Magnavox 37mf33id 37 tv cut off will not turn back on green light
Tv cut off i unplugged for awhile plugged back in no only green light on front of tv flashes when you try to turn on no picture or sound any solutions?Won' turn on when turned off. Left it on. This morning, it is off and is churpping.
  • 728 Answers
If you know what you are doing, and you are good with technology, you can open the tv and check for any blown fuses or capacitors that may be stopping any power from going any further. Also look at the green light on the front of the tv and see how many times it blinks consecutively. Then look in the manual and see what it says the problem is.
Posted on Feb 22, 2009
  • 10,594 Answers
As you already know it is power supply problem in your TV.
You can buy power supply from Shop Jimmy.
Please call there and ask availability as currently not in stock.
Good luck.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
The chirping is very significant, it indicates that that power supply is inoperative. This could be:
  • a faulty power supply; and/or
  • a circuit load is using too high current and therefore the power supply has shut down.
Corrective measure to eliminate guess work would involve measuring resistance and then voltage checks on key/test points referencing a service manual or at the very least a schematic diagram. It would also require familiarity with electronic components & circuitry, the use of a DVM and a soldering iron. Should you be uncomfortable performing a DIY (do-it-yourself), then perhaps your best bet would be to seek the services of a qualified professional.
If you are considering a DIY and feel comfortable working with live and high voltages, pls post back.
Good luck and thank you for using FixYa.
    President:
  • 2,110 Answers
You have to change power supply board ...
    Scholar:
  • 164 Answers
Hi!
I have a question, did you leave it unplugged for at least four hours?
Is there any burnt smell?
Do you pets?
So far it is leading me to believe that it is the power supply blown.
That costs about $150.00. Sears can fix it but charge $100.00 which is aplplied to total cost of repair.
Keep me posted please.
    Brigadier General:
  • 8,619 Answers
Hi
Please check for the cables at the back.Have you suffered from any power outage recently?Also try to plug it into a different socket and check if it works.
Why toymax magnavox 37mf331d 37 in tv worked good i turned it off came back to turn it on and it wont come on the green light that is usually there its not on ?
Fault with the main power supply regulator section. Either it will be on a separate board, or on the part of its main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Nov 27, 2014 | Toymax Magnavox 37MF331D 37 in. LCD TV
Cap checker bad
fault in main controlling board
Nov 19, 2013 | Philips Magnavox 26MD357B-37 26 in. LCD...
Magnavox 37MF321D/37. suddenly just shut off and would not turn back on, no blinking green light nothing!
Price the board first and then decide, I fix these in our shop but do not like or enjoy working on them at all.
Dec 20, 2012 | Toymax Magnavox 37MF231D 37 in. LCD TV
I have a magnavox 42"
Problem could be in the Main unit Board, check out www shopjimmy.com
May 31, 2011 | Philips Magnavox 42MF521D/37 Television
The magnavox hdtv model number 37mf33id-37 will not come on but the green light flashes above the on /off switch
Tries tv unplug,replug it back like about an hour later.Now the tv should be resetting itself back to the factory setting.The tv now should work again.If not the problems and the causes is the tv power supply board problems.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Dec 02, 2010 | Philips Televison & Video
I have 50 in plasma phillips magnavox 50mf231d-37, will not come on red light flahses 4 times
this is some info that some one else had found
get a memory stick( flash drive) and up load their soft ware from their site. I plug the stick into the computor and uploaded the software. I then plugged the stick into my TV on the side. A screen came up and the software loaded on the TV successfully. The red light then turned to green. However, I now have to unplug and plug the TV several times for it to turn on. It works fine but once the TV is turns on, but when I turn it off and it cools for a while I have to repeat the same proceedure off plugging and unplugging
Jul 12, 2009 | Philips Magnavox 27MS343S 27" TV
Magnavox tv manufacturing date october 1989 model # rk4482ak02
You might try unplugging the set and let it set for awhile and then plug it in again.
Since the set is so old there may be a loose connection somewhere on the main circuit board. When you moved the set you jarred it and caused the connection to fail.
Stargazer
Feb 19, 2008 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
129 people viewed this question
Top Televison & Video Experts
