Question about KWorld PCTV CONVERTER KW-PCTV-1600 RT (KWPCTV1600)
Get only black and white picture on TV through converter box
Try fiddling with the PAL/NTSC switches on the back of the device. I got color working by flipping one of the switches about half way towards "On".
Posted on Jun 11, 2009
Color on TV changes to black and white, then after awhile changes back
It is possible to be the box, and not your tv. A good way to test is to see if it does it when you are watching a dvd or another source. (game system, blue ray, ect) Hope this helps! Good luck!
Dec 04, 2013 | Televison & Video
How can i make my samsung LCD TV pictures change fro black and white to coloured in ghana
Set is likely formatted by design for North America which is set up for NTSC transmission system and likely there it is PAL--both issues fit this. You will need a PAL (if system there) to NTSC converter box.
Jun 13, 2012 | Samsung LN37A550P LCD TV
Trying to hook up digital converter box but cant get reception
This seems related to the TUNER and the IF section as the sound- audio and picture- Y signal does not process with the correct alignment.
Dec 06, 2011 | Audiovox VE727 7 in. Under Cabinet TV
Im trying to connect my sega dreamcast which has red white an yellow av cable only, however my insignia NS-32E570A11 led tv only has for component connection with the blue green n red, when i hooked it up,...
Sorry, this will not be easy....
You need to locate a composite to RGB converter box.
Your Sega outputs a composite signal - Video (yellow) and audio left/right (white/red).
The TV needs RGB (red/green/blue) inputs on the component connection...your composite signal divided by three. There are converter boxes out there for around 70 bucks or so.
Are you certain you do not have a yellow VIDEO IN jack on your set? Every LCD and LED TV I have experience with has at least one.
Feb 18, 2011 | Insignia 42" LCD Flat-Panel HDTV
Black and white viewing
It's probably the new technology.Do you have a cable box or basic cable with a straight wire?If you have a box it should work.Sounds like you don't though.The cheapest fix would be a digital converter box.If you buy one and don't like the results,make sure you buy it at a place where they will accept the return.A dish digital box should work though.Do you have just a wire from the dish?It seems like a dish requires some sort of converter.How long have you had this problem?If you had a picture when they first went to digital,it would be the TV.That's all i can say.
Jul 27, 2010 | Philips 60PP9601 60 in. Rear Projection...
Our tv doesn't have sound or picture
You need a Digital to Analog converter box as your TV is analog, and all broadcasts, since Last June 12 are Digital.
Apr 16, 2010 | Sylvania 6520FDE 20 in. TV/DVD Combo
No color on tv
if you have good picture and sound, color problem is with the t.v and color needs to be turne up
Sep 20, 2009 | Zenith B25A11Z 25" TV
Why is my tv only showing black and white when I hooked up my new converter box?
It decided you needed to view tv old school style. I had this problem, turn the tv on after you turn on the converter box. That solved it for me.
Jun 10, 2009 | Insignia Digital-to-Analog Converter for...
When connecting video or set-top box using composite video cable picture is black and white. If I use S-video I get colour. Video only has scart and tv only has composite/component/s video connectors so I...
you really cant convert to component. it defeats the whole purpose of upgrading your tv. with your tv you should be using hdmi to connect all your devices your cable box should deffinatly have one. any time you connect component to something else you will get black and white hdmi is totally digital where as component is still analog pluse you dont need audio cables with hdmi its just one digital cable
Sep 21, 2008 | Televison & Video
Open Questions:
Televison & Video Logo
342 people viewed this question
Top KWorld Televison & Video Experts
kenwal
Level 1 Expert
Ruben Balisbis
Ruben Balisbis
Are you a KWorld Televison and Video Expert? Answer questions, earn points and help others
