Question about Whirlpool LER5636P Electric Dryer
Amana (Whirlpool) LE8517W2 electric dryer doesn't heat & more...
I have an Amana (Whirlpool) electric dryer (Model LE8517W2). It no longer heats up to dry.
What I've done so far to correct this:
After resetting the circuit breakers for the dryer (even though they did not look tripped) and after cleaning out all the lint build up I could find in the dryer, I removed the heater assembly (which has the thermal fuse & thermostat mounted on it) as well as a separate secondary monitoring device (either a secondary thermostat or a moisture sensor for non-timed degree of dryness shutdowns?) that was mounted in line with the exhaust vent just past the blower. I brought them all to my local appliance parts store where they found all but the heater assembly mounted thermal fuse to be in working order. I bought a replacement fuse (I would have replaced the thermostat at the same time, but it was unavailable. So in lieu of unnecessarily replacing the entire heater assembly ($70) I just got the fuse. I didn’t want to buy an unneeded part as they don’t take electric parts back as returns). I replaced the bad fuse & reinstalled the heater assembly and the exhaust monitor. I ran the dryer for a few minutes.
What is happening now:
The heat was back (temporarily), just not super hot. I placed a half load of towels in but it did not dry them properly even after a few hours.
Related background info:
It should be noted that before we lost the heat entirely the first time the dryer seemed to run forever before shutting down. The auto shut off seemed to be malfunctioning. The clothes were dry possibly an hour before it ever shutdown. I am not sure what is used to detect the level of dryness of the load whether a moisture sensor (surmised earlier) or what have you, but whatever it is, it doesn't seem to be working properly any longer. I am not sure if this could be tied to this problem or not but the cool down period seems to have stopped working altogether as well. When we opened the door to remove the clothes they were so hot I thought they could have possibly caught fire if they were left in for much longer. So much so that metal buttons and zippers would nearly burn you if you grasped them. I was wondering if this second issue (bad moisture sensor for auto shutdown) may have caused the first (no heat) due to excessive running times. (Needless to say I don't leave the house with the dryer running for fear of a fire.)
My question to you:
In your opinion what should I do next, replace the entire heater assembly or perhaps just the thermostat?
Your thoughts?
Thank you & sorry for the lengthy post (just want to provide as much info as I can so you don't have to ask for it).
  • 686 Answers
Yes you should replace your thermostat because the thermostat is what tells you heating element to shut down. They probably ckecked it for continuity and it seemed good but in reality it's not functioning properly. you seem to know about your dryer quite well so here's a site to go to and see about maybe replacing the entire heating unit check out items 1914 and 667745 at
Posted on Mar 02, 2009
Amana 7200 no heat
That could be the heater element or one of the safety limits mounted on the heater housing. I looked up the model posted and this is a newer whirlpool dryer with the filter in the top. Here is my homemade video of one of these dryers with a heat problem:
Nov 12, 2012 | Amana NED5200TQ Electric Dryer
Whirlpool duet electric dryer turns on but doesn't
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
Sep 01, 2011 | Whirlpool Dryers
Gas Dryer no longer putting out heat.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
May 14, 2010 | Whirlpool GEQ9858J Dryer
Heating element quit working on model # ler4624bw2 Whirlpool electric dryer
Hello there
Here is a couple of links that will help you replace the heating element along with some manufactures that can also help ok?
Best regardss michael
  1. Whirlpool Dryer Heating Element 279838 Kenmore | Estate ...unknown.gif ... REL4632DW0,LER6638DW0 LER4624BW2,LER7646AW2,KEYS677EZ0,REL4632DW1,LER6638DW1 ... Model: Whirlpool | Kenmore | Sears | Roper | Kitchen Aid | Estate. Shipping
  1. How to Replace Your Electric Dryer's Heating Elementunknown.gif How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid. Electric Dryer's Heating Element ... 3 styles of heating elements in use for these dryers. - Cached
  2. How to Replace the Heating Element in A Whirlpool Dishwasherunknown.gif How to article - how to replace the heating element in a whirlpool dishwasher. When your dishwasher heating element goes bad, your dishes will not dry quickly.
  3. How to Replace the Heating Element in A Whirlpool Ovenunknown.gif How to article - how to replace the heating element in a whirlpool oven. If the lower heating element in your Whirlpool oven no longer gets hot, or if you n
Oct 15, 2009 | Whirlpool Dryers
Amana Dryer model # LEA60AW. Dryer runs but no heat.
check the heating element and the high limit fuse
Jul 10, 2009 | Amana ALE643RB Electric Dryer
Amana (LE8517W2) No heat
You should inspect the filter hosing and blower assembly and replace the cycling thermostat mounted on the blower housing. Get rid of whatever is blocking your outside vent and causing the thermal overload.The dryer is getting too hot either because of a control malfunction or an air blockage. If your control thermostat is the 4 wire type (2 small 2 large wires) then it probably is bad.
I test them by using an electronic thermostat to gage the temp. It should at max not exceed 160F nor get below 100F during drying cycle. Perma press should be around 150
delicate 140.
May 16, 2009 | Dryers
The dryer is heating on air fluff.
Good Afternoon,
Is this dryer Electric or Gas?
Mar 27, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool dryer heat not working
Feb 24, 2009 | Whirlpool LER5636P Electric Dryer
Amana electric dryer model LEA30Aw will not heat
The heating element measures 10 Ohms at 68 degrees farenheit. Usually if the element is bad, it will measure infinity.
Dec 24, 2008 | Amana Dryers
Whirlpool LER5636P Electric Dryer Logo
569 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
