Question about GE 25.0 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Black-on-Black
Ice door will not close tight
GE refrigerators side by side model # gss22qgmd , after the ice comes down the round door will not close tight will stay open about 1/2 inch
    Scholar:
  • 59 Answers
You will need the part linked below. Its a solenoid they rust from moisture that forms on them.
Solenoid.
Posted on May 21, 2010
  • 478 Answers
You will need to re place the soliniod that closes door flap
Posted on Mar 12, 2009
Icing up where ice cubes drop from door
door to ice shute not closing tight replace with door kit . for your model the newer model uses a better seal and a stronger spring . .. mm
Aug 11, 2010 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
Refrigerator door
ice door won't close ge #pss26msrbss
Dec 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
PSS23MSTC GE PROFILE WATER WORKS, ICE CRUSHED ICE INDICATOR LIGHT DIMS NO ICE IDEAS?
clean built up ice in the door where ice comes out.....make sure the metal bar is down. its located inside the tray where the stored ice is.
Nov 06, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
PCG23N ice cube dispenser area problem
This is probably due to the door flap in the ice chute not closing tightly. There is a solenoid that operates the door that could have stopped working. Can you hear it? The hinge on the door could be broken or the bracket it goes in could be broken. You'll have to look to see what's wrong.
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
Aug 21, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE ice dispenser door hangs down
You should replace the dispensor solenoid and plunger due to rust . Very common problem with G.E.
Jul 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice cube flap door
try this site...input your model # and look for the ice door parts. Maybe a bad spring. They are also very helpful with their chat and phone assist., video repair etc. Make sure to get the model # though.
https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Refrigerator/62-5-1414685-/Whirlpool-Refrigerator-ice-maker-overflowing-WRX735SDBM00?r=%2fShop-For-Parts%2fa4b5c21i2659d1414685%2fModel-WRX735SDBM00-Whirlpool-Refrigerator-Gasket-Seal-Door-Gasket-Parts
Best to you.
Oct 22, 2017 | GE Refrigerators
Ice machine flap doesn't close all the way,then stays closed
There is a ice door solenoid for your dispenser, its probably the problem. Costs about 35 dollars and just about anyone can replace it.
May 29, 2009 | GE GSS25JFM Side by Side Refrigerator
Ice dispenser flap/door will not close properly
I have a similar problem. The repair guy took a look at it and stated everything is working and did not order any solenoid or any other parts. After he left the problem returned where ice comes down the chute it tends to lodge and keep the door open. I am disagreement with the repair guy and am leaning toward the idea that the spring has lost tension and is just too weak to close with any authority. There is a video on how to replace the spring on youtube. This is what I will be doing next weekend and will try to return to post results.
Jun 10, 2008 | GE Monogram® ZISS420DMSS Side by Side...
GE Side by Side Model GSS22JERFWW
front of the unit with the door closed, what ever makes the ice come out the dispenser.
Feb 17, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE 25.0 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Black-on-Black Logo
145 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
