Question about LG 37LB1DA Television
I have a LG 37LB1DA and the screen remains black
I have a LG 37LB1DA which for not reason the screen went black. I can turn on and off but when I turn the thing on the screen remains black although it has apppered to do something but I have no input.
3 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: LG 26LC7D LCD TV that turns on, but no pix
IF the backlights are on but you just get dim glowing on the screen when look at the screen in darkened room then the T-CON board is bad or it is not getting the 12vdc from the main logic board. Need to use logical troubleshooting before buying the wrong parts.
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=LG+26LC7DC+
Posted on Jun 26, 2010
Testimonial: "Seems to have good clues. Will now apply them."
info33
  • 72 Answers
Here is a link for the manual - it might help - http://tv.manualsonline.com/manuals/mfg/lg/26lc7d_26lc7dc_32lc4d_42lc4d.html
Posted on Jul 03, 2010
Is there a way to stop the burn-in mode on a lg tv
In the Menu, there should be options to disable or change how the TV handles burn-in, which might be called Anti Image Retention of something like that.
May 26, 2014 | LG 37LB1DA Television
Screen is dark and pixalated
If u have warranty means then claim it.................
Jul 22, 2008 | LG 42PX5D 42 in. Plasma HDTV
I have a lg 37lb1da tv that is flashing red blue green when you turn it on
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience. Do a search by type in the brand name of the device to the search box.
Sanyo TV - black screen, sound find
The black screen on your Sanyo TV is symptomatic of power supply failure
Jun 03, 2013 | Televison & Video
LG 37LB1DA flat panel TV
most likely the inverter board is faulty, I think this model has two of them, look on ebay for cheap replacement.
Mar 24, 2017 | LG 37LB1DA Television
Not able to turn it on. for no apparent reason the screen was black after setting overnight. The pilot light was on. tapped the space bar a couple of times thinking the computer would wake up and desk top...
I have the same monitor & just had same problem. Did you find a solution to your problem? This is the second time my monitor has done this. The first time I had problem i unplugged it and disconnected it from pc. Plugged it into power source and blue pilot light came on then went off. I did see the LG logo on screen before it shut down. After several times doing this and pressing the power switch repeatedly it seemed to reset and recognized it was not receiving a signal and indicated this. I then reconnected monitor to pc and all appeared to work fine for several days. Now I again have same problem after sitting over night.
Dec 02, 2009 | LG W2252TQ Monitor
Black screen after a couple of seconds
The monitor needs to be replaced. I had an LG LCD that did this luckily it was still under warranty. Contact the maker and have your receipt handy. Otherwise buy a new monitor. Monitors tend to be replacement only
Apr 11, 2009 | Gateway FPD1960 19" Flat Panel LCD Monitor
Our LG 37LB1DA is scrolling through channels
I have seen problems similar to yours in the past. Several causes can make the channels change by themselves. Some corrosion on the main board near the channel up/down switches for one. The next common cause is that the EPROM may be failing or a fault with the main control processor. A good test to see if the EPROM is having a problem is to program in all the channels off the cable and then unplug the TV over night and then plug back in the see if any channels are missing.
Jan 17, 2009 | LG 37LB1DA Television
TV screen went black, sound OK
check cold solder vertical circuit
Nov 21, 2006 | JVC AV-27530 27" TV
LG 37LB1DA Television Logo
175 people viewed this question
Computer Repairing
Computer Repairing
