Question about HP OfficeJet 6110 All-In-One InkJet Printer
HP L7680 scanning problems on MAC
Scanner doesn't ask for next page when scanning from glass. Seems to be converting certain text to indistinguishable letters. Isn't scanning to size. Do I need to uninstall and reinstall. everything else seems to work fine
    Problem Solver:
  • 4 Answers
I think that there is a problem with your driver, uninstall and reinstall your drivers. should work.
Posted on Mar 02, 2009
I am trying to scan a multiple page document into a single pdf document on my HP C7280 but it scans each page to individual images. Any suggestions?
In Adobe Acrobat:-
From 'File' select 'Create PDF', 'from Scanner'.
Scan the first page and the program will ask of you for 'Next' or 'Done'.
Select 'Next' until you have scanned the last page, then select 'Done'.
You can also make the document searchable by carrying out an OCR on it under 'Documents', 'Recognise text under OCR', 'Start'.
Jul 06, 2011 | HP Photosmart C7280 Laser Printer
I can not copy from glass scanner of HP L 7680 all in one, when I load paper into the lid then press copy, printer just load paper in ADF not run copy from glass scanner
Is your system on? If it is on, then you press copy, it scans it and a window showing your scanned document is displayed. Then from here (the system) you can print it. Try it and tell me what happens.
Dec 08, 2010 | HP Officejet Pro L7680 All-In-One Printer
HOW DO I SCAN PICTURES TO MY MAC OSX
Load the item to scan You can scan from the scanner glass or from the ADF (Automatic Document Feeder) tray, if your product has one. Make sure that the product is connected to the computer. Turn the product on. Load the picture or document: Scanner glass : Place the item with the print side down on the scanner glass, and then position it according to the engraved guides around the glass (usually on the right-front corner or the left-front corner). Close the scanner lid. ADF : Place the item into the document feeder tray. The printed side faces up and the top edge goes into the tray first. Adjust the width guides to fit the item. CAUTION:Do not load photos in the ADF. Use the scanner glass instead to prevent damage to photos. Use HP Scan to start a scan Use HP Scan to scan items and edit them to adjust resolution or color, crop, remove red eye, etc. To scan a picture or document, follow these steps: Open the HP Scan program in the Hewlett-Packard folder. From the Scan Profiles screen, click either Pictures ( ) or Documents ( ) . Click Profile Settings , and then adjust any settings in the Capture , Adjust , and Page Options (for documents) or Enhance (for pictures) tabs as appropriate. If you want to save these settings as a custom scan profile to use in the future, follow these steps: Click the drop-down list to the left of Profile Settings , and then click Duplicate Selected Profile . Type a name for the profile in the text box under the profile icon. The new profile saves under Custom Profiles. Click Scan . Make any desired changes to the scan preview by using the icons available in the toolbar and the Adjust window. NOTE: You can use + and ? buttons in the Bottom bar to add or delete pages in the OUTPUT list. You can reorder pages by dragging them to new positions in the Sidebar. Select a destination from the Toolbar: If you opened HP Scan from other software, and want to send the scan to that software, click Return . If you are ready to save, print, or send the scan to a specific destination, click Save , Print , or Send . NOTE: If you are saving the file, make sure to select the file format that you want.
Jul 16, 2010 | HP Officejet 4315 All-in-One Printer
How to scan a document in pdf format from hp psc 1315
  1. Position the first page of your document on the flatbed scanner and close the lid.
  2. Step 2 In Adobe Acrobat, under the File menu, choose "Create PDF", then "From Scanner" and then "Custom Scan."
  3. Step 3 In the Scan dialog box, choose your configuration settings. This will vary based on the nature of the document you wish to scan (e.g. color or black & white, images or text).
  4. Step 4 Click "Scan."
  5. Step 5 When the scanning process is complete, Acrobat will ask you if you wish to scan more pages into the file. If you do, position the next page on the flatbed scanner and click "Scan More Pages." Otherwise, click "Scan Is Complete."
  6. Step 6 Repeat the above steps as necessary to scan a multi-page document.
May 30, 2010 | HP PSC 1315 All-in-One Printer
Scanner not scanning
PSC 1401 will print but it will not scan
Jun 30, 2009 | HP PSC 1401 All-In-One Printer
L7680 all in one W/big & wide dark vertical line
Open the document feeder and clean the scanner glass.
Feb 16, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Scanning docs & size of pdf files on Mac w/HP l7680 All-in-one
The scanner produces a "picture" of the document, much as if you laid it flat on a table and took a picture of it with your digital camera. If you did this, your .jpg from the camera would be several hundred K at a minimum - comparable to the file size off the scanner. That's why the file is so big, it contains a picture and not text data - even though it's still a .jpg file.
If you reduce the scan resolution you will save space, but at the expense of legibility of the document image. To get it down to the smallest possible size, you will need to run the scanned image through OCR ( Optical Character Recognition ) into a Word document for example, and then print it out to a .pdf file. If you have a clean source document with few graphics this isn't as difficult as it may seem. Microsoft Office has an excellent OCR process known as Document Imaging. You need to carefully proof read the result but with a clean input Document Imaging is amazingly accurate in Office 2007.
In short, there is no easy solution to your problem.
Dec 30, 2008 | HP Officejet Pro L7680 All-In-One Printer
When scanning, the scanned page is not readable from a third of the page down to two thirds of the page.
It is important that the item you scan comes in close contact with the scanner glass. If the resulting scanned image is not clear, check to see that the item is in full contact with the scanner glass. The scanner uses optical character recognition (OCR) to convert text on a page to text that you can edit on your computer.
  • If you scan text but cannot edit it, make sure that you make the following selections during scanning:
  • Scanned text might not appear on your computer exactly as it appeared on the original, especially if the original contains faint or smudged text. For example, some characters might be incorrect or missing. As you edit the text, compare the scanned text against the original, and then make corrections as necessary.
  • To change text scanning options, click the Scan Document Settings button in the initial What are you scanning? screen.
  • The OCR software is installed by default when you install the HP Scanning software during scanner setup. If you use the Custom option when installing the software, you can choose not to install the OCR software. Try reinstalling the software using the default install options.
  • Email to jdiaz@coretec.us
  • If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
Nov 07, 2008 | HP Office Equipment & Supplies
Yellow line showing on in scanned pages
if you can open the cover of the scanner just clean the glass and use any lubricant to apply on head rod to move smoother .
bye
Nov 14, 2007 | HP 9200C Digital Sender
HP OfficeJet 6110 All-In-One InkJet Printer Logo
183 people viewed this question
Seeker5211
Seeker5211
