I'm have problem wiht lg dvx 162 codec - Televison & Video
  • salupi Apr 20, 2009
    I can't see title on my language in DVx !
LG FA 162 doesnt power on.
Dry electrolitic condensator on main power unit or short circuit on speaker cables
Nov 27, 2013 | Sony MHC-GX555 Mini Hi-Fi System Shelf...
Does lg smart led tv support mp4 and mkv formats?
It depends on the specific LG TV model.
Most LG "Smart" TVs have some way to view photos and watch videos from a USB device. In general, the user interface will pop up when the device is inserted.
Unfortunately, the embedded firmware supports a very limited number of video formats (codecs) since LG needs to negotiate for and pay licensing fees for each codec. Since most TV buyers prefer a low price to a rich collection of codecs, there are a limited number of supported formats.
The technically minded may find LG Smart TV Document useful.
Jan 27, 2013 | LG 47lm6700 47 3d Led 120hz Smart Tv...
Get ue code in spin cycle loaded or empty it's pretty level
the reason for ue can be one of these
The load is too small.
• The appliance is tilted.
• Laundry is gathered to one side.
• Non distributable things are put into the drum
Sep 05, 2011 | LG WM-2277HW Front Load Washer
Hi! Somehow got `Key Locked`on my 42LCD LG TV screen. Can not use remote anymore even to turn it off..Can not find manual to read what should I do in this situation. Could you help? Thanks!
From owner manual:
• If Lock is already set, enter the password as requested.
• The TV is set up with the initial password "0-0-0-0".
• If you ever forget your password,
key in '7', '7', '7', '7' on
the remote control. Then, the
password reset to '7', '7', '7',
'7'.
You should download the user manual: www.retrevo.com
Jun 08, 2011 | Televison & Video
Flashing LE does not go into spin cycle
•The connector (3-pin, male, white) in the MOTOR HARNESS is not connected to the connector (3-pin, female, white) of STATOR ASSEMBLY.
•The electric contact between the connectors (3-pin, male, white) in the MOTOR HARNESS and 4-pin, femal, white connector in the MAIN PWB ASSEMBLY is bad or unstable.
•The MOTOR HARNESS between the STATOR ASSEMBLY and MAIN PWB ASSEMBLY is cut (open circuited).
•The hall sensor is out of order/defective.
Dec 18, 2010 | LG Washing Machines
I have a samsung flash camcorder (smx-c10lp/xeu) and have been struggling to put any recording onto a dvd. Can you suggest a program please? I have tried nero but it doesnt recognise the file types. I am...
it depends on what exactly want to do with the files...if you just want to store them and use them into computer for future watching and managing ...Nero can do that ..but you have to choose to make Data dvd ...it will not be playable in classic dvd players...but it will play in most computers..with the right codecs on ...
also ..if the files came out in Vob format ...(I assumed that cause you said nero do not sow the files..) there are VOB to..avi converters on the net ...downloads for free..
but ..from what I understood ...tis camera is capable to export Mpeg 4 file format ...this is readable in most dvx players...and all computers with a player and a dvx codec....and also can be converted in dvd clasic format even with nero...if you choose to make dvd ...ad mpeg 4 files ...and have patience ..cause it is taking time ...
anyway ...if you want to make a classic dvd format ..playable in all dvd ...(video -ts files...) you need this kinda program
http://www.soft29.com/how-to/convert-vob-to-dvd.htm
use it to make (convert the files in dvd format ..than use nero to burn dvd...
Jan 10, 2010 | Video Cameras
¿que tarjeta grafica puedo poner ?
Solamente necesitas comprar una tarjeta de video AGP the mas o menos 256 MB the memoria. uesta alrededor de $60 en eBay.Galaxy GeForce es suficiente. que tenga VGA y DVI conecciones.
Dec 10, 2009 | Computers & Internet
Idt high definition audio codec for LG E5
you need a codex. search on dowload.com and look and type in divx on the search bar. download it from there and install it.
May 26, 2009 | LG X-Note LM50 Notebook
LG DVX 380 Region Code Unlock
This fix for a LG DVX 350 worked on a region 2 (Europe) LG DVX 380 player:
http://www.videohelp.com/dvdhacks/lg-dvx350/9792
You need to burn the ISO image to a CD then put the CD into the DVD player. A region menu appears, select 0.
Jul 24, 2008 | Televison & Video
Televison & Video Logo
309 people viewed this question
Top Televison & Video Experts
