Question about Gigabyte GA-M57SLI-S4 (4719331821180) Motherboard
New Build PC not booting
I have just built a new barebones desktop ATX PC and am experiencing problems when booting.
The computer is built with the following components:
1) Gigabyte S-Series GA-M57SLI-Sq
2) AMD Athlon 64 3000+ Socket AM2 1.8GHz 512KB L2 Cache OEM Processor
3) Akasa AK 860SF - Processor cooler
4) Memory 2 x 2Gb Gigabyte Motherboard GA-M57SLI-S4 DDR2 PC-5300
5) Gigabyte 256MB/512MB Geforce 7300SE PCI-E Graphics Card
6)Pioneer DVR-216DBK 20x Internal Black Bare SATA DVD+/-RW Drive
7)320GB NEW Samsung 3.5" SATA Hard Drive (300gb HDD)
8) ATX 400W Blue Computer Case 20 + 4pin PSU
All items were brand new and sealed
I have connected all of the jumpers as per the manual and doube checked these
On power up the CPU fan kicks in, the disc in the DVD player is read (I can see the light flash on and off) as too is the Hard Disk (light flashes on and off). The yellow LED next to the LAN (RJ45) socket also lights up. However there is no bleep and no signal transmitted to the monitor. I cannot see that there is a power LED on the motherboard. I have 2 sticks of 2Gb memory and I have each combination in all of the 4 available slots with the same result. I have a PC PCI Diagnostic Card Motherboard Analyzer and on boot it goes through codes C!, C3, 21 and always stops at 25.
Any help or advise is greatly appreciated
  • 85 Answers
Do you get any onscreen information like a bios screen?
Posted on Feb 22, 2009
  • 5 more comments
  • Chuck Feb 22, 2009
    im sorry that wasnt solution i needed clarification
    you must install new operating system as well correct?
    xp or vista? sp1 sp2 or sp3 disk?
    just make sure to plug in all power connectors on motherboard there is a 4 pin connector near top of cpu port on motherboard it might have a plastic plug on it make sure to remove this and plug in power from powersupply. i have to look at your video card now as well. do you have the exact model number of it?
    i just saw the other pcie power for motherboard this is the power for your graphics card and the one you have is pcie so make sure you also plug in the 4 pin molex from power supply as well you can locate it underneath where you plugged the cpu fan in. i believe if you didnt have either one of these extra power connectors plugged in this would give you the problems you are describing. look at my previous comment for the other power connector
  • Chuck Feb 24, 2009
    did you read page 25 and 26 of your manual from the above comment? just make sure those power connections are all plugged in ok. and how bout a fix ya if it worked or maybe alittle
Help with a new desktop is a fantastic site, i have built several pc's and i always use them, they have everything you will need
Dec 30, 2009 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
I need to replace the motherboard on my Gateway 503GR. Will the following motherboard work? eVGA e-7050/610i GPU - motherboard - micro ATX - GeForce 7050
Check your wiring harness on your Gateway and see if it will match up to your new board. If the wiring harness will match up then you can install the board. However, you will now have a custom built computer in a Gateway case.
Aug 01, 2009 | Gateway 503GR PC Desktop
I can't get a video signal to the monitor. Have a new graphics signal????
1/ first change motherbord on your desktop.if it is work (your old bord is damage ).then keep graphic card/ vj card on old mother bord slaut. if not work . it is seriously problem.mainly in pinless bord we can"t repair it. change or took it on export
Jul 10, 2009 | Intel DX48BT2 Motherboard - X48, Socket...
Pc tower motherboard upgrade
you can put in any new micro-atx motherboard no problem. I can be 100% sure if the case is Atx full size- best way to check is to see how many pci expansion slots are available at the back of the case. Any Atx case can hold micro-atx mobo's but a micro atx case wont hold atx mobo.
May 27, 2009 | Compaq Presario 5000 PC Desktop
New build computer boot problem
The exact problem is not actually a problem.Just get in to BIOS.
As it is a new system, even if you get to boot from HDD it would say insert proper boot device and press enter or your floppy drive is in first boot.Check you boot settings.
Change the boot order as below.
  • 1st boot device:CD drive
  • 2nd boot device:Hard drive
  • 3rd boot device: anything you want
Now save and exit(F10 then Enter)
Now your PC will reboot.
Drop in the OS CD (Xp , LINUX or whatever)
Install the OS .Now you are ready to use your PC.
Mar 18, 2009 | Intel Computers & Internet
What PSU will work with my Acer T690?
Any new ATX PSU will do.
Prices variate, but an 500W PSU is good for this purpose and medium in budget terms.
Feb 20, 2009 | Acer Aspire T690 (AST690UP820A) PC...
remove ram memory - it should beep when you switch it on - if no beep then check CPU in socket and cpu fan spinning when on.
Jul 31, 2008 | HP Compaq d530 SFF PC Desktop
My shuttle wont boot
If it's a new build, can you give details on processor etc. But if there is no bios, it's normally a memory incompatability problem, or the processor isn't active.
Jan 08, 2007 | Shuttle SN41G2V2 Barebone
Gigabyte GA-M57SLI-S4 (4719331821180) Motherboard Logo
288 people viewed this question
Top Gigabyte Computers & Internet Experts
Alun Cox
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
