Question about Singer Quantum 7322 De'cor Mechanical Sewing Machine
Janome 11000:bobbin thread appears on top, filling the design
The top thread catches the bobbin thread, but has no tension, so the bobbin thread fills in the satin stitches, zigzags, etc. You can't even see the color for all the white bobbin thread. I've cleaned everything completely and retreaded countless times. I've tried adjusting the top tension up and down to no avail. I tried regular straight stitching and the top thread just lays on top, feeding out only because the feed dogs move the fabric. The threads are "caught" like they should be, but not with the right tension.
  • 323 Answers
SOURCE: Desgin stitch out on Futura 250
It sounds as though the design is stitching but the machine is skipping stitches. If this is the case, be sure you hoop the tear away in the hoop with your fabric.Make sure the fabric is taut. Use a new needle and a good quality thread.If this doesn't solve your problem, try the design on a different type of fabric.
Posted on May 30, 2008
  • 208 Answers
SOURCE: singer machine needle won't do width in zigzag
It sounds like it needs lubrication on the needle bar frame and linkage.
Posted on Oct 01, 2009
SOURCE: singer 2662 only does a straight stitch
got the same problem - wish I could help you -
Posted on Jan 13, 2010
SOURCE: PFAFF 362 Sewing Machine: The shift
I just fixed this on my pfaff 230-the problem is the needle position dial-the middle dial with the chrome lever on the right-has froze up .
remove the dial-it doesn't come off by the screwhead in the middle of the dial ,the screw you need to loosen is the one under the wider end of the part of the dial you hold-you will need a glasses screwdriver.
once it is off ,heat the exposed shaft with a heat gun while turning the shaft back and forth with pauses for dripping 3 in 1 oil on the shaft so the heat melts the hardened grease and draws the 3 in1 in to flush out the old grease and lube the shaft.
eventually you will be able to turn the shaft easily-then when it cools off replace the plastic dial.make sure your upper dial is on "0" there is a cam on it that will push down the other end of the chrome lever.
This will work-there is no plastic in the shaft and arm assembly to melt and you don't have to dissasemble from the top-that sucks.
Posted on Feb 04, 2010
  • 1116 Answers
SOURCE: I have a 7466 Singer sewing machine. No matter how
Make sure to thread the machine with the presser foot up to insure the thread is seated into the tension control.
Always free-motion with the presser foot down.
Try a lower setting on the tension.
Posted on Mar 29, 2010
My bobbin keeps bogging up on my janome 11000 what could the problem be. I have taken apart and cleaned the whole bobbin area.
Try a different bobbin with different thread. You can also rethread the top thread from the beginning. Be sure the presser foot is always raised when threading! If that doesn't change anything, then you may need to take it for service.
Aug 14, 2017 | Janome Sewing Machines
The thread is not catching properly underneath
Try resetting the bobbin. Also check if bobbin is over-wound. Open hatch and watch to see what is going on down there. See if threads are wound around base of bobbin.
Jul 28, 2014 | Janome Harmony 2039 Mechanical Sewing...
Bobbin thread tension issues
There might be a piece of thread or lint caught in the bobbin tension preventing it from functioning correctly.
Feb 24, 2010 | Janome L-344 Mechanical Sewing Machine
Bobbin is not filling. It barely turns.
This happened on my Janome had to be repaired in a shop.
Jun 07, 2009 | Janome Memory Craft 5700
Breaking Thread
Use a bigger spool stopper to keep the thread from catching in the **** on the thread spool.
Dec 22, 2008 | Husqvarna Viking 1
Bobbin winder has no tension
are you sure you have the thread over the right place? it should be from the spool to the small metal wheel on the top of the machine and nothing else, also make sure your using a janome or s-class bobbin ( also it should be a plastic bobbin if it loads from the top of the machine and not the front ) when i fill a bobbin i also start out slow sometimes keeping my finger loosley on the thread itself before it winds on the bobbin to give it more stability.
Sep 23, 2008 | Janome 8080 Computerized Sewing Machine
Won't stitch properly
ever tried adjusting the thread tension control? clean if possible
tighen it more, loose tension adjustment causes loose stitch and tangling of the thread.
Jun 25, 2008 | Janome D'cor Excel 5018
Mc 5700 problem
You don't have much info here to go on. I take it that it embroiders fine otherwise, ie on the built in designs. Is it a Janome card? Does it do it on a particular card / design? Have you changed the bobbin thread that you use? Check the top tension - even though it is 'automatic', it does require adjustment at times. Have you changed / using stabiliser that you use? Is the bobbin correctly threaded?
Check these things
Oct 21, 2007 | Janome Memory Craft 5700
Singer Quantum 7322 De'cor Mechanical Sewing Machine Logo
104 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
