Question about D-Link DI 514 Wireless Router (DI-514)
My D-Link DI-514 wireless router doesn't light up
My D-Link DI-514 wireless router doesn't even light up anymore when I plug it in.. The router's status light would fail and I would lose connectivity. I'd restart the router and it would work for a minute or so before the status light (only) fails and I'd lose connectivity. NOW, when I go to plug it back in, none of the lights light up (power light, WAN ...). I've tried reseting the unit, to no avail. Is my wireless router DOA?
  • 33 Answers
Sounds like you have a bad power supply. In my personal experiences with bad routers they either don't light up at all or all the lights blink. It doesn't take much to send one to the router graveyard. Power surges and lightning strikes are the most common culprits. Hope this helps
Posted on May 22, 2009
  • 1342 Answers
SOURCE: D-Link DI-514 router not working after power outage
To reset your router, use the following steps:
  1. Press the reset button for 10 seconds. You can use a small object, such as a paper clip to hold down the button.
  2. Do not power off the unit while the router is being reset.
    The unit should now reboot, and once the WLAN light stops blinking the router should be reset.
  3. Open up your Web browser and enter in the address bar.
  4. For the login, enter admin as the ID and leave the password blank.
The router has now been reset.
Posted on Apr 22, 2008
SOURCE: lost cd to d-link model DI-514
It's a B:1
Posted on May 30, 2008
SOURCE: AT & T Hook up to D-Link
If those lights are lit, they often have a "Code" this code is in the manual. Please find below a link for the manual I am sure all will be found in it. Oh & I am sure ya can connect another WiFi'ed PC no prob's.
Posted on Sep 15, 2007
  • 787 Answers
SOURCE: D-link DI-514
The information he gave you was correct for a new DI-514 but if this has already been used it could be that the password was set. To take care of this problem, you can return the router to factory default settings by inserting a paper clip into the reset hole at the back (leave the router plugged in and turned on), hold it for ten seconds and then release. The router should reboot. Try the 192 and admin again.
Posted on Oct 17, 2008
  • 25 Answers
Try that link it shoulkd get you going
Posted on Jan 03, 2009
My wireless router doesn't work!
Your ADSL or Internet should be turned on, if not, you may pay your ISP bill, or your ISP didn't give you Internet access.
Jul 23, 2010 | D-Link DI 514 Wireless Router (DI-514)
No lights on D-link DI 524
try to use it with other electric socket .if lights stil doesnt appear ,then iit could be problem with the adapter on dlink router..otherwise your router has gone bad ..if it is in warranty period go for the free replacement..
May 29, 2010 | D-Link DI 514 Wireless Router (DI-514)
The STATUS led on my D-Link DI 524 wireless router
reset you router on factory set and then you can see the satus of lights.
Apr 04, 2010 | D-Link DI 514 Wireless Router (DI-514)
My d link DI 514 router will not turn on when i plug it in. Is it permantly broken
Try using a different power cord. If that doesn't work, then the answer is "YES".
Feb 13, 2010 | D-Link DI 514 Wireless Router (DI-514)
Connection and wireless network with DI-514 disappeared
there is a very small reset button on the unit. Press it and hold it for 5 seconds. This will reset it to the factory specs. Then proceed to set it up like you did when you got it new.
May 27, 2009 | D-Link DI 514 Wireless Router (DI-514)
When connected to the wall outlet no lights are on
It could be just the power adapter problem. Try to plug it to a different outlet first. If the same problem persists, you can claim your warranty because it might that the router's power adapter is defective. The worst thing is your router is the one that is defective. If you just bought it, go back to the store where you bought it and replace it with new one
Apr 18, 2009 | D-Link DI 514 Wireless Router (DI-514)
Want to use Dlink DI-514 with Qwest modem to hardwire 2 computers
Believe it or not, Actiontec modems from Qwest are setup as a router already (even though ports are missing from it). You should use a switch instead of another router. Otherwise you will have to configure the DI-514 to act as a switch rather than a router. This is done by assigning a new starting IP address into your DI-514. By default both routers use as the default. You will have to plug the DI-514 seperately into a computer (to take it off the network) and assign a new starting IP address for the DI-514 such as for example. Then you will be able to get it work. I would strongly recommend using a switch instead and turn the wireless on the modem itself (this is why the modem is the router). It will save you some headaches if the power goes out.
Feb 04, 2009 | D-Link Dlink DI-514 Air Wireless 2.4 GHz...
D-LINK DI-514 LAN Ports not working
  1. Connect a cable from your PC to one of the four plugs. Not the WAN port.
  2. Setup the wireless the way you want it.
  3. Then give this router a different IP, like
  4. Then you have to disable the DHCP server in the router (keep in mind now you have to set your desktop or laptop that is conencted to it to a static IP to still communicate with the router)
  5. Once this is done just plug you existing network into one of the four ports. Not the WAN port.
  6. It will now act as a wirelessa access point.
Althoug this is doable it is not recommended as this router is a pile of **** and the wireless is crappy.
I would suggest a dedicated wireless access point.
Dec 06, 2008 | D-Link DI 514 Wireless Router (DI-514)
Current dlink basic want to use dling DI 514
If you want to use your former router, you just have to connect the previous router in between your modem and computer. Try turning off all the devices (modem, router and computer) for 2 minutes. Then turn on the modem first, wait for the lights to be stable then turn on the router. When the router lights are okay that is the time that you can turn on the computer and check the internet connection.
If the Internet connection still has not come back, you will have to reconfigure it for Comcast connection. You can try using the setup CD or access the setup wizard using User name is admin and leave the password empty then run the wizard.
May 05, 2008 | D-Link DI 514 Wireless Router (DI-514)
DI 514 Wireless Router Problem
you upgrade new version firmware in your wireless router
Apr 02, 2008 | D-Link DI 514 Wireless Router (DI-514)
D-Link DI 514 Wireless Router (DI-514) Logo
741 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
