Question about HP dx2300 Monitor Personal computer Intel Core 2 Duo Processor E2160, 1 GB RAM, 80 GB Hard Drive, ... PC Desktop
DVI no input signal......VGA input active.
nothing will load from puter to monitor...sometimes if I really jam connections hard it will work.....
HP ran a scan and says puter in fine working order.....HELP Judy
  • 1 more comment
  • jjgeorge Feb 23, 2009
    here's something weird....to get it to work I go thru these steps that work most of the time but getting worse lately.....I start with power off to everything.....turn on the monitor......let it go to sleep....wait a minute then turn on puter....it works!!!????? Can you figure it out? JJ
    Holy cow......lol.......this is a brand new puter...not even 25% space on drive used.....says no defrag needed...I don't want to do a system resyore because....I had a huge AVG upgrade last month that I had to let my ISP install for me 'cuz I am on a slo dialup and am not allowed to be on line for hours....I live in the woods....no cable....just got water after 30 years....LOLOLOL! I am sure the problem is in a connection .....I will be in touch tomorrow...thanks ever so much.....Judy
    Oh don't I know about XP.....had it for a long time and miss it dearly.....I will see about getting a tech....thank you so very much........Judy
    Scholar:
  • 164 Answers
Are you running an additional Video card? Or are you using the built in one.
You might try cleaning the connector / plugs with acetone from finger polish remover or de=natured alcohol.
Never jam anything on a computer.
If its an add on card, remove it and reboot. Shut down and reinstall card and reboot.
keep me posted please,
Posted on Feb 22, 2009
  • Mike Davidson
    Mike Davidson Feb 23, 2009
    Now I have a bunch of question...gee thanks!
    Have you tried to do a system restore?
    Since I have no idea how much you have done, I will add a group of stuff.
    I do think a system restore will solve it but, read through this and apply those that fit.
    Since I have no idea on what all you have done, I have some questions / suggestions.
    1st: Have you Defragmented your computer? If not this month, please do so ASAP.
    2nd: How much free space is left on your hard drive? You need over 15% free space.
    3rd: Have you cleaned out you cookies, temp Files & Temp. Internet Files?
    4th: Every item you add or install anything on your computer, it starts running each time you boot up.This eats up your limited power and processor.To see this you will need to use the CRTL/ALT/DELETE keys to open up your TASK MANAGER
    On the right side you will see a TAB called START UP. Each item that is checked or ********** is running in the background.
    You do not need this stuff running. Its a gift of Microsoft to make it start faster for you and is no longer a needed item since you have so much power.
    Uncheck most if not all items, like MSN or YAHOO chat, Games and anything not directly related to the computer operation.
    And get the drivers for your sound. I am to assume its an onboard sound. You need to go to MFG's web page and their driver download.
    Thanks!
  • Mike Davidson
    Then it is still under Warrenty.
    Have them send a technician.
    Most mfg's will. If not take it back. get XP and not Vista. There are a ton of issues with the Vista OS.
    Mastersage
Model dx4300. Why does monitor indicate no signal input?
This machine has both VGA and HDMI outputs. Depending upon your monitor, you have one of the two cabled up to it. Some monitors will auto-detect which input is active, but others do not. Check the monitor and ensure that if is has dual inputs (VGA/DVI) (VGA/HDMI), that you have the correct input source selected. This is usually done from the buttons on the monitor itself.
Jan 30, 2016 | Gateway DX Computers & Internet
How to switch from analog to digital mode
Any contemporary monitor is able to switch analog/digital mode automatically if connection from signal source to monitor is set up properly.
Connect digital output from your graphic card to DVI input of the monitor. Disconnect any other signal cables from monitor and switch on both devices (PC & monitor). Wait a while. Monitor checks its inputs and a activates digital DVI, because it is only one active input on it.
If none picture excluding error message of monitor is displayed, go through these steps:
1) Check whether your monitor is set for automatic input selection. If monitor buttons have no response try to use analog input to activate screen (any picture, desktop background...) and then get monitor menu access by pressing menu button.
2) Find out what connector type has your graphics card in PC. Possibilities are: DVI, HDMI, DisplayPort and some their options. See Wikipedia for connector look if you are not sure.
