Question about Whirlpool 24 in. GU1200XT Built-in Dishwasher
Whirlpool Dishwasher Model GU1200XT
Does not get upper rack dishes clean. Could there be a pump gone bad in the unit ??
  • 38 Answers
Check the upper spray arm for debris plugging the spray holes, if clean then pull off lower spray arm and filter screen, and clean and remove any debris found in the sump, check the disposal blades as well. You will need a torx style screwdriver to remove the sump screen on this unit. You can buy a set for under $10 at your local hardware store.
Posted on Feb 23, 2009
Whirlpool Gold Dishwasher- bowls in center of top rack are full of water, bowls in corners have almost no or no water in them and dishes on top rack are dirty. Dishes on bottom rack are clean.
First try running a cycle of "Dishwasher Magic". You can find this at Walmart for around 5 bucks. This will clean and condition the inside of the dishwasher and the inside of the pump and motor.
If this doesnt help...and the plastic and/or metal components in the dishwasher seem to look and feel intact..this would lead me to believe there is an issue with the pump and motor. These are sold as 1 unit or as seperate units depending on the model. Changing it is simple if you know how to dissconnect and reconnect a dishwasher. Take into consideration the age of the unit, the cost of the part, and the cost of a total replacement.
Oct 29, 2013 | Dishwashers
My Whirlpool Quiet Partner II does not clean the upper rack of dishes properly. They are greasy. I have checked the top spray arm for blockages. There were none. I am fairly certain that water is
Make sure the center loading is not obstructing the water jet to the top shelf. Top shelf is only for glasses and saucers , use Jet-Dry .Pre rinse and clean bottom pan strainer from dirt debris.
May 14, 2012 | Whirlpool GU2400XTP Built-in Dishwasher
Dishes in my Whirlpool Dishwasher is not cleaning dishes in the upper rack. It is also leaving a white film on the dishes.
Hello Mike,
What ya want to try is to clean the filter screen on the wash pump and see if that helps to circulate water better resulting in better washability.
This video will show ya how to take apart and clean the wash motor/pump area
Oct 29, 2011 | Dishwashers
Dishwasher leaves upper rack dishes dirty. It's Whirlpool Quiet Partner II
Your water pressure is not high enough in the dishwasher to wash the dishes on the top rack. The most common reason is that the pump in your dishwasher cannot pump fast enough to keep the water pressure up. That is because the shaft that drives the pump impeller also drives the macerator cutter that grinds up bits of food fine enough for it to pass through the screen and out to the drain. Over time, small bits of bone, broken glass, eggshell, and other items that are too strong to be cut up by the cutter end up sitting in the area where it has to spin, and they prevent it from spinning fast enough to pump enough water to the top rack with any pressure. It is simple enough to repair. You need to take out the racks, remove the bottom arm and clean out the little macerator. Once that is done, it should work great again.
Feb 22, 2011 | Whirlpool 24 in. DU900PCD Built-in...
I have a whirlpool gold dishwasher model Quiet Partner 3. The top rack is not cleaning the dishes very well. We live in the country and have hard water. I am wondering if there could be a buildup of some...
if it is just affecting the upper rack i doubt it is just a plugged spray arm (though i could be wrong). more likely than not you have a blockage on the intake of your spray pump motor. a series of bones, toothpicks, foreign material, etc could be blocking the entrance of the pump causing it to starve for water so to speak.
you will more than likely need to remove the lower rack and spray arm to be able to disassemble the strainer and gain access to the sump.
a complete model number would help bunches to.. alas
May 20, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Water level low. dishes having pasta debris left on, which should be easily washed off. dishes on center lower rack, upper rack corners are not clean.
sounds like a bad circulation pump. but this is how you check. once the water start to circulate and the unit is wahing open the door and see if you have a steady water droplets at the very top evenly. if you dont 9times out of ten pump is 50 to 75 % gone and the unit is not washing properly. let me know if i was of some helpto you.
Feb 26, 2010 | Dishwashers
Whirpool dishwasher does not go into wash cycle
you will need to replace the control bd. if it is not washing. I think that it is probably just filling and not starting the washing process and this would be a bad sump/mtr. assy.
Apr 03, 2009 | Whirlpool 24 in. GU1200XT Built-in...
Whirlpool GU3200XTP dishwasher - No spray on upper rack
Sounds like the hose assembly that attaches to the rear of the upper rack has come undone. just pull out the upper rack and reconnect it.
please rate my answer as a fixya! thanks.
Feb 14, 2009 | Whirlpool 24 in. GU3200XTP Built-in...
Whirlpool built-in dishwasher - has sprayer for lower and upper racks. Have had to have repairman out to clean out dishwasher as residue blocks water from getting to upper rack - is there any way to do...
Yes, you will need to purchase a set of torx style screw drivers at your local hardware store. Remove the upper and lower spray arms and clean the debris out of the spray holes. Remove the screws that hold the filter in place and remove the gunk out of the sump. In the future stop using gels or gelpacks, just use electrasol powder or cascade powder. The gels and gelpacks clog up dishwashers like you would not believe. Run some Lemi-shine through the machine on a monthly basis, Lemi-shine is available at most walmarts.
Jan 15, 2009 | Whirlpool 24 in. GU1200XT Built-in...
Dishwasher Not Heating!!
Using a multi-meter check for continuity on the heating element, if element is good then check for continuity on the door switch, if this also checks out good then the heater relay located on the control board is likely gone, replace control board.
Jan 08, 2009 | Whirlpool 24 in. GU1200XT Built-in...
Whirlpool 24 in. GU1200XT Built-in Dishwasher Logo
288 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
