Question about Brother MFC-8860DN Printer
MFC 8860DN Won't Scan to File
I loaded the printer on my mac and it prints,copies, faxes, etc. will scan to Image, but not scan to file.
I have loaded and reloaded the scanner driver directly from the website several times. Am I missing something?
SOURCE: reset drum - brother mfc-8860dn
Open front cover
Remove drum unit and toner cartridge assembly
Put drum unit and toner cartridge assembly back in machine, but do no close front cover.
Press Clear/Back
You will get a message "Replace Drum?"
Select Yes to confirm
Posted on Mar 16, 2008
SOURCE: Brother MFC 8860DN: Send Problems
Update the firmware and it does support SMTP-AUTH
Posted on Apr 15, 2008
SOURCE: Fuser replacement on Brother MFC 8860DN
Yes I did it myself, however I am savvy with most hardware, I wouldnt suggest it for the novice. It cost around $NZ245 for the fusing unit, which from doing a quick search online is about the same in most countries.
Posted on Sep 03, 2008
SOURCE: my brother mfc240c is out of ink, but won't scan to file. help
http://journal.drfaulken.com/trick-your-brother-inkjet-into-working-when-an-ink-cartridge-runs-dry/
This works like a charm!!
Posted on Oct 23, 2008
CarlGehrke
  • 169 Answers
SOURCE: Not able to scan to pdf file with Brother MFC-240C
What you seem to want to do is not possible. Let me explain:
A file that has its data in the Adobe company Portable Document Format (or a pdf file) contains various objects that are described to the computer using a superset of the PostScript language, some of them can be images.
A file that comes from the scanner is first a very organized set of pixels and gets put into a more compact form by using a well known process as defined by the Joint Motion Picture Experts group. This is a roundabout way of saying that it has a format that isn't PDF.
What you CAN do:
a) open the jpeg file with a Macintosh, using the Print command from the file menu make a pdf file that has the image in it.
b) buy and install a PDF printer driver on a Windows machine, and then follow the same process as A above.
c) Use your favorite PDF creation program to make a file with the image embedded.
Carl
Posted on Dec 10, 2008
Cannot scan to computer
I've been able to go into my mac and open up my printer and go to the scanner and scan from there. Good luck..
Apr 04, 2013 | Brother MFC-J625DW Wireless All-in-One...
Scan and copy modes inop
try resetting the machine by unplugging it for an hour, and then start it back up. Next go to the menu, and reconfigure your fax settings.
Feb 25, 2008 | Brother MFC-8860DN Printer
I have a lexmark 464de mfp. How do i setup scan to e-mail on windows 7 on this network printer?
Multi-function printers cannot scan and then e-mail the scanned image. They can scan and then fax a document.
You need to scan the document, then save the scanned image, open your e-mail program and create the e-mail then attach the image file (file attachment) to the e-mail before you send the e-mail.
Jul 08, 2011 | Lexmark X464DE Mono Laser MFP, 38ppm A4...
How do i change the file name that is attached when i use "scan to email" ,change the file in then machine constantly , now i get image.pdf
I could never get my Control Center software to behave, so I just sucked it up and used Paperport.
I got my first copy several years ago with a scanner and have upgraded through each edition.
With the Brother software, I can put the documents into the feeder, run Control Center on my computer, and it let me edit the application that opens when I click Scan to Email, but the attachment always messed up and gave an error.
With Paperport, I click on Scan Settings and I am presented with options to pick a document type (color, b&w and resolution) and device options including auto straighten, pdf, OCR, etc. As it's scanned, I can then merge or unmerge the pdf pages and name them by hand.
It is a $100 program, but they usually offer it for half price most anywhere from time-to-time.
http://www.google.com/search?q=paperport+12&rls=com.microsoft:en-us:IE-SearchBox&ie=UTF-8&oe=UTF-8&sourceid=ie7&rlz=1I7GGLL_en
There are other Scan to email software programs, that may be free, that will do the same thing.
Carl
Jun 19, 2011 | Brother MFC-8860DN Printer
Lexmark 5600 how can a I scan or make it a word document or pdf file
You will need the Lexmark OCR scan software to scan a document from the printer to your computer and save the file as PDF, word document, etc. The Lexmark OCR scan software is only available in the installation disk. If you don't have the disk or you lost it, contact Lexmark technical support to request for it. Thank you for choosing Lexmark.
Sep 14, 2010 | Lexmark X8350 Print, Scan, Copy and Fax...
Brother MFC 8220 all-in-one fax prints with a vertical line
First guess is you have a bit of dirt (often white-out from people scanning corrected paper that's not quite dry) stuck on the fax scan window. This should be described pretty well in your user manual (which you can download online from brother.com).
Its also possible that there is dirt (typically loose toner) on the laser scan window (there's a laser that shines through it to get the image pattern on the drum). That window is often along the bottom of the unit under the drum/cartridge (take the cartridge out and look). The Brother manual I've seen seems to ignore this possibility.
Print streaks DO NOT mean cartridge drum replacement in many cases !! On brother Intellifax or MFC or other laser copier/printer/fax, keep in mind that either the fax/copy scan window OR the laser scan window can get dirty. If the fax scan window is dirty, you see streaks on outgoing faxes and copies (but NOT incoming faxes). If the laser scan window is dirty, you see streaks on all prints (copies, faxes, print-from-computer).
Note also that when transporting/moving some laser copier with the toner cartridge inside, the toner can get out and make a big mess inside (including getting the laser scan window dirty). An air compressor can be usefull to blow it out. And sometimes using alcohol to clean is a BAD idea (maybe incompatible with plastic and rubber parts). A damp rag is probably fine.
Nov 21, 2009 | Brother Office Equipment & Supplies
Can't email scanned files.
hell csnevels you will need to uninstall the program and then reinstall the cd that came with the machine, if not you could download the cd from brother.com brother tech
Jan 17, 2009 | Brother MFC 240C All-In-One InkJet Printer
My Brother 8860 DN does not copies, yet it can print . The menu screen only allows fax, not scan or copy.
This is commonly an issue with the Keypad PCB. We can get you pricing on parts if you want to try this as a repair. Does the machine beep 3 times when you hit the copy or scan keys?
Dec 31, 2008 | Brother MFC-8860DN Printer
What you CAN do:
Carl
Dec 10, 2008 | Brother MFC 420CN All-In-One InkJet...
Brother MFC-210 fax issue
Install fax software . You can do this with the following procedure:
go to control panel, go to add and remove softwares and then in install windows components install fax .It will ask u for a windows cd
Dec 08, 2008 | Brother MFC-210 All-In-1 Print/...
Brother MFC-8860DN Printer Logo
164 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
