Question about Maytag PAV2300 Top Load Washer
My Maytag wahsing machine fills to the correct level, will not agitate however when i put it to the spin cycle it spins!
  • Maytag Master
  • 3,361 Answers
The water level switch may be stuck and not sending a start signal to the timer.
Posted on Feb 22, 2009
Why won't my Maytag Brazos top loader washer, model mvwx600xw1 agitate or spin? Also, the lid lock light blinks once in awhile. Checked lid lock, still no spinning
my first suspicion is in the door lock switch if it goes bad u have no action in wash or spin, next I would first check the water pressure switch as it is the unit that sends the signal to the machine to start wash cycle? if the diaphram does not detect the proper level of pressure due to water level. it will just keep filling and overflow and never start wash cycle. als0 check the water inlet valve, lastly a bad clutch will not allow much in the way of a spin cycle but would not effect the wash cycle? a bad motor coupler on the other hand stops both wash and spin?
Mar 23, 2015 | Maytag Washing Machines
Water fills to over flowing and never starts agitate or spin cycle
With the tub empty disconnect the air hose from the water level switch in the console. Blow through it to see if its kinked or restricted. Check the air bell for a buildup of **** especially near the opening where the air hose attaches.
If all is OK reattach the hose and disconnect it from the air bell. Turn your water off and set it to wash. Blow through the hose to see if the switch goes from fill to agitate.
Jan 03, 2012 | Maytag Performa PAV2200
Hi, I have a Maytag Alantis Washer (model: MAV
Does it not spin just in the final cycle or not at all during the wash cycle? Also, does the wash cycle agitate normal?
Regards,Richard
Nov 07, 2011 | Maytag Washing Machines
Water runs through entire cycle until spin mode
Check the plastice hose going to the water level switch. It is pinched, or has a hole in it.
Repair or replace the plastic hose.
Apr 10, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Washer won't agitate
Check your timer and make sure that it is working correctly with a multi meter
Feb 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag washer won't fill or agitate; only spins on cycle
sounds like you have a blown fuse. I dont have a schematic so I dont kno where you have to look to find it
Dec 30, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Maytag Dependable Care Plus LAT8824
I think that you mean "Agitate" some of the time that you write "Spin" Yes?
If I understand you correctly, you have no agitation during the "wash" cycle, this is almost certainly a corroded agitator shaft seized up in the transmission.
Oct 05, 2017 | Maytag Dependable Care LAT9706
Washing machine fills, but won't agitate
sound like the lid switch is open, if that doesn;t fix it try the water level switch
Mar 27, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag PAV2300 Top Load Washer Logo
63 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
