Question about Philips 23PF5320 23 in. HD-Ready LCD Television
Trying to find a port for sound input on Philips DVI LCD TV.
Just got Sky HD and I am trying to find a port for sound input on a DVI HD Ready Philips 36 inch LCD TV; can't see model number (about two and a half years old). Can get sound (but no pictures) through AV slot. There is a headphone port but can't see anything for a phono jack.
  • Philips Master
  • 5,568 Answers
If it is two-channel sound, the 'line' inputs should be color-coded as red (right) and white (left).
Posted on Feb 22, 2009
I have a Philips flat screen HD ready TV for my xbox. I don't know what type though as my parents have upgraded to an LG and we now have this Philips TV. I have Sky connected to one of the EXT ports and...
Perhaps the Phillips TV isnt compatible with some of the Xbox Settings.
Or mabye when you adjusted your settings it may have affected any graphics.
Apr 07, 2010 | Microsoft Xbox 360 Console
Connecting to HD TV
This TV has no HDMI input socket. It Has a DVI input socket. Therefore you will require an HDMI to DVI converter adapter or an HDMI to DVI cable. The DVI is video only so you will require audio cables from your Sky box (Audio L and R ) which will connect to the back left of your TV (Audio L/R sockets next to the s-video and component video connectors)
Nov 02, 2009 | LG RZ32LZ55 32 in. HD-Ready LCD Television
Connect tv to cable box with hdmi lead
You will need an HDMI to DVI cable which are available in the shops, even ASDA has one but I don't know how good it is. Or you can buy an adapter that will plug into one of the ends of the HDMI cable and then plug into the DVI socket at the back of the TV. The DVI input is video only so you will need audio leads for sound. These will connect from the output of your source, say, blue ray or sky HD (Left and right audio sockets ) to the audio L/R at the back left of the TV (on the block next to the three component video connections and s-video connections)
Oct 03, 2009 | LG RZ32LZ55 32 in. HD-Ready LCD Television
DVI-HDMI work but there is no sound
DVI input has no sound as normal you can use a RCA connection to get sound from the freeview box
Apr 21, 2017 | ViewSonic N3000W 30 in. HD-Ready LCD...
Trying to hook up my PS3 to my Viewsonic N3000W to enable me to watch HD BluRay Discs. There is no HDMI socket at the rear of the telly. Disc plays but HD picture quality looks the same as ordinary DVD....
Your TV has a DVI input connector, but no HDMI as you noted. Adapters (fondly called "dongles") are available to convert from the DVI connector to an HDMI jack so you can connect your HDMI source. Search for "dvi to hdmi adapter" with your favorite search engine and you will find them.
As for settings, this set has 720p resolution. Make sure your source is set accordingly, and you should be set to get the best quality you can with the connections available.
Please take a moment to give this solution a fixya rating if you've found it what you needed, and thanks for asking here!
Mar 05, 2009 | ViewSonic N3000W 30 in. HD-Ready LCD...
No sound on the hd setting on my lcd phillips hd tv
look in the owners manual about installing devices or components--- sounds like you have something hooked up wrong that is not allowing the video and sound to work--- if that doesnt work--- try using a combination device and hooking the two items to it--then run that device's wires to the television
Dec 03, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Trying to connect PC to Philips LCD HDTV
While the tv is on the right input, and the computer is running, try unhooking the cable and hooking it back in. That's the only way I can get my Philips to detect the HDMI signal from my pc. I haven't found a fix for it though.
Jan 29, 2008 | Philips 37PF9996 37 in. HD-Ready LCD...
SPDIF Output
SPDIF output is only for the integrated digital tuner.
Jan 23, 2008 | Philips 37PF5521D 37 in. HD-Ready LCD...
No sound through ps3 hdmi
hi i had a problem, but had no pic, but did have sound, rang sony, and they said buy a new hd cable, went out and bought one, and it worked fine!!!
Jan 08, 2008 | LG 42LC2D 42 in. LCD HDTV
My hd tv
to view anything in High definition you have to connect to your tv using either the DVI, Component or HDMI inputs. Your cam or anything you want to view HD videos from will need to have a lead to suit these inputs, the component lead will consist of an input from camera to five seperate coloured leads or an oblong DVI connector or HDMI which looks similair to a usb connector. You will need then on your tv to select the resolution of 720P or 1080I to view the HD picture.
Jul 14, 2007 | Philips 37PF7320A 37 in. HD-Ready LCD...
Philips 23PF5320 23 in. HD-Ready LCD Television Logo
151 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
