Question about Intermatic EI210 Electronic Auto Shutoff Timers
How do i hook up a 4 wire timer switch (R G B W) to a three wire box(G B W)? this is for a intermatic EI210
jeltey
  • 44 Answers
SOURCE: ei210 in wall countdown timer in undocumented ''test mode''?
You could try disconnecting power to the switch for a few minutes maybe that will reset it. Other than that I would say cut your losses and replace it. Hope this helps a little.
Posted on Dec 04, 2008
  • 10865 Answers
SOURCE: How to wire a EJ500C timer?
Hi. go to http://www.intermatic.com/images/misc/158ej12685ref.pdf for complete instructions. good luck.
Posted on Jan 21, 2009
  • 243 Answers
SOURCE: Bought a Intermatic sprinkler timer. need help.
reading the specs i should say its a timer for only one zone. you can use it for one zone switching or for the pump. sorry.
Posted on Feb 14, 2010
  • 351 Answers
SOURCE: Trying to replace Intermatic with Utilitech inwall
The wires on your new switch are intended for black = power .. white = neutral . and red = lights .. with two black wires on the old switch I am assuming that there is a bundle of white wires in that wall box, the white timer needs to join that bundle ... then you need to determine which black wire is the power from the electrical panel ( voltage tester) and connect to the black timer wire .. the red timer wire connects to the other black wire in the wall..
Please Vote !!
Posted on May 13, 2010
SOURCE: Utilitech Wall Timer #0192773 does not switch
Old timer: Intermatic EJ500 & ST01C timers have a battery. Battery operates the clock motor. Red wire is for 3-way circuit [a hallway with 2 switches is a 3-way circuit].
Utilitec timer, clock runs on 120Volt circuit instead of battery. So clock has to have power.
How to connect wires:
Black timer wire connects to hot wire from breaker box.
Red (or blue) timer wire goes to landscape lights.
White timer wire connects to white neutral wire [or if no neutral is available, connect to bare ground wire].
Green timer wire goes to bare ground wire.
How to find black hot wire and white neutral wire inside box
: Disconnect and separate wires so you can test. Use ordinary tester. Power is on. There is only 1 black hot wire inside each electrical box. Test each black wire to bare ground until tester light comes on > that identifies the black hot wire. Next, test black hot wire to white wires until tester light comes on > that is the neutral wire. Exception: This test does not necessarily work with 3-way switches since they reverse each time switch is thrown.
Posted on Sep 21, 2010
I have a 3 gang box: a is for hall light switch
Timer is not identified. Battery-operate timers wire differently than timers that require neutral wire.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
For 4-wire battery-operated Intermatic EJ500, ST01C, and Ei600, Ei400 wiring:
http://waterheatertimer.org/ST01C-program.html#ST01C
For 4-wire Intermatic Ei200 series, KM-series, Ei500 that require neutral wire
http://waterheatertimer.org/Programmable.html#wire
Add a comment with model number for more specific information
Jun 19, 2011 | RTO Intermatic Digital 7 Day Wall Switch...
I have tried to install the Utilitech timer but am having trouble. I have a ground, black, and red wire that were previously wired to a switch that controlled my outdoor garage lights. I tried to hook red...
Sounds like this was probably a three-way switch you are replacing as there is no neutral (white) wire in the box. If so, you can splice the white wire to the green wire in other three-way switch box; then hook the green wire in the box you are placing the timer to the white wire of the Utilitech timer.
Apr 17, 2011 | Intermatic & Self-Adjusting Wall Switch...
I have two of these switches and they both are operating incorrectly. I use them to control bathroom fans in two separate bathrooms, but they both act the same. That is, when I push one of the time...
Leviton countdown timers have additional wire that powers internal electronics.
Leviton timers have red-black-white-green wires (or blue-black-white-green wires)
1) Regular single pole switch has 2 insulated wires. One of these wires is Hot from breaker, and the other goes to Load (fan)
2) Timer green wire connects to bare ground as you know.
3) Hot from breaker connects to timer black wire.
4) Load wire connects to timer red (or blue) wire.
5) Located in back of box are white wires that are twisted together and covered with wire nut.
