Question about Tappan 24 in. Freestanding Gas Range Kitchen Range
Tappan Gas stove: oven/broiler won't turn on
In the display screen of my Tappan gas stove, a symbol (looks like half of a capital "H" followed by a dot) appeared and I can't turn on the oven/broiler, or clear it (none of the buttons work). However, the burners on the stove top work. What does this mean? How do I fix it so I can use the oven/broiler again? Please help, I'm desperate!
5 Suggested Answers
SolutionGuy
  • 331 Answers
SOURCE: Tappan Gas stove
The pilot adjustment screw is located on the back side of the oven temperature thermostat. Lift the cook top to access it. Use a flat screwdriver to adjust... counter clockwise= bigger flame.
Posted on Aug 15, 2007
  • 145 Answers
SOURCE: burners and oven not heating tappan range 560s111po1
You need to check the connection at the back of the unit that hooks to the house power. Turn off breakers or pull fuses before checking. It sounds like you only have half of the voltage you need. One of the wire connectors may be burnt or you may have a problem with the house wiring.
Posted on Apr 23, 2008
TheMobilian
  • 8220 Answers
SOURCE: Whirlpool Super Capacity 465 the oven/broiler does not come on.
More than likely a bad ignitor
Here is how to tell If the ignitor is glowing it should be VERY bright, if it is dim orange it is weak and bad.
Posted on Jan 08, 2009
SOURCE: Replacement Parts For Vintage Magic Chef stove
You probably have a 1940's model of Magic Chef. Check for the model number under the lid of the cook top on the upper right hand side of the stove. It should have the model number and the serial number, too. You will need both. The Old Applicance Club run by Jack Santoro is the place to go along with a site called "Antique gas stoves"in Georgia. Good luck with the world of vintage stoves.
Posted on Apr 06, 2009
Asus manuals
Not seen a manual as such but a dummy or similar guide to Android is likely to have one.
Most android keyboards including jellybean (4.2) are pretty standard.
The up arrow is shift for capitals and hold for a couple of seconds to get all caps rather than one and then return to lower case.
Bottom from right - ?123 is for numbers and symbols and it toggles.
The symbol next to it is for speaking commands rather than type.
long blank is the space bar, then dot,
Left arrow is carriage return or enter. Above this the x with white arrow is backspace delete. A multidot symbol toggles the keyboard on and off the screen.
Normally when you enter a field on a form the keyboard automatically appears. It also appears when you enter a browser address box etc.
Aug 07, 2014 | ASUS MeMO Pad FHD 10 ME302C-B1-BL 32 GB...
Tappan gas stove
Older gas stoves used a battery to ignite the flame but due to its age, I would get a hand held gas lighter.
Apr 21, 2017 | Kitchen Ranges
How to change language on MID tablet??
Find the settings icon.
This sometimes looks like a graphic equalizer with three sliders.
On the settings page, scroll up and down on the left to find the language Icon.
This looks like a black square with a capital A on it and some dots.
On the language page select the top one (Chinese symbols).
It should display a list of languages.
Select yours.
Feb 21, 2012 | Tablets & eReaders
No gas going to oven
Hi blocked oven pilot , ffd not working oven burner blocked injector blocked
Feb 02, 2010 | Tappan 24 in. Freestanding Gas Range...
Flame going low on range cook-top
Check your gas supply is not running too low and then check for leaks, Let me know if this helps.
Jan 02, 2010 | Tappan TGF320 Gas Kitchen Range
Oven not coming on
I have a tappan gas stove the top comes on but the oven wont come on.
Sep 07, 2009 | Tappan TGF363 Gas Kitchen Range
Old tappan in counter gas stove/range
sorry, misinformation, no such child lock existed in those days, either your spark module is bad or your switches are bad, (unusual for all switches to fail simultaneously)
Apr 02, 2008 | Tappan TGF364AS Gas Kitchen Range
F1 and F2
Here are the codes for Tappan ranges:
TAPPAN
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F0 & F1 EOC (Electronic Oven Control) failure Replace Electronic Oven Control F2 Oven too hot Check Bake function, if OK, replace oven temperature sensor F3 Oven temperature sensor open Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor F4 Oven temperature sensor shorted Replace oven temperature sensor F5, 6, 7 EOC (Electronic Oven Control) failure Replace Electronic Oven Control F8 Lock switches Check switches and replace if necessary
Nov 06, 2007 | Tappan TGF363 Gas Kitchen Range
Tappan 24 in. Freestanding Gas Range Kitchen Range Logo
462 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal De
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
