounds like the TSR is out on your cartridge. The TSR is the heat sensor for your print head. If the TSR goes out it cannot tell the printer that the temp at the print head is at ok levels. So the printer assumes the print head is really hot and at risk of fusing its nozzles so it prints really slow (the faster the printing the hotter the print head gets). It is possible, but not very likely, that the ink in the cartridge is of such low quality that it is not cooling the print head properly as it flows through the nozzles. Thus the TSR tells the printer to print really slow so you don't burn up nozzles. If you got this cartridge refilled at a store or on-line I would return it and get your money back. I recommend Cartridge World for refills because if this happens to one of their refills they will give you a new refill at no charge.
Oct 15, 2009 | HP PSC 1610v All-in-One Printer
Lexmark x3430 low ink warning
when you installed the new ink cartridge did you go into your program menu and find the lexmark solution center? If not, you have to go to the solution center, choose the maintenance menu and tell it you have installed the new ink cartridge. If you don't it will not recognize the new one.
Jun 23, 2008 | Lexmark X3470 All-In-One InkJet Printer
Dell 924 All-in-One InkJet Printer Logo
44 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