These are Neutral wires. Connect timer white to these wires. This will power timer electronics.
6) If box does not have Neutral wires described above, then connect timer white to bare ground along with timer green wire.
7) Turn power ON and try timer countdown.
If timer does not work, then reverse timer red and timer black wire.
8) If box does not have neutral wires: Image on link below shows similar Intermatic timer:
Image applies ONLY when Neutral is not available.
http://waterheatertimer.org/images/EI210-wiring-full.jpg
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 25, 2011 | Leviton 6230M Decora Four Preset...
HOW DO I CONNECT TO POWER SUPPLY? WHERE DO THE WIRES GO?
You posted under Intermatic EI210 countdown timer.
To confirm this is your product, open link below:
http://www.amazon.com/Intermatic-EI210-Electronic-Countdown-Minutes/dp/B001EE1J74
Manual with operation instructions appear on link below
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/ei220w%20-%20english.ashx
EI210 replaces single-pole switch only.
Single pole switch is where 1 switch controls the Load (light, fan, motor)
To wire this timer:
1) Single-pole switch has 2 insulated wires and 1 bare ground wire.
2) Connect insulated switch wires to timer red wire and timer black wire, in either order for now.
3) Connect timer green wire to bare ground wire.
4) In back of electric box are white wire that are twisted together and covered with wire nut. Connect timer white wire to these wires. This will power electronics located inside the timer.
5) If electric box does not have white wires described above, then connect timer white wire to bare ground wire along with green wire.
6) Turn power ON. Press oval button. If indicator light turns ON, then timer is wired correctly. If indicator light does not come on, then reverse timer black wire and timer red wire.
http://waterheatertimer.org/How-to-put-on-wire-nut.html
Add a comment if you need more free help.
For a price, fixya expert gives you same instructions shown above via phone while you connect the device.
Dec 30, 2010 | Intermatic EI210 Electronic Auto Shutoff...
How to hook up a auto shut off timer
When you take off the old switch you will have two wires going to it. One is a hot and the other is a switchleg. On your timer you have a red wire which connects to the wire going to your light(switch leg) a black which connects to the hot feed and a white which will connect to the neutral in the box. (If you do not have a neutral this timer will not work) The neutrals will be white wires that are connected together with a wirenut and pushed in the rear of the box.
Oct 01, 2010 | Intermatic EI210 Electronic Auto Shutoff...
Generally your hook up is like this.
G - Ground - Green or bare wire
B - Hot - Black wire
W - Neutral - White wire
R - Switched - Hot when on
On your three wire
B - Hot - Black wire - hook to switch wire from switch
you should also check: http://www.intermatic.com
Jun 04, 2010 | Intermatic EI210 Electronic Auto Shutoff...
Bought an intermatic model EI600 wall switch timer to use with gfl outsidelights. black green, blue and red wires from the back. Went black to black, green to ground, red tored and blue to white in...
That is a three way timer. There is no wire that the white wire gets hooked to. The black is the hot, the blue sends power to the device, and the red goes to a switch that connects it to the blue wire essentially. Here is a PDF of the directions, including wiring diagrams.
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/ei600c%20-%20english.ashx
Mar 06, 2010 | Intermatic EI600WC - In-Wall Decorator...
Wiring the timer
green wire=ground
black wire=hot
white wire=neutral
blue=switch
May 22, 2009 | Intermatic EI210 Electronic Auto Shutoff...
Problem with wiring diagrams for EI210
Sounds like you don't have a Neutral wire in the box, timer requires Neutral.
How to wire that timer appears on following link:
http://waterheatertimer.org/How-to-wire-timers.html
Or install a spring-wound mechanical countdown timer:
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html#FF
Sep 03, 2017 | Intermatic EI210 Electronic Auto Shutoff...
Ei210 in wall countdown timer in undocumented ''test mode''?
Nov 12, 2008 | Intermatic EI210 Electronic Auto Shutoff...
Intermatic EI210 Electronic Auto Shutoff Timers Logo
726 people viewed this question
Top Intermatic Hardware & Accessories Experts
Gene Haynes
Jay Finke
Jay Finke
Steve
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
