Question about Panasonic PT-51HX41 51" Rear Projection Television
Panasonic PT-51HX41B, Not a problem but some info for Ladywinn
Ladywinn
Re: Panasonic PT-51HX41b
As reading your advice has help me diagnosing the problems with my Panasonic PT-51HX41b TV I thought I would pass on some information, but was not sure of the actual part number as I do not have the service manual to properly ID the part. Any way over a year ago I replaced the the two STK392-150's and the feed resistor bank R7048 - R7051.
However in my case the resistors are 10k not the 2.2k that I see referenced a lot. Maybe a different version of the chassis.
What I wanted to pass on that after a year post repairs the TV started turning off by it's self and back on randomly, but only when cold. A good sign of a cold solder or cracked trace.
Sure enough after a long check with a magnifying glass I found it! On the main board just below the AC daughter board there is a Blue rectangular box (relay R801)and it had two cracked solder joints.
Hopeful this info will help you or others with their Panasonic PT-51HX41b problems.
  • 41 Answers
SOURCE: No voltage to convergence chips
There are usually 2 micro fuses that resemble 1/4 watt resisters around the power supply, and are usually all green,tan or yellow, and in most cases will have a + or - voltage marked right near these fuses 20 to 25 volts dc typical.
Posted on Jun 29, 2007
premtech
  • 934 Answers
SOURCE: Where to buy feed resistors?
Acme enterprises in Florida, inexpensive and very reputable...
http://www.acme-sales.net/index.shtml
or by phone at: 1-800-575-9833
Bill
Posted on Nov 27, 2007
MikeMaierTV
  • 206 Answers
SOURCE: Convergence
Sorry about that Boxerman My Computer picked the wrong time to hang. No the reason why I tell peoplle to get the Hitachi Kit X480295 is becuse this forces them to get good parts, not only are there some spare resistors but the Ic's are a higher wattage and will last longer. When people seee that the orginal Ic's the STK392-110 go from anywhere from 5.95 to 37.00 for what they belive is the same Ic they almost always get the 5.95 cheep'Os. Then in one week or less the Ic craps out and they don't know why
So the Kit that has The higher wattage STK392-150 in it and for a good price is a bargan. , Now you said you have a Hitachi giving you trouble till it warms up, that is a whole differant problem and is most likly in what is called the 3DY comb filter and a few caps on that board have or are failing
Posted on Feb 19, 2008
  • 8457 Answers
SOURCE: I have a Panasonic Projection HDTV that i recently
The 2 STK convergence ICS are dead,all the resistors too,if it is smoking and glowing.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to repair it again.Find the correct tv make and model.The convergence kit buy from one of these website's will have all the parts to repair it right this time.
Posted on Jul 16, 2010
SOURCE: panasonic pt-47wx42f
I replaced the convergence chips, the tv comes on now, but turns itself off in just a few seconds. I need to know why.
Posted on Sep 06, 2010
After power surge panasonic hdtv projection tv model # PT-53WX42F wont come on red light flashes
Bobbie, It dose not sound like surge protector was real effective, the TV will have to come apart to diagnose what has all blown, capacitors, boards etc. Google search can help show how it is done.
Enter all your TV's info, will not power on repair.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Apr 08, 2016 | Panasonic Televison & Video
My tv powers on and then shuts off in a few minutes. I love this tv and the picture looks great, i think its a fan problem. But not sure.
Do you see any light lit solid/ blink when tv shuts down?
Let me know is it Panasonic PT-50LCX63 or any other model?
Above info will help me to diagnose problem and to suggest a solution.
Thanks.
Jan 24, 2011 | Panasonic PT-50LCX63 50" Rear Projection...
The TV will not power on at all since last night. How can I fix this problem?
Does power indicator on tv front blinks? If yes, how many time or there is no power in sign when tv plugged in?
These info will help me to diagnose problem.
Thanks.
Nov 28, 2010 | Panasonic PT-53WX42 53" Rear Projection...
How do i reser the lamp meter after i replace the
Panasonic TY-LA1000 TV Lamp Reset Procedure/instructions:
Per numerous members, it looks like this method works quite well:
  • Hold the Vol down button on the TV and the Split button on the REMOTE for five seconds, -or- Press the Volume button on the TV while pressing hte SPLIT button on the Remote Control for five seconds
  • It will NOT work if you try to do it both from your remote!
Sep 16, 2009 | Panasonic PT-60LC14 60" Rear Projection...
Panasonic pt51 hx 41e
Recheck all of your solder connections recheck and make sure everthing is pluged or reconnected right then retry set.
Nov 29, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Have a panasonic pt-47wx53 47"
crsheidt,
I am having the same problem.Terryfic gave me some good advice I am the process of taking. The service manual will help you locate the convergence IC circuit board so you can remove it to replace the IC`s. If you need I can send you a copy of the location picture from the service manual.I recommend you contact Terryfic for exact advice.
Johnny
Mar 31, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic PT-47WX49
you can get the service manual at this link, and with the purchase of the manual they provide free help to diagnose and help you repair your set. They also will email the manual.
http://servicemanuals.vstore.ca/
Mar 10, 2008 | Panasonic PT-47WX49 47" Rear Projection...
TV powers on for about 5 seconds and then powers off
I really dont think resistors need changing on this make and model first check hori out put NTE2973 capiactor may be burnted 1200pf 2kvolt, this is what i found wrong with customer set after getting tvs high voltage up then i saw that convergence ic needed to be changed out also.If you need more help let me know ive been up all night,will answer as soon as i can.
Mar 06, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic projection tv
panasonic is well known for two capacitors 1200pf 2k volts, also it has been known to short out the mosfet transistor, it sounds like you only need to replace the caps.
Dec 20, 2007 | Panasonic PT-47WX53 47" Rear Projection...
PT-51HX40b chassis BP819
if you get to the red chk press the power button on remote numbers should appear lower right each time you hit power button nummbers change keep going till 00v00 appears press ch up then it should read oovo1 at this time press vol up now your ready
press 1 to toggel colors
use vol and ch buttons to move cursor
press mute to choose to addjust
press7 to save data
good luck
Nov 26, 2007 | Panasonic PT-51HX41 51" Rear Projection...
Panasonic PT-51HX41 51" Rear Projection Television Logo
62 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
