Question about Coleman Powermate Premium Plus 6250W Portable Generator
Generator runs does't put out electricety
Generator was bought new 2/27/07 and was used three times of a total of 12 hours at the most. I also start it every month for 10 minutes. This time I started and have no electricety. It is stored in a garage.
  • 169 Answers
Sounds like the brushes may have gotten fouled.
Here is a link to a general no output solution I posted a while ago.
Regards,
Carl
Posted on Feb 23, 2009
I have a 12 station Orbit Model #57900and I want to water the same stations two to three times a day
Program modes
Program A or 1 is your primary program setting. All Zones will run on this program.
Select program B. Or 2
Set start time for program B usually an hour or two after the LAST zone (12) run time on program A or 1
1. set selected run time for the zones you want to run. 5 min -20 min ( leave the others 00:00 or off)
Select program C or 3
And repeat above.
Keep track of the start times of each program as 12 zones running for 10 min will add up to 120 min or 2 hours total. So if Program A/1 starts at 6am it will finish at 8 am. Set program B/2 start time at 11am. Them select the specific area/zone you want to run again will water the area a second time. Just remember to leave the other areas you don't want to water Set at 00:00 or off. Repeat through all the programs and you off to enjoy your day. Cheers
Jun 06, 2016 | Orbit Hardware & Accessories
Honda generator starts, runs, then stalls and backfires
Honda makes quite good gasoline motors. I doubt it is a valve timing issue but it might be a burned valve or a valve adjustment issue. What does after a while mean? A couple of minutes or 4 hours? Is it running for just a short while and then stops or it runs well for a long time and then stops?
Aug 01, 2012 | Honda Generator Eb4000x Eb5000x Eb6500x...
Kholer power systems generators 18RESL auto shut down code UU
UU is generator under voltage. Check to see if it does it without laod also. if it does you will need a pro to check and ohm the rotor and stator for shorts
Jul 11, 2012 | Kohler Electrical Supplies
Kohler 12 RES - Unit fails to start occasionally. Attempting a manual start by placing switch in run position, cause a loud click, but no cranking. The panel says CC. This morning I put a jump start...
I finally solved the intermittant starting problem on my Kohler 12 RES by replacing the strater and the starter relay. I was also experiencing the occassional OC indication, red blinking LEDs on the ATS, and intermittent non-starts during the weekly exercises. The problem happened during power outages a couple times also. If I flipped the start switch between auto and run quickly the generator would occasionally start. Once started, the generator runs fine. I ordered a new starter, which included the starter solenoid. By the way, don't worry about the genuine part thing..the old starter was a Delco made overseas. I ordered a new starter online for $85 (6744N) and it was indentical to the genuine Kohler starter. Replaced the starter and it improved the problem but did not totally solve the intermittent starting. Ordered the starter relay (GM49746) replaced it and the problem is solved.
May 09, 2012 | Kohler 12 kW Emergency Power System -...
New generator bought on 2008 used for the first time 10/11, ran for about an hour and a half and stopped out putting any wattage, engine runs great...
This could be anything from a blown fuse to a shorted circuit. My best recommendation would be to have an electrician look at the generator.
Nov 10, 2011 | Electrical Supplies
I am installinga 4548 inverter. At 4500 watts, it puts out approximately 20 amp per phase. My generater that will feed the charging current for the batteries will put outapproximately 28 amps. Is the...
Let just wait a minute. You have an inverter that is rated at 4500 watts. This spooky. The inverter has a three phase input/three phase output? What is the inverter going to be used for?
Next question. What type of batteries are you using and what is the voltage/current in series or parallel? What will be the total voltage you will producing with the batteries? What is the total current of the batteries.
Another question? What is the voltage of the 28 amps? If it going to dump 28 amps across some batteries that rated at 12 volts and 1400 amp/hrs. For 12 volt batteries with a total of 1400 amps. What you will need approx 14 to 14 1/2 DC and with 28 amps across the batteries for charging these batteries. The batteries will be gone in about 1 hour. Boil all the water out of them. When a battery starts to boil it release water with hydrogen gas (the gas is very explosive and dangerous).
You also don't have a regulation circuit to limit the amount of current depending on the needs of the batteries. Also, you don't have a trickle charger to keep the batteries fully charge when the batteries are idle.
You will also need DC regulated charger that will keep the voltage 2-4 volts above you battery voltage. Without this voltage above the batteries voltage it will not charge those batters. Batteries need to forced to except a charge that why voltage above the source voltage. If you can check the voltage on your car/truck with a 12 volt system. While engine is running the voltage across the battery will be 13.8 to 14.1 volts. Now, the current limiter is the alternator it has a regulator built into it for stabiizing voltage and current went the batteries require more current but it limited by alternator regulator
Now, to get more current out of the alternator the regulator will supply dc voltage to the stator of the alternator generator more current. More dc voltage is supplied by the regulator but the dc voltages is limit to about 24 volts. Another limiting factor is the alternator copper windings diameter---larger diameter more current, small diameter less current. Utilities systems use big mega watts generators. The maxi um dc voltage for these three phase generator would like 500 to 800dc volts for peak to peak output. There is a simpler way of doing this.
You need to rethink everything here. Also, I can help you if you supply the needed information.
I truly wish you luck in your electrical endeavors. GB you. stewbison
Aug 22, 2011 | Refrigerators
We are going to lose power at 12 am tonight and my husband has sizures and we need generator so we bought one but cannot find manual how long will it run? we bought at menards
I really depends on the size of the generator. 1 gallon of gas should last close to an hour, the tank should hold about 3-4 gallons so I would say atleast 3-4 hours but keep a check on the level as you never know when leaks occur, or how much gas it sucks up. Good Luck
Oct 09, 2010 | McCulloch Garden
Charging failure on a 1987 fz600
The generator will produce ac voltage not dc so the meter needs to read ac voltage. the readings need to be taken between the three wires using two at a time until all combinations have been tried. readings should all be the same. Engine will have to be run at about 5000rpm while readings are obtained. Other possible problem could be the regulator / rectifier unit breaking down when hot.
Aug 08, 2009 | 1986 Yamaha FZ 600
I have a coleman 6250 model pma525302 with no electricety
You probably have a problem in the field circuit of the generator, look here to see a general purpose solution I posted some time ago.
Carl
Mar 03, 2009 | Coleman Powermate Premium Plus 6250W...
Coleman Powermate Premium Plus 6250W Portable Generator Logo
203 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Phil Walker
Phil Walker
Tim Garcia
Tim Garcia
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
