Question about DCS Large Appliances Built-In Ovens Warming Drawers Single
My grill ignition continues clicking when lit. There seems to be excessive gas coming from just one nozzle above the ignitor and it stops clicking after about 5 minutes or so. Your advice would be greatly appreciated. With thanks R.Scott
    Scholar:
  • 123 Answers
Hi there......im not sure whether your igniter is a manual push button tye or automatic........i'll assume its pushbutton type the fault could be a sticking mechanism....my ADVICE IS HAVE THIS CHECKED OUT BY A QUALIFIED REGISTERED Gas engineer.....Gas explosions can be devastating and result in serious injury or death not to mention structural damage.....
IF IN DOUBT GET IT CHECKED OUT........DONT GET BLOWN OUT.
Regards Sir Galahad
Posted on Aug 12, 2009
Why does grill ignition click when bottom oven lit
ignition probably serves both, if clicking when not lighting, fault or sticking button
Jan 04, 2016 | Stoves Premier 720GRa Gas Double Oven
How can I stop the oven igniter continuing to spark after the oven has lit
This should not be a problem as the setup is it doesn't know which gas knob has been turned on, therefore the oven and grill spark to ignite either .
Hope this is helpful
Regards
John
PS if I had known the make and model number you can probably get a manual online.
Oct 31, 2014 | Ovens
How do you light the gas grill
I assume outdoor gas grill? If so, turn on gas at tank. There should be a knob that has a lightening bolt or something similar representing ignition. Turn the knob to that diagram and click the igniter till it lights. If you don't have igniter use a long grill lighter. Once that is lit you can turn other knobs that control other rows of gas if so equiped.
May 17, 2014 | Magic Chef Ovens
I have an electrolux EOG6330 gas oven and when I light the grill the igniter continues to spark,the only wayto stop it,is to turn the grill off.Any body know what causes it and how to sort it?
Hello dishboy,
There are 2 possibilites causing that
1) The electrode(spark plug) for the grill is is built up with a bunch of grime and not telling the spark module the burner is lit and turn off the spark. The electrode could be cleaned with the green srubby side if a kitchen sponge,or relpaced.
2) The electrode is telling the spark module to turn off but the spark module isn't responding, to turn off the spark. The spark module would need to be replaced
I hope this helps,
Gene
Aug 04, 2011 | Electrolux EOG6330 Gas Single Oven
Whirlpool SF365BEPW2. The bake section of the oven stopped working. TheIgnitor works but no gas is comming out to ignite. The Broil section of the oven works fine. Do you think the problem is withe the...
The problem with your oven not igniting is that the BAKE ignitor is weak and drawing the required amprage (3.3-3.6) to allow the gas valve to open. I know to the layman it does not seem that the ignitor could be the problem since it comes on, but as appliance technician with 30 years experience i am 100% confident that the problem is indeed the ignitor being weak,since it does come on that eliminates all others possibilities because if any other part were defective the ignitor would not even come on
The part number for the ignitor is 786324 it can be purchased online by simply googling the part number then click the shopping tab on the google search
Jul 26, 2011 | Ovens
Igniter stays lit entire time oven is on Blodgett dfg 100-1
I have seen this happen when a hole develops near where the ignitor is mounted. The excess gass overheats the ignitor and burns it up. What I do in a case like that is slide a c clamp over the burner and cover the hole.
Apr 12, 2009 | Blodgett DFG-100 Gas Single Oven
Lighting an old Frigidaire gas oven
Sounds as though the pilot light in your oven went out. On the inside of the oven there should be a small hole about the size of a 50cent piece on the floor of the oven. Turn on the gas for the oven, light a matchstick or rolled up piece of paper, stick it into that hole and it should light, monitor the oven for 30 seconds to see if it starts to heat. SAFETY 1st!
Dec 23, 2008 | Ovens
Oven will not light
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
iuop
Nov 19, 2008 | Whirlpool SB160PEE Gas Single Oven
Fault with Gas Ignition
Sound like the flame sensor is faulty on the ignitor
Apr 23, 2008 | Ovens
Whirlpool gold accubake oven won't re-ignite
i have a whirlpool gas accubake range and only two burners will ignite. The other two burners make a clicking sound and release gas but never light. I have to use a match to light the other two burners and the flame is uneven on one. What should i do?
Feb 18, 2008 | Ovens
DCS Large Appliances Built-In Ovens Warming Drawers Single Logo
116 people viewed this question
Top DCS Ovens Experts
ashburton
Sal De
Joyce Nokleby
Are you a DCS Oven Expert? Answer questions, earn points and help others
