Question about Panasonic Home Theater System System
F61 error how can ik fix the problem? Every time i want to start the player. type: panasonic sc-ht75 I hope you can help. Thanx
I Have a panasonic mdvd home theater modl#SA-HT920, WHEN I RAISE THE VOLUME IT SHUTS DOWN AND INDICATES F61 ON THE LCD SCREEN HOW CAN I SOLVE THE PROBLEM
Posted on Feb 22, 2009
MY PANASONIC SA-HT75 KEEPS ON CLICKING OFF WHEN I SWITH IT ON.WON'T START UP
There Panasonic SA-ht75 dvd Decreasing the opening treading on what's happening back immediately shuts down
Sep 05, 2011 | Panasonic SC-HT75 System
My Panasonic SA-HT75 clicks off seconds after I turn it on. Even got a F61 code.
Open the unit and clean/replace the fan.
If it doesn't turn when you power it on after cleaning it, put some oil on its bearing sleeve.
Never power on this device while speakers are not connected!
Hope this solves your problem!
Feb 23, 2011 | Panasonic SC-HT75 System
Unit displays f61 and nothing works What component is related to this
"Check and correct the speaker cord connections. Page 7
If this does not fix the problem, there is a power supply problem. Call 1-800-211-7262 for support."
http://www.retrevo.com/support/Panasonic-SC-HT75-Home-Theater-Systems-manual/id/356ci969/t/2/
It's implying you have a shorted speaker wire.
Jan 22, 2011 | Panasonic SC-HT75 System
My Panasonic SA-HT75 won't read any DVD/CD discs
The laser has failed. They all go this way. Throw it away and don't buy Panasonic next time.
Jun 09, 2010 | Panasonic SC-HT75 System
SC-HT75 home theater
This error means that the unit is in "protect" mode. An error condition was detected in the final stage of the amp and the unit has shutdown to prevent further damage. This is usually the output amp pac that needs to be replaced. Expect a parts replacement cost in the $75-$90 range.
Dan
Dec 04, 2008 | Panasonic SC-HT75 System
SC-HT75
The output amp pac has a problem. The F61 is indicating that the unit is in protect mode. This is a mode where the output section is shutdown to prevent further damage. Figure on $65-$95 for parts.
Dan
May 19, 2008 | Panasonic SCHT730 800W DVD Home System...
Panasonic home cinema model sa-ht75 . shows f61 disconnet output ic ,still shows f61
F61 error codes could either be IC501 or the regulator (IC502) in the power supply section.
For reference, pls view these two (2) posts here and here of similar concern on other models.
Other possibilities are:
1. fan not turning;
2. cold solder;
3. looses connections;
4. one of the other components/systems hooked up to the power supply is causing a fault (tuner, disc player).
Hope this be of additional help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Apr 26, 2008 | Televison & Video
Fault code
speaker cord connector problem:-
remove all speaker connectors and insert it one by one each time until you find the bad one and change its connector with a new one.
(you must play something and listen).if all above does not work you will have problem in power supply and need to fix.
Mar 24, 2008 | Panasonic SC-HT67 System
Display showing "F61" some electricity failure
you have a problem with speaker cords:-
1-make marks with tape or any marker pen in all speaker cords(left-right-sub- front-rear).
2-after marking remove all speaker cords.
3-insert them one by one until f61 appear.
4-the cord that connected and make the trouble is bad please change it with new one.
Mar 07, 2008 | Panasonic SC-HT75 System
Panasonic Home Theater System System Logo
540 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
