Question about Delstar Audio Players & Recorders
I have a delstar digital photo watch and have been unable to load pics onto it, when I plugged it into the USB and tried to use it I was asked to format the device, but then told it could not be formatted. Does anyone know how to make this thing work?
SOURCE: YP-55 Not working
i have the same exact problem what should I do?
Posted on Aug 16, 2007
smeago1
  • 136 Answers
SOURCE: Delstar DS-3512 (512 MB) MP3 Player format error
these players are notorious for this sort of problem
this site should solve ur problem
http://en.wikipedia.org/wiki/S1_MP3_Player
i recommend you upgrade the firmware.
cheers
smeags.
Posted on Dec 31, 2007
  • 189 Answers
SOURCE: digital photo frame
Some digital frames comes with built-in internal memory so you can load that with your PC via a usb connection without having any kind of removable media. If yours doesn't come with internal memory though I don't think you have any choice other than to purchase a memory card of whatever type is supported by the frame.
Posted on Jan 09, 2008
  • 8 Answers
SOURCE: Le mon MP3 Player Capacity 1 GB Plays MP3 , WMA , WMV , ASF and WAV
try this
i found a good step by step tutorial to restore the firmware in
http://www.samsung.com/mx/support/popup/howToGuidePopup.do?howto_guide_seq=78&howto_guide_step_no=1
and the software can be downloaded from
http://de.samsungplay.com/supports/download_detail.jsp
(just find "yp-t9 firmware")
Posted on Jan 15, 2008
streetlover
  • 69 Answers
SOURCE: Sansa Player - Unrecognized USB Device
alrigth it seems like you have formatted the recovery partition
if your sansa are working .. well if it´s starts then you should try
to go into recovery mode by having hold (on) and push rec button while starts the mp4 if it comes into recovery mode there then you can relese the rec button and connect the mp4 to the computer there you should see a device (15-16 mb ) in there it should be a file named : pp5022.mi4 you may try reset your sansa ( change the pp5022.mi4 file) you can download from http://chrisjs.com/PP5022.mi4
if you can´t come into reovery mode you got to do following
take it step by step and carefully read all twice before you starts:
you need to download ubuntu live cd learn more about that on www.ubuntu.com it´s is a open source os it´s free and anyone can change stuffs ect...
then burn ubuntu 7.10 to a cd or dvd
in the iso file i think after burning close the cd
and boot from the live cd with ubuntu so then when using ubuntu (you dont need to install it ) you do this :
There's four files you need to get, plus one you need to create. Copy and paste the following lines:
mkdir ~/e200t
cd ~/e200t
wget http://daniel.haxx.se/sansa/e200tool/e200tool
wget http://daniel.haxx.se/sansa/e200tool/i2c-e260.bin
wget http://daniel.haxx.se/sansa/e200/BL_SD_boardSupportSD.rom
wget http://chrisjs.com/PP5022.mi4
touch sansa.fmt
After everything finishes downloading, check the md5sum for each file:
md5sum *
That should return:
af26eb02fc3454f5264bb028107a2700 BL_SD_boardSupportSD.rom
d9f946067844e2a24fcbb6cfedb75057 PP5022.mi4
795cc4e75d38284a1460b840fc14967a e200tool
cecb257eeb64ceaae9cb20d9956a0bfc i2c-e260.bin
d41d8cd98f00b204e9800998ecf8427e sansa.fmt
If any of those lines don't match, redownload the file and check the md5sum again.
Then, make the e200tool file executable, switch to root (if you aren't already; enter password if needed), put your Sansa into Manufacturing mode, and program the i2c:
Keep in mind - there seems to be a 15 second timeout for Manu mode, so if you get a -71 error, try again.
chmod +x e200tool
sudo su
(Put sansa in Manu mode)
./e200tool init
./e200tool i2cprogram i2c-e260.bin
Also, you can use that i2c file even if you don't have an e260 - they're all the same.
I don't have a working Linux computer at the moment, but I believe at this point you need to turn your Sansa off. Hold power for 15 seconds, then go back to Manu mode.
Next, recover the bootloader to get to recovery mode:
./e200tool recover BL_SD_boardSupportSD.rom
When the display turns on, hold the REC button. If you don't get into recovery mode, try again.
Once in Recovery mode, place
i2c-e260.bin, BL_SD_boardSupportSD.rom, PP5022.mi4, and sansa.fmt
on the recovery mode drive.
