Question about Foxconn 945GZ7MC-RS2H Motherboard
Motherboard dos'nt start
Hi i purchest a motherboard bondel i have connected every thing tryed every thing the only thing i have to work is the cpu fan that is all
Hi thank you the problem is not on the ps because the greatest on i have put in the processor fan works the hard drive on the cd onbut no motherboard sound
Posted on Feb 28, 2009
  • 530 Answers
Hi im josh in cebu phils. may i help you. if your motherboard wont start. try to check the power supply you are using be sure it can supports enough current to your motherbard especially if there are many devices attached such as dvd/cd rom.vdeo cards etc. try to use power supply having an output of 500W or work your motherboard.then check all connections if mounter properly. good luck hope i helped for me so that ill know.
Posted on Feb 23, 2009
I installed the motherboard with the cpu 3500+
There could be many things that could stop the board from turning on, Determining what is wrong is like detective work. What I do, is take everything off the board to start. Then add the minimum to start a board to see if it will start. That's one drive (cd or otherwise) the CPU, and one bank of memory. (that's not a required eliminate, but it helps avoid beep codes) Also, make sure you have your pin's set on the board absolutely correct, or that could be your problem to begin with. Also, if your going to load a ide drive, make sure you set your pin setting correctly on it. Now, you should get the power supply on, and the cpu. If those don't power up, it's then either one of the five elements. The CPU, Power supply, Ram, Drive, or the motherboard. The next step is to replace each one of the first four with another to see if you get any change. Also, on the drive, try a different cable to make sure it's not that, If no change, then I usually get another board that I can test the first four, and make sure that they work. If after that and you have tested all of the components and they all work, then it's save to say you have a Dead Board
Good Luck and don't forget to leave a rating.
Dec 12, 2009 | MSI K9VGM-V Motherboard
P4X400dap 478 vt8235.
this sounds like a bios problem, faulty/corrupt.
try removing the cmos battery for 10 seconds, replace then re-boot.
If this does,nt work suspect faulty Power-Supply-Unit. Motherboard. Ram Or CPU.
Mike @ Compurepair.
Jun 15, 2009 | Jetway Computers & Internet
Windows problem
Try this.
Right Click on your DOS program EXE file. Then go to properties and go to Compatibilty TAB. Click in Check Box for Compatibitlity mode and select WINDOWS 95.
Feb 10, 2009 | Computers & Internet
When i am trying to use c++ on my system it is giving me message the NTVDM cpu has encountered an illegal operation
Here is an explanation of what NTVDM is: The NT Virtual DOS Machine (a.k.a WOW, or Windows on Windows), is a Win16 subsystem that runs under Windows NT, which allows 16-bit applications to run as if they were being executed on a DOS machine, with that machine's multitasking and segmented memory model. Because the system is multitasked 16-bit DOS and Windows applications cannot crash NT. However, 16-bit apps within a Win16 subsystem run the exact same way as they do on a DOS/Win 3.x machine; therefore, 16-bit apps within the subsystem can crash one another, or the subsystem. To prevent this, you can launch multiple WOW subsystems as long as your program does not communicate using shared memory. Windows NT will not allow NTVDM to execute instructions that try to directly manipulate hardware or memory locations. As a result, some DOS and Windows 3.x applications (such as games) may not run under Windows NT.
Feb 02, 2009 | Computers & Internet
Dead new motherboard
Are you using a 24 pin or 20 pin power supply? Can you confirm the power supply you are using does indeed work?
Mar 06, 2008 | Asrock ALiveNF6G-VSTA (MB-ALVNF6G)...
Only fans are starting - nothing else
Have you checked the CMOS/BIOS Battery? How about reseting the BIOS jumpers?
Test the system using Motherboard with processor and 1 RAM, just connect power and screen only, switch it on. It it fails try another memory... Whether the memory, board of processor is the problem.
Fixya me when done....
Post me back if it doesn't work...
Feb 08, 2008 | Gigabyte GA-965QM-DS2 (rev. 2.0)...
Machine hangs in between
hangs in between what? Try checking to see what is starting up. (If you can get it up) goto: start -> run type in: msconfig goto the last tab (start up) and uncheck anything that you don't use often (which most of the time is 99% of what is listed in there) Otherwise you might just have to reinstall Windows (repair) Here's a link to a site which gives multiple examples of repairing a install:
Feb 17, 2007 | Intel D850GB (D850GBC) Motherboard
Foxconn 945GZ7MC-RS2H Motherboard Logo
83 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
