Question about Maytag MGC5536 Gas Cooktop
Maytag sealed gas cooktop: electronic ignition starts a fire
Cleaned cooktop with soap and water and a few minutes later we noticed an electrical burining smell form the stove. turned on knob front left and a small fire ignited under left rear burner knob. Unplugged electical and tried to manually light burner on right side with a match and it works fine. The area below the knob on the left looks charred and we are very leary about trying to light it again.
Model number MGC5536. Can you recommend a way to open unit and inspect electronic ignition?
Beth dlP
bdelapena@planb-solutions.com
3 Suggested Answers
  • 161 Answers
SOURCE: (2) front Burner igniters on my new Matag 30" Cooktop continue to click
Sounds like water got into one of the switches. This usually happens when you wash the knobs. Water stays in the holes and runs down the shaft when replaced. Maytag has issued a recall on some stoves because this can be a fire hazard. UNPLUG THE COOKTOP UNTIL THIS IS FIXED!!!!!!!!! This has happened to me with a whirlpool unit and it tripped a breaker and shot sparks across the kitchen. First go to Maytags web site and see if yours has a recall. If so Maytag will fix it free. While you are waiting leave stove unplugged and light with a match. If you need to fix this yourself disconnect the wires from the two switches this should stop the sparking. Connect one switch at a time and see which switch is bad. Most of the time the electric part of the gas valve can be replaced seperately. and you can do this yourself. If you must actually disconnect a gas pipe unless you really know what you are doing call for service.
Posted on Jul 01, 2008
  • 52 Answers
SOURCE: I cleaned the gas top and the two left side burners do not ignite
Take the burners out, then take a needle and stick in the small hole where the gas comes thru.
Posted on Jul 15, 2009
SOURCE: Elect Ign not sparking, but get gas, other appliance working.
3 of my electonic ign. burners lite fine but the other won't without a match, been like this since I brought it home from the store
Posted on Jul 04, 2010
Sparker turned on by itself and would not stop
Hi rlimaye1,
The ignition switches probably got wet.
Please follow my below Tip on how to fix it:
GAS STOVE CLICKING PROBLEM...
Kind Regards
JEDEMEYER1
* If this solution helped you, please accept it
Sep 11, 2011 | Maytag MGC5430BDS Gas Cooktop
All six of the ignitors on my vgsu161bss cooktop are not firing--- electrical supply is working
Hi There are a few things to check for: First make sure the electrode (the small metal piece that the spark comes ...or The water that you spilled onto the cooktop has shorted out the ignition switch in the gas control knob. Don't worry .
Aug 16, 2011 | Viking 37 in. VGSU161 Gas Cooktop
Burner shuts itself off after 10 0r s minutes of working normally
this unit has a gas coil controling the valve . and wen it gets hot it is failing and cannot keep the gas on . replace the valve coil // mm
Jul 12, 2010 | Thermador PC366BS Stainless Steel Gas...
Gas hob ignition firing, won't stop
not a solution I'm afraid - I'm having the same problem. How did you manage to fix it?
May 11, 2010 | Baumatic 27 in. B67 Gas Cooktop
Gas cooktop starter continues firing
Turn your gas valve on, but leave your unit unplugged for a few days. You can light your burners in the meantime with a lighter so you can cook. Usually this problem is caused by moisture getting into one of your ignitor switches which are under your burner knobs. Most of the time the switch dries out and you can plug your unit back in after a few days. If it still keeps firing then you will have to replace one or more of your ignitor switches. Usually a very difficult job as most gas cooktops are now sealed burner units which means the top of your cooktop is bolted down to the burners with several screws or nuts that heat up with usage and become almost impossible to remove, without having to drill out the screws, or chiseling off the nuts. Be careful of boilovers or cleaning around the knobs with too much water to prevent this from happening again. Also get a surge protector at least 2000 joules or higher to prevent damage to you spark module. Good Luck, Appliance Specialists
Dec 16, 2009 | GE 30 in. JGP336 Gas Cooktop
Electric starters keep firing after I sprayed cleaner
your spark modual got shorted with the liquid you sprayed in there or spilled you can try unplugging it overnight to let it dry. at least 24 hours or you can take the cooktop of and get a hairdryer and dry out the spark modual.or if you wait 24 hours - 3 days and still not dried out you need to replace your spark modual but more than likley give it time it will fix itself.
Apr 23, 2009 | Amana AKS3040 Gas Cooktop
Kitchenaid gas ccoktop electronic ignition continues to click
We called in an appliance repair technician. He said during the cleaning process of the cooktop, when the control knobs had been removed to thoroughly clean the cooktop, some cleaning fluid or water or moisture got into the ignition switch panel under the cooktop. Letting it dry for 24 hours should fix the problem and this appears to have done that.
Feb 17, 2009 | Cooktops
May 15, 2008 | Maytag 30" Built-In Gas Cooktop - White
Electronic ignition
Most likely you got water (or some other liquid) into the control knobs. Unplug, go to bed and try it again in the morning. If you continue to futz with it, you run the chance of burning out the electronics in the control knob, like I did. :(
Oct 22, 2007 | Miele 35 in. KM326G Gas Cooktop
Ticking Sound of spark igniter persists
Our GE cook-top burner igniter has started ticking even when the oven is shut off. Even after cleaning the bottom of controls the ticking persists. Any suggestions? Thanks
Aug 27, 2007 | GE 36 in. JGP628 Gas Cooktop
Maytag MGC5536 Gas Cooktop Logo
310 people viewed this question
Top Maytag Cooktops Experts
deriuduo
Level 1 Expert
Gere knutson
Stan Ford
Are you a Maytag Cooktop Expert? Answer questions, earn points and help others
