Question about Cuisinart DCC-1200 Coffee Maker
Autostop problem Brewed coffee this morning, about 3/4 of the way thru it turned off. Pushed start again, it finished brewing then shut off very soon afterward, 5 min or less. My Autostop is set for two hours. Mine is 8 years old also, never had a problem before. Tried brewing again w/ the timer and seems to be working now, with the timer only.
  • 4 more comments
  • Anonymous Feb 27, 2009
    Mine does the same thing. 3 yrs old.
  • papascoffee Mar 06, 2009
    Same problem, brews 6-8 cups and shuts off. Lost my manual.
    Has something on the auto on set wrong? If I keep turning it on it
    will brew a little more sometimes. Sometimes I can't turn it on at all.
  • SugarMaple Mar 07, 2009
    Me too...ours is about 2 yrs old, very erratic. Works for weeks, and then it goes through a spell of shutting-off midway through a brewing cycle. Clearly a manufacturing/design defect. Other than that, not a bad coffee maker.
  • Anonymous Mar 09, 2009
    Same problem here only my DCC 1200 is only a couple of months old. It started out where I had to brew each pot twice to get it to brew the full pot. Then three times, then four..... Now it takes like 9 times to make a full pot.
  • dymer Mar 14, 2009
    Mine and my father-in-law's as well--both coffeemakers six years old, problem just started this month. Three-year warranty, oh well. I expected more from a $100 coffeemaker, but I guess $17 a year isn't bad. I still won't buy another Cuisinart. Fool me once...
  • kgmer Mar 18, 2009
    Same problem, approximately 5 yrs old. Just stops brewing either with auto brew or manual cycle. Can sometimes restart, sometimes not.
  • 85 Answers
Hello gschris213,
I recently had this similar problem. If you still have you machine try the following.
Your described problem may be one of two problems. Let's start with the easier solution first. In the DCC 1200 there is a filter "stick or column" in the left rear. Pull it out and remove the clogged carbon filter(s) that are in there. Shine a light into the receptacle and remove the debris in the bottom. It is likely that this is causing the problem with you machine needing to be started on multiple times. See if this solution works. If it does, you might run 8 cups of water and 4 cups of vinegar through to help decalcify the units plumbing. Do this once or twice and then rinse with at least one pot run-through of clean water. If this works then you are good to go.
Next, if this does not solve your problem we can do the following: unplug the unit and lay it on its back. You will need a #10 torx driver (hardware store if you don't have one) to remove the bottom cover plate. There are 4 torx screws holding it on. When removed, you will find 2 orange hoses. Carefully attempt to remove the left hose without splitting. I used a eyeglas screwdriver to loosen it up. If it splits, just cut off the split and stretch it to reconnect when time comes. As you look into the hose you will find a little black valve inside as well a some gunk. Clean it all out with a fine wire as best you can. Rinse well. Attempt to reconnect the hose back onto the pipe. Slip the pipe clamp back into place. Replace the cover and screws and you should be good to go again. This is not as daunting as it may seem. You can do it. :o) Good luck! If this answer helps, please leave positive feedback for me. Much appreciated. Regards, NormanZ
Posted on Jul 08, 2009
Gd morn. My CBC5200PC will brew only a partial amount of the water. This morning it stopped at 6 cups, then I coaxed it by turning it off and on,, but would only drop a cup of water at a time
Brewing Problems
Another common problem that can occur with the Cuisinart coffee maker is it will stop brewing, even when there is water ready to be transformed into coffee. The machine still turns on and works like it should, but does not continue brewing an entire pot of coffee, and acts like it has finished brewing even when there is still water sitting in the bin. This type of problem is pretty common among various coffee makers, and usually occurs when there is a problem inside the machine.
One of the best ways to fix this problem is by flushing the coffee maker out with a vinegar solution, which can be made with equal parts of vinegar and water. It should be poured in the same place as the water that is ready to be brewed, and will help to clear out the machine and make it ready to start brewing again. This problem is usually caused by calcium building up within the machine, and the vinegar helps to clear out any blockage to help it start running smoothly again. (From. Google Search)
May 17, 2017 | Coffee Makers & Espresso Machines
Coffee overflows when brewing
make sure carafe is pushed in all the way.We had to tape owrs every morning
Mar 15, 2015 | Mr. Coffee OptimalBrew 10-Cup Thermal...
Brewer stops @ halfway thru airpot, will not let me adjust brew level
take front panel off and on timer board is a little switch. move it from on to 1 then hold breww switch till you hear 3 clicks
Mar 31, 2014 | Bunn CDBCF 15 Coffee Maker
Mr. Coffee single serve brewer won't brew
First clean and please try again
Fill the reservoir with water.
Place your mug underneath the machine.
Add the K-Cup.
Choose your serving size.
Press the brew button to begin brewing.
Enjoy your delicious cup of coffee! .
Sep 25, 2013 | Mr. Coffee BVMC-KG6 Single Serve Coffee...
Cuisinart dc 1200 coffee maker auto start mysteriously shuts off
Sounds like the switches got damp when you cleaned it. Let it dry out very thoroughly before you plug it back in. Then set the TIME OF DAY first, and be sure you pay attention to AM/PM if you are not in the 24-hour mode. Next, set the BREW TIME. Once again, heed the AM/PM or you will have nice hot coffee either 12 hours early, or 12 hours late! (I don't know which would be worse.)
Mar 18, 2012 | Cuisinart DCC-1200 Coffee Maker
After first cup is brewed, it shuts itself off and
No solution but we are on our 5th replacement from Keurig. Everyone has done exactly the same thing. It worked fine for a few weeks, than started turning off after brewing a cup. Like the problem states, the only way we can get it to work is to turn off and wait 15 minutes or so, then try again. Keurig has been great in replacing our coffee makers, but I really like it to just work.
Jan 23, 2010 | Keurig B60 Coffee Maker
My machine only brews 1/2 cup of coffee. I have de-scaled twice within the last week and I get a full cup of vinegar/water, but as soon as I put in a K-cup I only get 1/2 cup of coffee out. The first cup...
I had some coffee grounds stuck up in the cone shaped hole that the water comes from at the top. I had to use a very long toothpick but it broke up some of the grounds that happened to get caught up inside. Before doing this, I went through 24 oz of vinager ;) .. the toothpick worked!
Aug 15, 2009 | Keurig B60 Coffee Maker
I Have a Cuisinart Automatic Grind & Brew Thermal that when you start brews a small amount of coffee and then shuts off. I shut off grind and start. After I do that it brews a full pot. We have cleaned...
I do love our Cuisinart pot...but find they only last 2-3 years...so my suggestions is: if the pot is still in warranty, call Cuisinart for a new one...they are great about it. If you don't know if it is still in warranty, call them, give them the number and they will tell you.
jlo
May 30, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Pot keeps shutting off after coffee completely brewed.
This may be an electrical issue, but I would try holding in the on/off button for a few seconds and see if it still displays 2 hrs as the auto-off time. If 2 hrs does display correctly, unplug the unit for 16 minutes or longer - do not plug it back in a single second shy of 16 minutes. Then reset the clock and reprogram the auto-off Try one more time.
If that fails, it may be replacement time.
-Tha Mp3 Doctor
Nov 28, 2008 | Cuisinart DGB-500 Coffee Maker
Cuisinart DCC-1200 Coffee Maker Logo
270 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
