Question about Minn Kota Maxxum 70 Freshwater Bow Mount Trolling Motor
Minn Kota Maxxum 74lb Variable Speed issue
My trolling motor is stuck on a constant speed. you would turn the knob to off and it still run on that high speed. What should I do?
  • theflhowes33 Apr 10, 2009
    I have the exact same problem
2 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: Minn Kota maxxum digital control board
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Aug 13, 2010
Why it runs half speed wide open?
propeller could be slipping. It is sometimes held tight by a rubber washer that wears out.
May 23, 2014 | Minn Kota Maxxum 70 Freshwater Bow Mount...
I have a 5 speed forward minn kota only 3 speeds work ,I replaced the speed control box but have the same problem
Check the Relay's these will be found in the control module, Most likely totaly sealed, test or replacement may be required
Aug 26, 2010 | Minn Kota Maxxum 55 Freshwater Bow Mount...
Trolling motor stays on same speed no matter where I set the speed 10 -100. It is at a mid range speed.
I just recently had a simialr problem. No speed control and motor only ran at 100. I talked to the minn kota tech rep and sent him my control board and he said it had a bad potentiometer...however, I had to buy a control board to fix the problem ($215). Hate to say it but sounds like you may need a new control board.
Jun 24, 2010 | Minn Kota Maxxum 70 Freshwater Bow Mount...
Burning out fuses on trolling motor at battery
not enough info. I went the the min kota website, they show four maxxum 80's at different voltages.is it a 12v 24v or larger? without a year model I'll have no reference to what wiring schematic Is the fuse connected inline with the trolling motor? what size amp fuse are you burning up? well I can give you some troubleshooting tips. tools to buy (1) amp gauge. if you are unfamilier with amp gauges make sure you get instruction book with gauge or you could burn yourself. Toubleshooting(1) Remove cover off minn kota trolling motor. black cover ontop of unit were the foot control wires go into.turn over foot control remove cover (2) check for corrosion. any exposed terminals should be cleaned.(3) go to your batteries and clean all connections. make sure the batteries are fully charged.(4) take amp gauge and test positive wire for amp draw as you tun on trollling motor and run it through all speeds. if batteries are in the rear away from trolling motor get a 2nd person to control trolling motor. if the trolling motor is more than a 12v system you will have more than one positive lead to test.GOAL. What your trying to find out is how many amps the trolling motor is really pulling. and at what speeds. under a load in the water and out of the water.how many more amps than the fuse raiting? newer trolling motors come with inline breakers not fuses so I'm guessing your using 30 amp fuses. again without more info i can only guess.
Oct 29, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
On a Minn Kota All Terrain trolling motor, what should the MOM/OFF/CON switch be set to when using the foot pedal manually?
You should only use the MOM (or momentary) setting when using the push button the foot pedal. Con will just keep the motor running and your foot control will only allow for direction and speed!
Jul 06, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
Ran aground on lake,now stuck on high speed,can't lower speed
My Minn Kota 55 powerdrive had the same problem except mine occurred while it was trailered in the yard. High speed only, everything else worked great. From what I could research the control module is a frequent problem. Took a chance and purchased a new control module and this cured the problem. Maybe this happening and running aground was just concidental.
Apr 06, 2009 | Minn Kota Maxxum 55 Freshwater Bow Mount...
What size batteries needed for minn kota 24 volt 74lb thrust
I use Red Hot Mama batteries. These have held up for longer than any other brands that I have used. These are deep cycle marine wet ones.
Nov 12, 2008 | Minn Kota Maxxum 70 Freshwater Bow Mount...
Minn Kota Maxxum 70 Freshwater Bow Mount Trolling Motor Logo
206 people viewed this question
Top Minn Kota Boating Experts
Mike Marcotte
Mike Marcotte
Andrew Taylor
Andrew Taylor
Colin Stickland
Colin Stickland
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
