Question about Connex 3300 240-Channels Base CB Radio
Power outage The power goes out. Had a repair shop look at it and fix 2 cold solders. It worked great for 3 days and then the same problem again. I tried another power cord but it was not big enough and just kept blowing the fuse
  • 40 Answers
This radio takes a 7 amp fuse in the fuse holder if it blows the fuse the most likely the radio has blown the protection diode at the power plug on the positive side this usually happens when the radio is hooked up backwards.
Posted on Mar 12, 2009
Describe your Kenmore 53652 / 53654 / 53659 Side by Side Refrigerator Unit is not cooling. Stopped working after power outage
Kenmore Coldspot 106.53652300
I just fixed my neighbors fridge that suffered from a power surge. She explained that she smelt a burning smell in the kitchen and the next day the fridge and freezer were not cold. Of course she did not share the burnt smell part until after I discovered the starter relay and the capacitor were burnt on the compressor. She purchased the new starter kit and capacitor from a local supply company and while installing them I discovered the compressor fan was not running which also meant the compressor was not getting any power. I removed the screws that held the control panel on the fridge side (right side) and inspected the circuit board which I discovered a burnt trace on the board for the compressor control relay. I fixed the board by soldering a piece of solid core wire across it and it works great!
Make sure you shop around for your parts. The BIG local supplier here in Tulsa wanted $65 for the starter kit and $65 for the capacitor. We shopped around and found another supplier in Tulsa that sold them for $25 each and they were FSP parts!
Dec 15, 2009 | Kenmore 53652 / 53654 / 53659 Side by Side...
Panasonic phone KX-TG4500 base not turning on, I have had it for 3 years and all of a sudden it died, like a battery goes off.
I could tell the base unit was about to go a few days ago. Have had the phone for years with intermittent problems but it has been for quite awhile now. However, the screen on the unit started to blink a bit a few days ago. Had a feeling it was about to go but the phone kept working until this morning when it suddenly dies. After reading that changeing the cord might work, I replace the unit power cord with one from my handset and the phone is working again! Thanks for the suggestion!
Oct 01, 2009 | Panasonic KX-TG4500 Phone
Upon powering on my Toshiba 36" I get the normal.......
first of all have a nice day..the problem of your tv is a COLD SOLDER meaning there's only loss solder causing by overheated component such as resistor, tranformer etc. check and look closely to all of the suspected terminals, someting looks burning, try to solder all the susupected terminal using soldering iron and solder. chek also components it maybe cracked resisitor or diodes
Jul 30, 2009 | Toshiba 27A33 27" TV
Horizontal lines on screen after STR6301 replcement
hi just by using a 3-2 prong converter which is found at a hardware store can take away ur problem. It takes the plug into the wall from a 3 prong plug to a 2 prong plug and is supposed to work. try it and let me know if it works....
May 24, 2009 | Sony Televison & Video
Frigidaire upright freezer Model #FFU17C3AW1 Not keeping cold
Yes that is the correct part number.
If a new cold control does not correct the problem. Replace the compressor start relay.
Mar 12, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Fridge stops working when power goes out.
It sounds like maybe the freezer fan is coming back on ??? Do you hear it in freezer?? I would recommend having it looked at ----this definately doesnt sound normal.
Jan 16, 2008 | Kenmore Elite 21082
67" rear projection Mitsubishi....
Sounds like a cold solder joint, turn the main pcb over and see if you find any cracked solder or where the solder looks like it got hot.
Dec 04, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Intermittent losing blue on SD-643HD5 Pioneer
check the convergence area for bad solder
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Nov 01, 2007 | Pioneer SD-643HD5 64" Rear Projection...
Good possibility that the electrical contacts have failed (burned/welded) in either the defrost timer (part# 68233-3) or the Cold Control (part# 61002085. An intermittent failure is extremely difficult to track down. Both of the parts I listed total about $80. You can purchase them and install them for less $$ than having a professional do it for you. We would obviously charge more because we would absorb the cost of warranty, labor, drive time, etc... If you choose to replace these components, UNPLUG THE FRIDGE BEFORE HAND!
Jul 29, 2007 | Magic Chef CTB2125 Top Freezer...
Turns off 2-3 seconds after turning on-no red light?
sounds like a power deflection board issue its one board and it cost around 300 bucks its calld the d board i believe if it was just a cold joint solder it would be some xtra work trying to find the exact point but good luck
Jul 04, 2007 | Panasonic PT-56WXF95 56" Rear Projection...
Connex 3300 240-Channels Base CB Radio Logo
88 people viewed this question
Top Connex Radio Communications Experts
AnyMHz.com
AnyMHz.com
Jim Y
Jim Y
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