Disconnect the sansa, turn off hold, and it should (hopefully) work. (chris did help me with this )
if you got any problems send a mail to skrap94@hotmail.com and write sansa e200 in top off message and try to say the problem if you got one let me know if you fix it it always fun :D
hopes this helps
Posted on Feb 16, 2008
How do I upload digital pics from my card onto the digital photo frame? Which buttons and what order?
Does your photo frame have a slot for your memory card? If so, they will work straight from the card. Otherwise you load them to your frame via a small usb cable normally. Without telling us the make andmodel of your frame we are unable to tell you about the buttons to use
Dec 03, 2011 | Cameras
Delstar player
Support URL: www.delstar.net
Support Phone Number: 954-458-7771
Support Email Address: Delstarswc@aol.com
Feb 12, 2008 | Delstar 772557 MP3 Player
The camera wont load pics onto the computer.
try plugging it into some other USB port and even try uploading the drivers of the USB!! or best is try using some other USB to test it!!
reply and rate!!
Jul 07, 2010 | Nikon COOLPIX L18 Digital Camera
Unable to transfer photos from memeory card with usb cord
uninstall fuji software from laptop. plug in data cable, pc will ask u for drivers then load it. if not then pause antivirus for while then use data cable
Jun 18, 2009 | Fuji FinePix Z10fd Digital Camera
Camera won't permit review of pictures
Hello Charlie, Hook your camera directly to your PC with the USB cable, The computer should see Kodak Easyshare, Double click on it to open and check in the folder shown for your photos and down load or delete them as you wish. As far as the SD card error it sounds like possible camera firmware problem,go to Kodak website under support for Dx7590 for the firmware and instructions.
Best Regards, Russell
May 31, 2009 | Kodak EasyShare DX7590 Digital Camera
My photos wull not upload onto the pc from my kodak easyshare camera
To up load you have to make that the Kodak easyshare ICON on your desk top is open. Then turn on your camera plug in the usb cable to your camera and to the PC . the pic will up load automatic . I hope this helps .
May 13, 2009 | Kodak Easyshare C813 Digital Camera
Delstar mp3 1 gb with voice recorder
hi!the mini disc contains the software for using the mp3 player..do install the software and then connect the mp3 player..windows has autorun functions that give u all the possible choices when u insert a disc..hope it helps!do get back for any help..will be glad to assist u!
Nov 08, 2008 | Delstar DS 31024 MP3 Player
Usb cable for delstar mp4 degital player
The cable plug is called Hirose. Specifically a mini-B 4pin Hirose, BUT-- there is a single slot as well as a double slot. You need the double.
640dab4.jpg If you find one and can't tell from the pics or description, ask the vendor.
Here are a few links though I haven't purchased myself.
http://foliumcei.com/usbadapteramaletohiroseminib4pmale.aspx 99 CENTS!!!!!!!!!!!!!!!!!!!!!!!
http://www.powersonic.ca/usb20-cable-mini-hirosemini-p-3714.html?osCsid=38c68f6d5fdb33d77b04d6c43004c103
http://www.revealcable.co.uk/acatalog/Camcorder.html
http://www.ebuyer.com/product/95792
http://www.ebuyer.com/product/95797
http://stores.channeladvisor.com/cablestar/Items/hiroseusbzz?sck=73192081&caSKU=hiroseusbzz&caTitle=USB2%204%20Pin%20HiRose%20MP3%20Digital%20Camera%20Cable%201.8m%20Lead
So I guess you lost your AC charger as well. I recently purchased a cool USB charger at Dollar Tree. They also have various cords including USB A to A extension in case you only purchase a Hirose adapter. Good luck.
Sep 01, 2008 | Delstar DS-802 Digital Media Player
Worked for some
hello,
what operating system are you using? 98se, Xp or vista?
the usb change on your camera to mass storage works good with XP & Vsta.
if selected, you wont see scanner and camera wizard ever again.
when pugging your camera into your pc, the autorun window pops up like you just plugged in a USB jump drive in.
on view file you can drag the whole folder onto your desktop from the camera and rename the folder once done.
if the photos are showing up unable to view photo, file could be corrupt.
ive seen bad memory cards do this. then try another card.
good luck.
Aug 14, 2008 | Nikon Coolpix L11 Digital Camera
Fuji Finepix Z won't load photos onto my computer
check the memory disc it might be full in which case it is best to save the pics onto your computer and then wipe the disc for room to take more pics.
Jun 25, 2008 | Fuji FinePix Z10fd Digital Camera
112 people viewed this question
Top Delstar Audio Players & Recorders Experts
steve cannon
Level 1 Expert
Mister Danger
Are you a Delstar Audio Player and Recorder Expert? Answer questions, earn points and help others