Remember that blue D-SUB (VGA) connectors are analogue and you cannot activate digital mode through analog VGA cable.
3) Use appropriate cable to connect monitor to PC.
Example: Your PC has HDMI output. Use HDMi-to-DVI cable. Your monitor input is DVI and common DVI-DVI cable is not suitable in case you have PC with the HDMI.
Note that DVI-to-DVI, DisplayPort-to-DVI etc. cables are available. You must buy right one.
Be aware that "Auto" button is inactive in digital mode of monitor.
Nov 18, 2013 | Belinea 1930 S1 Monitor
My acer monitor H243H says No Signal after I unplugged the DVI cable and plugged it back in. I can't switch the input because nothing happens when I push the input button on the bottom of the monitor. It...
Maybe your BIOS switched to VGA output, try plugging in another monitor which has VGA input and change settings in BIOS for default output to DVI.
Nov 05, 2013 | Acer H243H Monitor
I have a HP LP20265 monitor, and it seems have problem, with signal detection.
well why not test it on another system
DT or LT
desk top or laptop.
why connect 2 data cables at once, this is SO wrong.
only 1 at a time.
Mar 09, 2017 | HP LP2065 Monitor
wow ,, why not test the monitor on any other PC or laptop.
see if its good or bad.?
this is the only way to find this, unless guessing works.
i got lost in your post.
try 2 machines
the post photos of what screen does bad, words never work for telling graphics./
Mar 08, 2017 | HP LP2065 Monitor
I loaded Windows 7 and now when I turn on the computer, the monitor says DVI input no input signal and goes to sleep. Can you help?
Do you have the correct driver loaded? Are you using DVI output on the computer? Is there a VGA output? If so, try using a VGA cable while you troubleshoot the video issue.
May 11, 2011 | HP w2207 Monitor
I run a PC with the newest sandy bridge hardware and a Msi GTx 560 Twin Frozr II video card (dual Dvi-I input and a mini-hdmi input). I also have a BenQ G2222 monitor (one VGA input and one DVI-D input),...
The problem might be with your ram. Try taking it out and putting it back in. You might also have a problem with the video card. Make sure it is secure and screwed in.
Mar 19, 2011 | Computers & Internet
My DVI has no signal but my VGA does! what do i do? Please help me!!!
Your HP2009M monitor supports (3) methods of accepting signals from a computer. They are: 1) VGA, 2) DVI and, 3) HDMI.
You would connect the computer to the monitor using one connection only. Generally the VGA is the least desirable as it is an analog signal. The DVI and HDMI method provide digital paths into the monitor and often perform better. Your computer may only offer 1 or 2 connection choices, so you'll have to choose a cable type that is supported by both the computer and the monitor. The HDMI choice will pass audio signals to the the speakers in the monitor without needing to run a second cable between the stereo audio jack of the computer and the audio input jack of the monitor (located next to the HDMI jack) or to a set of external speakers (unless of course you prefer the external speakers).
The message you're seeing is normal. Once the monitor is connected to your computer, there will only be one active selection; VGA, DVI or HDMI. Since you're using the analog VGA jacks and cable, it is expected that you'll see a message that there is no signal present on the DVI (and HDMI) inputs when attempting to view signals on other inputs.
I hope this helps and good luck! Please rate my reply, thank you.
Feb 26, 2011 | HP 2009M Monitor
DVI-D cable not working with Westinghouse L1975NW...
If the monitor has two video inputs - a DVI-D and a DSub VGA then the monitor needs to be switched to the DVI-D video input.
Jan 26, 2010 | Westinghouse L1975NW Monitor
No DVi input, then computer goes to sleep
I have a new HP pavilion slimline with Vista......a 19 inch flatscreen monitor......I went nuts with it not connecting and saying no DVI input......
I tried something and so far it has worked 10 times in a row...
start out with puter and monitor off.......turn on monitor.......let it go to sleep....then turn on puter....
I have the puter that has the start button on top of it.....not too crazy about it.....
hope this works for you.........Judy in NY
Dec 07, 2008 | HP 22" Widescreen Flat Panel TFT LCD HD...
HP dx2300 Monitor Personal computer Intel Core 2 Duo Processor E2160, 1 GB RAM, 80 GB Hard Drive, ... PC Desktop Logo
2,659 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
