Question about Solis Master 5000 Espresso Machine
Water flow problem
We used a grinder cleaner and the water flow seems to be blocked, the machine grinds coffee but no coffee is produced, the machine seems to be blocked
    President:
  • 1,618 Answers
Check the coffee chute to see if its clogged. It is easier to use a small amount of white rice to clean your grinder, about a teaspoon.
Posted on Mar 11, 2009
What would cause the machine to grind the beans but not produce any coffee despite the water tank being full?
Your grinder setting might be too fine. Only adjust while the grinder is grinding -- set to a coarser grind. Have you tried the preground coffee dispenser? Again, use coarser ground coffee in case the sieve is getting clogged.
Mar 27, 2015 | Coffee Makers & Espresso Machines
Fill beans
the coffee beans are not entering in the grinder disks and since they rotate without coffee the machine understands that their is no beans. You need to clean the grinder disk and grinding coffee funel to bee sure their nothing blocking the coffee movements. Use a vaccum cleaner and try to clean everything in grinder and grinder exits. Try also the machine by regulating thegriding to more gross coffee and when it will start grinding normal then you can udjust step by step back to grinding position you have at the begeining.
Feb 27, 2012 | DeLonghi ESAM 5500M
My Bunn coffee filter overflows during brewing. What a mess! Is there any way to slow down the water flow?
If this is a pour-over coffeemaker, you can't do anything about the flow. It's just gravity pushing the water out of the reservoir. But you can try using a coarser grind of coffee. If the grind is too fine (if you grind whole beans for too long in a blade grinder, for instance, or if you're using espresso grind coffee), the water can't flow through quickly enough and it backs up and overflows. Make sure your coffee is ground for a drip coffeemaker.
Aug 02, 2011 | Bunn Coffee Makers & Espresso Machines
Grinder blocked
One posible problem is the coffee shute. This is leading aslo to the passage where you put the grinded coffee and cleaning tablets. This might have be clocked from dry coffee mixed with humitity or steam. So you can use a bending brush similar to the one used to clean babes milk bottles and at the same time vacum with air vacum cleaner.
You can make perfect cleaning if you remove the top platic panel and visual check that everything are perfectly cleaned.
The last thing that is possible for the problem is weak ginder motor which have lost its power so it can grinds but not have the power to push the grinded coffee all the way through chute to the coffee group. In this case you will need new grinder motor.
Hope that this can help you, good luck.
Jun 04, 2010 | Saeco Royal Professional Espresso Machine
My Jura S9's grinding unit clogged (due to Peete's beans)
Usually water in the grounds container is caused by the coffee solenoid valve return side being blocked from dry coffee. Using cleaning tubelets to clean the coffee grounds out. If that doesn't work then you should remove the solenoid and clean it out with warm water. If that still doesn't rid you of the wet grinds you should have a certified repair tech take a look at it. You may end up having to replace the solenoid but that should be verified by a tech before you spend the money.
Apr 26, 2010 | Jura Capresso Impressa S9 Coffee...
Hi, Our Gaggia machine will not disburse water through coffee dispenser. Sounds like its operating normally till water flow should happen. Then the motor slows down to nothing. Have descaled to no effect....
Try this press the button for ground coffee then when it lights up press the coffee brew button, if water flows normally then the grind on the grinder needs to be adjusted coarser, if no water then the screen on the brew unit is blocked.
Sep 07, 2009 | Gaggia Syncrony Logic 74884 Espresso...
Waterflow/heat seems fine - but little/no extraction
Try running the gro;up without the portafilter in place, what does the water flowq look like: is it a nice strong flow or barely a dribble. If if is barely a dribble, backwash machine with purocaff and check shower screen, that may be clogged. If you have a nice flow then try adjusting the grind on the coffee grinder.
May 09, 2009 | Rancilio Silvia Espresso Machine
Machine doesnt produce coffee
Try this, your machine has a manual/coffee grounds input, press the button for that option and see if water flows from the coffee spouts, if yes then adjust the grind on the grinder to coarser, if it gives you a ventilate error, then one of the lines to the brew unit is blocked, nd you will have to run the descale again or open machine and find blocked line and clear.
Mar 16, 2009 | Gaggia Titanium Espresso Machine
Solis Master 5000 Espresso Machine Logo
228 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
graybeard32301
Colin Stickland
Colin Stickland
AZBen
AZBen
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
