Where is the hard drive located in sony vaio vgn-nr430e/s
I can't find out where the hard drive is located on this machine. Anyone know?
  • 1 more comment
  • Anrev Feb 22, 2009
    This is the sony vaio vgn-nr430e/s
    there is only one panel on the back and it has the memory in it....no other panels that i can tell.....
  • Anrev Feb 23, 2009
    Hi thanks for all the replies!
    There is no sign of a hardrive anywhere...I checked under the keybourd...I am assuming I will have to take the whole machine apart to find it.....silly:(
  • John Miller Jr May 11, 2010
    Laptop, make and model please...
You Do have to take the machine apart I have the same computer and there are about 15 or so screws on bottem and be gentle when taking apart the hard drive will be in the inside to the left you have to unscrew a little sound bourd at verry end of hard drive to be able to slide it out and on the other end there are two more screws holding it in as well Good luck.
Posted on Aug 28, 2010
  • 3 Answers
You have to remove the base part of the laptop by removing all the screws including the little ones under the cd when the dvdrw is removed. and the ones under battery and there is one under the ram cover then the base comes off easily. just then remove the caddy locking screws one at the front and one and back
bingo bongo.
greg
Posted on Nov 11, 2009
  • 115 Answers
Http://office.manualsonline.com/manuals/mfg/sony/sony_vaio_notebook.html
check this sony vaio manual
you will able to figure out where is harddrive located
Posted on Feb 22, 2009
  • 4,806 Answers
Hi there
Underneath the laptop you will find some panels with screws in them, 1 is for the memory, 1 is for the hard drive and so on, the laptop HDD will look similar to this >>>>> Where is the hard drive located in sony vaio vgn-n - b1923bb.jpeg.
They are pretty easy to replace once you are familiar with them.
Good luck and thanks for using Fixya!!
  • Lee Hodgson
    Lee Hodgson Feb 22, 2009
    If its not underneath the laptop, have a look at the front and sides for hidden panels with screws, it will no doubt be hidden at the side, if you still can't find the hard drive it may be underneath the keyboard
    Good luck
  • Lee Hodgson
    Lee Hodgson Feb 23, 2009
    hi there
    its underneath the keyboard, under the metal grill, like this >> locate and remove the screws that holds the metal plate in place, then you should be left with something like this>>>> be careful when you have removed the screws because the sata cable is very fragile.
    Good luck
Hi, own a Sony Vaio VGN P530H with hardisk Toshiba MK6028GAL damaged. as forced to replace unit, wonder could install a higher capacity? Brand & model if available please!!! thanks to all of you!!!
The VAIO VGN-T350 is a notebook computer designed and distributed by Sony.
The hard drive on your Sony VAIO VGN-T350, which is the unit that stores data, consists of many clusters of data that can be rewritten with new data.
If you are looking for a memory capacity upgrade, or if your old hard drive is having errors, it's time for an upgrade.
Upgrading the hard drive on your Sony VAIO will require the use of a screwdriver and will take you about 30 minutes to complete.
Turn off your Sony VAIO VGN-T350 and remove the power cord and any other peripheral components.
Turn over your Sony VAIO VGN-T350 and locate the hard drive chamber on the bottom of your laptop. It will be clearly labeled.
Use the screwdriver to remove the screw holding the lid in place.
Gently lift the hard drive and its cage away from your laptop and disconnect the data cord.
Remove the four screws located at the corners, and then remove your old hard drive from its cage.
Place your new internal laptop hard drive into the cage and replace the screws.
Connect the data cord to your new hard drive and place your new hard drive into its chamber.
Close the lid and replace the screw to complete the operation.
http://www.fonerbooks.com/laptop_1.htm
http://www.youtube.com/watch?v=rg_GvaMunas
Sony Vaio Hard Drive Replacement
This might not be your specific laptop it might give you an insight into the hard drive installation.
Ebay this hard drive should fit there are smaller capacity drives that will be compatible.
http://www.ebay.com.au/itm/New-500GB-Sata-Hard-Disk-Hdd-for-Sony-VAIO-PCG-3H2L-VGN-P530H-VGN-SR410J-B-/190882270487?pt=US_Internal_Hard_Disk_Drives&hash=item2c71784d17
500GB Sata Hard Disk Hdd for Sony VAIO PCG-3H2L VGN-P530H VGN-SR410J/B
Aug 14, 2013 | Computers & Internet
Viao vgn-nr430e/p just died
remove battery and retry with only ac power connected ..if that works then the battery is bad...if that doesnt work then it could many other things like bios battery, power connector, mobo...
Apr 15, 2013 | SONY VAIO NR Series VGN-NR430E/P NoteBook...
My sony vaio model is vgn nr32s.didnt work av mode.i install win vista.what cn i do right now
The VAIO Launcher Software is responsible for the proper functioning of the AV Mode buttons. Please download and install the same in the computer from the below link:
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNNR410E&upd_id=3595&os_id=28
Thanks
Jan 07, 2011 | Sony VAIO VGN-NR430E/S NoteBook
How is the display replaced on a Sony VAIO series lap top
You can watch this video on how to replace it, replacement LCD you may be able to find on Ebay
Dec 29, 2010 | Sony VAIO VGN-NR430E/S NoteBook
I have a sony vaio vgn nr430e laptop the display goes off as soon as the cpu fan starts rotating
That could be a problem with the heatsink/fan assembly on the processor. It sounds like the processor is starting up, getting warm as they do, the fan starts up but does not cool efficiently enough and forces a shut down due to heat.
Clean out the fan assembly and replace the old heatsink compound on the processor heat sink.
Hope that helps.
Dec 09, 2010 | Sony VAIO VGN-NR430E/S NoteBook
VGN-NR430E the fan doesn't seem to be working does it come on at power on
i have the same problem pulled it apart a few times and it started to work againg am still watching it to see what will happen planning to buy a cooling mat.
Jul 14, 2010 | Sony VAIO VGN-NR430E/S NoteBook
How to remove hard drive on a sony nr series laptop
In the below link, you can get the detailed illustration of removing your sony laptops harddisk...Please choose appropriate model from the below link and see the illustration with diagran
http://repair4laptop.org/disassembly_sony.html
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Aug 06, 2009 | Sony VAIO VGN-NR430E/S NoteBook
Computers & Internet Logo
2,571 people viewed this question
David Payne
David Payne
