Question about Water Heaters
Pilot light on boiler
Our boiler is an Ariston combi.
Model DIA 20/24 MFFI CE.
The pilot light wont ignite the gas two times running. There is a button underneath that has to be pressed and held. We have had a corgi plumber look at it, then says its ok now - charges us, then it happens again
  • billtaylor60 Feb 26, 2009
    Thanks.
    I will try to do these jobs myself. If not I will get a different plumber.
    Novelist:
  • 152 Answers
The plumbers repair should be guaranteed, give him a call back.
It sounds to me that the pilot flame needs to be adjusted or the thermocouple is not aligned properly or there is a draft that is blowing out the pilot.
Good luck...
Posted on Feb 23, 2009
Ariston euro-combi boiler not giving hot water
odd noise like popping or singeing fire....clicking noises.....sounds like you have a water leak putting out the pilot.......or your thermo coupling is bad....or the noise is the tank full of calcium buildup and that will make noises when the burner is on
Jan 19, 2013 | Water Heaters
I have an ariston 20/24 mffi combi pressure rises when switched to central heating but pressure ok when asking for hot water ? expansion vessel ?
over heat limit stat on central heating circuit ? if hot water is ok and hot to temp when run for 5 minutes the expansion vessel is doing its job.remember hot water is the maximum demand for any boiler ,,heating is secondry?once you establish hot water at maximum rate then the only real problem is on you demand for heating??
Dec 10, 2012 | Water Heaters
I've got a Alpha 240 e combi boiler..... Everything seems to be wor,kin ok but it won't start the ignition sequence .
could be air presure switch which tells pcb that fan is working and would then bring inn ignition system then main gas valve.Would suggest getting gas engineer in.pommie engineer
May 26, 2012 | Water Heaters
Combi boiler (vailant), pilot light not igniting; boiler firing etc o.k
hi there
does the fan start up?
sounds like a faulty gas valve. has there been an interuption in your gas supplie?
hope this steers you in the right direction
Dec 19, 2010 | Water Heaters
Got a ravenheat ls 1oot combi boiler not working red light on timer on not making any noise works every now and then for short periods
I have a ravenheat 820/20(t) boiler and the pilot will not say alight, I have 20mV from the thermocouple(through the safety switch) and its had a new gas valve fitted(good earth continuity).The heating system is holding pressure at 1.2 bar.
Has anyone got any ideas what could be holding the pilot 'OFF'.
I CANNOT SEE ANYTHING ELSE IN THE PILOT CIRCUIT.
PLEASE HELP !
Dec 20, 2009 | Water Heaters
Ariston ACO MFFI 35 E34 fault code present
This is the manual for your boiler. I hope the information contained in the manual will help you identify your problem.
http://www.ariston.co.uk/uploads/doc47e92b04013d8.pdf
Mar 30, 2009 | Water Heaters
Ariston A01 fault combi boiler
its not definately the pcb. change the detection sensor first( £3.20p). if this doesnt fix a01 fault then change the main pcb(£145).
Oct 29, 2008 | Water Heaters
Water Heaters Logo
539 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
