Thanks for all the feedback regarding whether the soundcard affects
recording from a digital source. This has helped me to focus on trying to
decide between these two cards:
E-MU 0404 Digital Audio System
M-Audio Audiophile 2496
They seem to have a similar spec and are currently both available in the UK
for ??69.
Does anyone know if there is there a quality/feature/ease of use difference
between them?
And just to muddy the water a bit.
My ASUS A7N8X Deluxe motherboard has on board sound that seems fine for
games etc. It also has a headphone output, which these cards do not. Will I
need to disable the onboard sound, or can I still use it for games and audio
playback and just select the new card for actual recording in/out and Midi
in/out?
Thanks again.
Rating: 0%, 0 votes
You might consider this one:
A bit more money, but unlike the other two, it has balanced I/O.
Was this solution helpful? Show your Appreciation by rating it:
Rating: 0%, 0 votes
to me like you're ready to take anyone's advice without listening to either
card. In that case, go with the reliable card. The difference in sound
quality will be negligible.
Rating: 0%, 0 votes
Their opinions were firmly split, with one recommending the E-MU as being
the more powerful, better specified card and the other recommending the
M-Audio as the well established, hassle free workhorse!
I suppose I could get the E-MU and then try and swap it for the M-Audio if I
have compatibility issues...
Cheers
Rating: 0%, 0 votes
long before that.
What does E-Mu have to say about that? Did you ask? It's unfortunate
that they released a product with non-working WDM drivers (at least
not working for you, I wonder if everyone has this experience), but
that's the way things go these days. As soon as it produces sound, the
marketing people start advertising it, and as soon as an ad appears,
people expect that there are thousands out in the field and we want to
know how good it is. So they HAVE to release it.
They'll get it right in a few more months.
I'm really Mike Rivers (mriv@d-and-d.com)
However, until the spam goes away or Hell freezes over,
lots of IP addresses are blocked from this system. If
you e-mail me and it bounces, use your secret decoder ring
and reach me here: double-m-eleven-double-zero at yahoo
Rating: 0%, 0 votes
easier.
Your recording software can specify which card is used for recording without
changing the default card for other applications. Either card will be a
substantial step up from the on-board sound.
Rating: 0%, 0 votes
Emu sounds very good, but I had major installation problems with it. In
fact, after re-installing Windows and ensuring no interupt sharing etc, I
was still unable to get it to record audio. I wound up building a new
computer to accomodate it. I had 2 AMD 2400+ systems, one with the M-Audio
and one with the Emu. I highly suspect there was a compatibility problem
with the Emu drivers and the VIA chipsets. Since putting together an all
Intel system, the Emu works fine. The Emu drivers are still in the infant
stage and the WDM drivers don't really work yet, ASIO works fine though. I
have read that others have had success with the nVidia chipsets and the new
Emu products, so you should be fine.
The M-Audio cards install easily and work without a hitch. They sound good,
but not as good as the Emu 1820m. I understand the less expensive Emu cards
do not use the same converters as the 1820m anyway. Either way, both
products are good sounding and I am pleased with them.
I disabled my onboard sound chip. You'll have to play it by ear as to
whether or not you'll need to do the same. It will depend on whether or not
you have the spare interupts available.
Hope this helps you with your decision.
Cary
id/
Post a New problem for E-Mu 1820M Sound Card
Email this problem
Can you Help with these Sound Cards problems?
pops and clicks in recording...
emu 1820m all audiodock lights...
