Question about Porter Cable 361 3" x 24" Belt Sander
I need a switch for my Porter Cable Heavy Duty Belt sander model 361. PLEASE HELP ME LOCATE A SWITCH.
  • 2,176 Answers
You didn't specify what type but I looked at a type 7 or so and the switch number is 697452 and list is 14.00. You should be able to buy that online or I would suggest if you have an electrical supply house in your area taking that one and matching it up, there is nothing special about it other than size, BUT make sure that they get one for the proper amp draw which is listed on switch. Let me know if I can help further
Posted on Feb 23, 2009
2 Suggested Answers
SOURCE: I need a switch for my Porter Cable Heavy Duty
image.gifpower cord stuck in rear wheel of power sander
Posted on Jun 16, 2009
Please help me find a free owners manual for my porter cable 352vs belt sander
The ServiceNet site has the manual for most Porter Cable power tools here: http://servicenet.portercable.com/ . The 352VS documentation is here: http://servicenet.portercable.com/Products/Detail/352VS . Look in the right hand column for the Instruction Manual; you'll see an option to download a PDF or have the manual sent by email. However, you need to look at the sander and attempt to find the Type number. This will be on the label with the model and serial number. There are 7 different belt sanders that were released with the 352VS model number. Use this number to get the details for your sander. The direct link to the manual for the Type 1 version, today, is http://servicenet.portercable.com/Products/GetDocument?docName=EnA00111.pdf&productId=55856&productType=12187&documentId=32863&translatedFileName=http://documents.dewalt.com/documents/English/Instruction%20Manual/Porter-Cable/EnA00111.pdf .
I hope this helps.
Nov 20, 2015 | Sander Tools & Hardware - Others
I have a Porter Cable 2'' A-2 belt sander and need
you can buy that gear from ereplacementparts.com you will need the type number off the tool to make sure you order the right one, they cost around 25.28 and for a type 2 the number is D839309
Sep 10, 2011 | Porter Cable 363 4" X 24" Belt Sander
Have a porter cable 3x21 belt sander and the sand paper keep rolling off the wheels
on the front wheel , there is a screw that you can adjust ,, that will adjust the tracking of the front wheel, the rear wheel is stationary , once you have the new belt on, locate that screw,, and just click the switch as you adjust it,, once adjusted, you will see that it tracks straight and won't fall off
Aug 26, 2011 | Porter Cable Garden
Need motor brushes for a stanley heavy duty 4'x24' belt sander. type: 497, model A, amps: hi-8.5, lo-7.0, volts 115, serial # 457244. thanks, tom
Hiya
I had the same problem, cannot find spares. I went to a local tool hire company and purchased two brushes (Part No. L41F10). You will need to shorten them by approx.1/4"", swap the springs and cut down the metal terminal to same shape as the original. A small 1/2 round file, junior hacksaw and about 15 minutes should get you going.
I am looking for a trigger (on/off) switch to suit my sander, if anyone can help I would appreciate it. Only other option seems to fit an inline switch to supply cable.
Jun 15, 2011 | Garden
I need a new belt for my porter cable 4X24 inch belt sander - model 362 - type 6 whisper series
I have had the hardest time trying to find a belt for mine.
I've made do with a 3 x 24 without any turmoil
I take it you are having similar problems
Mike
Aug 21, 2010 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
How do you replace the drive belt on a Porter Cable Belt Sander
There is a lever on the side at the front right near the roller that you can use to release the spring tension on that roller (moving it slightly to the rear).  Once the tension is released you can slip the sanding belt onto both rollers from the side.  Release the lever and the spring will put tension on the belt to hold it in place.  Use the knob on the left side to center the belt on the roller if it starts to slip sideways when in use.
May 28, 2009 | Porter Cable 361 3" X 24" Sander
Porter Cable belt sander
try to rig the nozzle of a shop vac to the part where the bag would normally connect and run the sander simultaneously with vac for a few minutes and see if that helps
Jan 11, 2009 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
Porter Cable 361 3" x 24" Belt Sander Logo
103 people viewed this question
Top Porter Cable Tools & Hardware - Others Experts
John Trevino
T bone 1963
Are you a Porter Cable Tool and Hardware - Other Expert? Answer questions, earn points and help others
