Question about Kenmore 63942 Dryer
KENMORE DRYER MODEL #110.847424 DOES NOT HEAT.
Runs fine, timer works. It is not the breaker. Electric dryer.
  • 686 Answers
Need new heat element
Posted on Mar 01, 2009
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
Kenmore dryer 11062062100
If a dryer is not heating - and it is electric, then the first thing to check are the breakers. It runs on a double breaker and half of the breaker may be good (allowing for other functions other than heat). Half breaker will run motor and timer but the element needs both breakers (220v). If that is not the issue, then element may need to be inspected.
Apr 11, 2014 | Dryers
Dryer does not heat up
Unplug the dryer. Look for blockage.4b24ab7.jpgIf you have air restrictions your heater element might be OK. 142c967.jpga4caa20.jpgIf all these components check good and you still don't have heat you might have a timer problem or an electrical problem. The timer has a leg going directly to the heater element. The load is high and overtime the contacts inside that timer get burntc97b4dc.jpgAnother thing it could be it the breaker. The motor runs on 120 volts. The heater however runs on 240 volts. If the breaker is worn on the heat load side then the dryer will work but their will be no heat.7e5d468.jpgIf it turns out to be a limit instead of the heater element then clean out the dryerd60b014.jpg8006b2f.jpgb57aa0b.jpg0fe9a0b.jpg3aea907.jpg2b993f6.jpgService manual for kenmore
More Here
Aug 04, 2010 | Kenmore 64742 Electric Dryer
Dryer will not come on at all. working fine on last load
check house fuse/circuit breaker
door switch
if an electric dryer the thermal fuse as they are often wired into the motor run circuit
check for power to the motor in start and run circuit, if present motors spent.
if not present trace back to timer and verify timer is sending power, if not timers spent.
more likely circuit breaker, door switch or thermal fuse if electric dryer..
hope this helps,
best of luck,
ttfn
Oct 27, 2009 | Kenmore 64902 Electric Dryer
Dryer tumbles but not heat
here is the link for the wiring diagram... heat is definatly on a separate circuit.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5174194
May 25, 2009 | Maytag MDE308DAYW Electric Dryer
Dryer working but no heat
The manual says that two circuit breakers used,and that the dryer
can spin but no heat if one of them tripped, check your panel and see
if any breakers are tripped. If this was the problem,have an electrician
check the circuit.
Apr 09, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Dryer does not heat
Q - My electric dryer runs but will not heat, what could stop my dryer from heating?
A - Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Mar 07, 2009 | Kenmore Dryers
Kenmore 110.64732400 Electric Dryer No Heat - Won't Shut Off
The stepper motor in those timers are prone to giving favorable readings when checked and go back to acting fruity when left to themselves. It's a sticking problem. Try taking the back off the control timer, usually you bend some tangs that hold it on straight, being careful not to overstress them and check the contact points. If they are burnt even slightly then take a file or emory cloth to them, making sure you keep them straight, don't round the corners. Then put the switch back on the head housing without the back on and plug back in. DO NOT TOUCH BACK OF TIMER WHILE PLUGGED IN. Run it through a cycle and see if the motor binds up. It may take a couple of times for it to do it if it's going to. If this doesn't work, then get back to me.
Jan 27, 2008 | Kenmore 64732 Electric Dryer
Kenmore 63942 Dryer Logo
50 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
