Question about HP Pavilion a1200y (EK457AV) PC Desktop
Hp pavilion a1200y with windows xp home
I turn on the computer and it tries to run the windows then it goes black shows the three partitions witch is windows xp home windows recovery and windows setup none of these are working when i go to the home edition it ask me to put my cd in i do the it tells me that it can not run it do to internal erro and missing file wich i do not have the set up just goes to a black screen does nothing the recovery asks for a pass word wicth i dont have so how can i get the file i need or fix this problem i am on another computer because my hp is not working
    Problem Solver:
  • 9 Answers
Hmm,
It seems that you might either have a problem with your hard drive or you might have a huge Trojan that is not allowing you too sign on. If you cannot go to your desktop, you might have to get a new computer, if your finally able, try scanning it with a anti-virus.
Hope this helps,
TechGirl123
Posted on Feb 22, 2009
HP pavilion ze4600 XP operating system safe mode etc. will not load CD restore does not work either? help
Firstly hdd's shouldn't click. Purchase a new hdd set your BIOS to boot from CD drive, install XP from your disc.
Dec 05, 2014 | HP Computers & Internet
Cant get the computer to work. a1540n, When I start it up the screen says no signal.
Your OS is hopelessly corrupted. Try a repair operation with your XP disk. If that does not do it then you will either have to use the recovery disks you have or deal with it and and reload the witch.
Jul 22, 2017 | HP Pavilion a1540n PC Desktop
My hp Pavilion a450n wont boot it shows the screen where it says Window XP and it shut down and for maybe 1 second shows a blue screen with some info and it goes back to asking to start window normally...
It sounds like your windows OS installation has been corrupted. Your computer might have a recovery partition like many HP models do.
Try hitting F11 when you first turn on the computer (watch the screen in the corners. It may say something like hit "F2 to go to BIOS or F12 to choose a boot device/ etc. Each computer is different in this regard).
If you can get into the recovery partition you may be able to do a windows repair. Alternatively, if you have your windows disc you can boot off the cd and run the windows repair tool like that.
I would HIGHLY recommend manually backing up any and all important files first. If you have a USB enclosure use that to pull the drive out and hook it up to another computer. If you dont then I would run a bootalbe version of linux or something and transfer your files to a USB drive or burn to a cd. See here to download ubuntu.
Mar 01, 2011 | HP Pavilion a450n PC Desktop
I have an hp pavilion a720n desktop with an hp pavilion mx70 monitor and windows xp home. There is a problem with the color displayed on the monitor. I see mainly black and white, but blue shows up fine....
First of all you can check the computer by connecting another monitor to it to see if the problem goes away...if so then the problem would be in the monitor. If not , then I would try to change the video grafics card in the computer(assuming you don't have built in video). If you have built in video on the mother board then you will either need to replace the motherboard or disable the onboard video and install a video card
Dec 19, 2010 | HP Pavilion MX70 17" CRT Monitor
My hp beeps and shows a black screen when trying to start up
Hp Support ---->Link.
or :
Cause 1 This issue may occur if you have a CD, a DVD or a floppy disk in your CD, DVD, or floppy drive when you start the computer. Cause 2 This issue occurs if one or more of the following elements are corrupted and will not load during the boot sequence of the computer:
  • Master boot record
  • Partition tables
  • Boot sector
  • NTLDR file
Method 1: Troubleshoot the specific element that causes Windows not to loadNote This option requires that you perform multiple steps to determine the exact element that causes the issue. This option may allow for you to keep customizations in Windows.
  1. Restart your computer in safe mode. To do this, press the F8 key while Windows is starting. Then, create a Windows XP boot disk to start the computer.
    For more information about how to create a Windows XP boot disk, click the following article number to view the article in the Microsoft Knowledge Base: 305595 (http://support.microsoft.com/kb/305595/ ) How to create a bootable floppy disk for an NTFS or FAT partition in Windows XP 315222 (http://support.microsoft.com/kb/315222/ ) A description of the Safe Mode Boot options in Windows XP If you can start the computer from the boot disk without receiving an error message, the damage is limited to the master boot record, the boot sector, or the NTLDR file. After Windows XP is running, immediately back up all data before you try to fix the boot sector.
    Use Disk Management to view the partition information and to verify that the disk partition (or partitions) is correct. To use Disk Management, follow these steps:
    1. Click Start, right-click My Computer, and then click Manage.
    2. Expand Storage, and then click Disk Management.
    If invalid partitions are present or you cannot start your computer by using a boot disk, consider reinstalling Windows XP on your computer and restoring your data and configuration information from a recent backup.
    If you do not have a current backup copy of the data on the computer, contact a computer specialist to determine the best method of data recovery and configuration.
  2. Run a current virus scanning program to verify that no virus is present.
  3. Repair the master boot record by using the FIXMBR command from the Windows XP Recovery Console.
Oct 06, 2010 | HP Computers & Internet
A1200Y won't start
Dead CMOS battery does not cause the problem you are describing. More likely your southbridge chipset is defective on your motherboard. Replace the motherboard.
May 30, 2010 | HP Pavilion a1200y (EK457AV) PC Desktop
This Computer is a HP Pavilion s5213w Slimline
You just need a valid CD installer of your windows XP Home. Just insert the CD Installer when you start your computer so that it will boot from the CD. Then just follow the installation instructions on screen. You need a valid serial key. And you need to recreate the partitions. Make sure also that your motherboard drivers are ready since all of the needed drivers are shipped with your device package.
Feb 03, 2010 | Computers & Internet
Computer shut down and windows password page came up. I cant remember the password.how can I reset it?
Turn the computer off. Turn it back on and start tapping F8 when you get the 'advanced boot options' choose safe mode and use the administrator account to change the password from there.
Jan 18, 2009 | HP Pavilion a1200y (EK457AV) PC Desktop
Trouble installing xp on a hp pavilion t3000
use the Windows Xp CD to format the hhd twice.
install the OS from the CD without partition.
you can always partition the hhd later.
Jan 13, 2009 | HP Pavilion a705w PC Desktop
Installing windows xp
Try first  to use hiden boot cd.With it u can see all files on hdd.When u see winxp files just delte.But i will not take responsibility couse sometimes xp wont boot up...
But i recomneded you to save all your data and format your pc.Make sure that the partition cd must be deltet befor u contiuing with formating ur pc like in this pics:
http://www.imagehost.ro/pict/3003390347268b3728923.jpg
Oct 29, 2007 | Microsoft Windows XP Home Edition
HP Pavilion a1200y (EK457AV) PC Desktop Logo
111 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
