Question about Roper RAS8445KQ Top Load Washer
Will not fill up with water
The water will run and the washer just will not fill do not see it leaking anywere, just will not stay in the washer and fill up to wash clothes
    Scholar:
  • 106 Answers
Check the exit hose behind your machine must be lying at floor level, this should not be. It must go over a certain height, approx 3 feet before it comes down to your drain. If you look carefully behind your machine you may find a water mark, the tube should go to this level & then down to your drain. Check this out.
Posted on Feb 23, 2009
My whirlpool just started leaking from the bottom of machine onto the floor. This happens when the machine is OFF and no clothes in machine. Is it a switch
The drain hose has to be higher than the water level at its highest point. IF there is water coming into the machine when it is not running then you may have a bad water inlet valve. They develop leaks like any faucet or valve. It could be some other things too, like the voltage to the valves is not completely cutting off. There is also some water that stays in those machines because it cannot all be pumped out. What is the model number?
Oct 29, 2017 | Washing Machines
My front loading washer always fills with water when i am not using it
It sounds like one of the automatic water fill valves in the machine is leaking water when washer is off and the valves are closed. There are two manual water supply valves at the wall behind the washer, one for hot water and one for cold. Close the manual hot water supply valve and allow the washer to sit and see if it fills with water. If it does fill, then the cold water automatic fill valve is leaking. If not, then open the hot water manual supply valve and close the cold water manual supply valve. Allow the washer to sit again and see if it fills. If it does then the hot water automatic fill valve is leaking. Replace the leaking valve in your washer. You can order the new valve online using washer brand and model number on a appliance parts web store, or maybe even find it at a local appliance parts store.
May 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washer is leaking from bottom,but I don't know where it's coming from
Remove the case and do a load. Look for leaks. I bet the pump is leaking:
Apr 01, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Roper washer leaks when filling
It's in the drain hose somewhere,during the fill the water gets as deep in the drain hose as it does in the washer,during the wash the pump runs in reverse keeping the water level in the hose low,during the drain the hose is filled again.
Prop the washer up in front on a couple bricks or boards,start putting in water until it starts to leak and take a peak under the machine.
Sep 27, 2009 | Washing Machines
Water leaks out of bottom of washer
The screw in the washer tub, is not a factor in this. I'm not sure what brand of machine you have, but several machines have a fill hose that connects to the outer tub of the machine. Sometimes when a machine gets loaded heavily, during the spin cycle items in the machine can actually knock the fill hose right out of the tub. Then when the machine trys to fill the next time, all the water runs down the outside of the tub and leaks out of the bottom of the machine.
Repair is to open up the machine. You'll need to remove the top cover and that will give you access to the hose/tub connection. It may be as simple as reinserting the hose back into the drum or you may need to replace it if it got too damaged and won't stay in the hole correctly.
If you need specific how to's on opening up the machine, get back to us with the make and model info and we'll be happy to help you open that washer up!
K
Aug 01, 2009 | GE Washing Machines
During the fill cycle, the washer leaks water?
I've repaired leaks from bad rubber washers on the fill hoses as well as loose hose clamps on the back of the fill solenoids that run into the tub. Check closely.
Jun 27, 2009 | Maytag Washing Machines
Ideset front load washer
If no water is entering the drum, and it is not leaking out anywere, then there can be no water coming in at all, unless the pump is coming on right away and pumping the water out., check the waste outlet pipe as it is filling, and see if water is discharging from hose
One other possibility is that the belt is off and the whining niose is the motor turning on it's own with out turning the drum.
This being the case, u probably wouldn't see any water in the drum, due to the small amount that they take in.
Plz rate my solution.
Thanks.
Dec 29, 2008 | Indesit WA 125 Front Load Washer
Water leaks out bottom of washer when filling
Open up the top of the machine after disconnecting the mains. Check the pipes coming from the inlet valve to the dispenser box. One of these must hv come off. Refix carefully.
And don't forget to rate me pl..............
May 31, 2008 | Kenmore 46462 Front Load Washer
Roper RAS8445KQ Top Load Washer Logo
57 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
