Question about Dell 924 All-in-One InkJet Printer
Show location and how to access cartridges on dell printers
Demonstrate exactly where the ink cartridges are located and how to gain access to them in order to be able to change to a new cartridge in. My printer service tag is: 5Y0Q6FI. Please help.
  • 512 Answers
Go to page 49 of the manual ("http://support.dell.com/support/edocs/systems/924/en/om_en/om_en.pdf" if you don't have it) good luck!
Posted on Feb 28, 2009
Ink jet cartridge
  • 1 Select the ink cartridge specific to your printer. Canon inks are versatile, so your selection may be as simple as choosing between black, color or a multi-pack with black and color cartridges.
  • 2 Turn on your Canon printer. The switch is generally located on the top right hand side of the printer. Open the printer's lid.
  • 3 Wait a moment. The cartridge carrier will automatically disengage.
  • 4 Put your hand behind the existing ink cartridge and pull the cartridge towards you until it pops out. Dispose of or recycle the used cartridge.
  • 5 Carefully pull the tape off the new cartridge.
  • 6 Position the new cartridge into the cartridge carrier. Make sure it is facing the correct position.
  • 7 Press the cartridge carrier gently until it clicks into place. Some cartridges have indicators to demonstrate that they are properly positioned.
  • 8 Close the printer's lid. Print a test page to ensure everything is working properly.
  • Hope It's resolve all Your Printer Problem,
    Or Still having Problem Then follow Us For
    Canon Printer Support
  • Apr 22, 2014 | Canon MX340 AllInOne InkJet Printer
    Finding compatible upgrade to cpu 870
    Instructions
    5
    6
    7
    8
    Jan 10, 2013 | Dell Studio XPS 8100 PC Desktop
    Brains are fried. Kodak is taking it back and sent us a refurbished printer. I want to get my old cartridges back!!!! They are under the plastic housing (far to left). I have pried off plastic,...
    To replace an ink cartridge:
    1. Make sure your printer is on.
      Lift the printer access door, and wait for the carriage to move to the access position.
    2. The black and color ink cartridges are located in the printhead.
    3. Pinch the latch on the ink cartridge and lift it out of the printhead.
    You should now be able to get the ink cartridge out.
    Mar 30, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
    Where do i change the ink cartridge in the dell 948 all-in-one printer
    Hi
    Scanner base unit
    Unit you lift to gain access to the ink cartridges.
    Lift the base of the scanner unit to access the ink cartridges.
    Dec 23, 2010 | Office Equipment & Supplies
    How do i install the ink cartridge in my lexmark z35 printer
    Oct 31, 2010 | Lexmark Computers & Internet
    Why stil show empty after installation of refilled ink cartridge
    As you were using a refilled ink cartridge, it needs to be reset. When you refill your cartridge, it will read as low or empty when you try to print with the cartridge.
    There was a embedded serial number in the contact strip located on the back of the cartridge and your printer remembers that serial number and gives the message of low or out of ink. The internal memory is located in the printers firmware and is not in the software. It will remember the previous two cartridges ink level.
    On this matter I need the exact model of your HP printer so I can assist you more further on this.
    Let me know from you again here soon. Just leave a message and I will attend you ASAP.
    Thank you for using fixya.
    Jun 22, 2010 | HP Deskjet D2660 All-In-One InkJet Color...
    Replaced ink cartridge still shows ink low needs to be replaced but is printing? Can it be reset?
    1. Remove your current empty cartridge from your Dell printer. Turn on your printer and lift the cover and top half of the unit. You can suspend it in place by lifting the blue plastic lever and securing it to hold up the top of the printer. At this point the ink cartridges should move to the center of the printer and be easy to access. Follow the instructions locate on your printer to remove the cartridges. You can do this by pressing on the blue tab to remove the colored cartridge or the black tab to remove the black cartridge. Once you press the tab, the cartridge cover will pop open. Carefully pull out the exposed cartridge from it’s setting. Save the empty cartridge so it can be refilled.
      Remove the sticker from the newly refilled Dell ink cartridge. Follow the directions on the opened printer to insert the cartridge. Hold the cartridge so the writing is on the top and the ink spot is on the bottom. Gently push it into the opened setting until it is securely in place. Close the cover of the cartridge holder by pressing down on it gently until it clicks into place. Remember that the black cartridge goes into the black setting and the color cartridge goes into the blue setting. Close the top of the printer. You will hear the ink cartridges move back into place.
    2. Test your newly refilled Dell ink cartridge and load your printer with paper.Print a document so either in color or black and white (depending on the type of cartridge you had refilled). Review your printed document to make sure the color is consistent and you are pleased with the outcome.
      Repeat whenever you run out of ink.
    Apr 30, 2010 | Dell V305w All-In-One R840635AU InkJet...
    How do I open my canon printer to change the ink cartige?
    Step 1
    1. Select the ink cartridge specific to your printer. Canon inks are versatile, so your selection may be as simple as choosing between black, color or a multi-pack with black and color cartridges.
    2. Step 2 Turn on your Canon printer. The switch is generally located on the top right hand side of the printer. Open the printer's lid.
    3. Step 3 Wait a moment. The cartridge carrier will automatically disengage.
    4. Step 4 Put your hand behind the existing ink cartridge and pull the cartridge towards you until it pops out. Dispose of or recycle the used cartridge.
    5. Step 5 Carefully pull the tape off the new cartridge.
    6. Step 6 Position the new cartridge into the cartridge carrier. Make sure it is facing the correct position.
    7. Step 7 Press the cartridge carrier gently until it clicks into place. Some cartridges have indicators to demonstrate that they are properly positioned.
    8. Step 8 Close the printer's lid. Print a test page to ensure everything is working properly. ....plz give feedback..
    Nov 15, 2009 | Cannon Canon i960 Photo Printer
    Where is the Ink cartridge for Dell 962 located at?
    If you mean how to access the ink cartridges, go to this link and go to "Ink Cartridge maintenance"
    http://support.dell.com/support/edocs/systems/962/en/OM/962_English.pdf
    If you mean, where do you buy Ink, follow this link and take your choice:
    http://www.google.com/search?hl=en&q=dell+962+ink&btnG=Google+Search&aq=f&oq=&aqi=
    Aug 04, 2009 | Dell 962 Photo All-In-One InkJet Printer
    Dell A940 and A960 printers will not print in black ink, just purchased ink cartridges from Office Max, have deleted all info from computer of previous A940 and A960 printers, reinstalled program via disc....
    I had the exact same problem with a replacement black cartridge directly from DELL. I called support, and they just had me clean the cartridge manually by swiping the print strip, then running the standard cleaning commands in the computer. I had to do that a couple times, but eventually the black ink started working again. VERY ODD. I hated dealing with it, but these steps worked to fix it eventually. Hope that helps.
    Dec 15, 2008 | Office Equipment & Supplies
    Dell 924 All-in-One InkJet Printer Logo
    55 people viewed this question
    Top Dell Office Equipment & Supplies Experts
    Electro Med Services...
    seerads
    Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
