Question about KitchenAid KWCU205HSS Kitchen Hood
Hood fan works but displays the letter "C" ?
And how do I clear it ?
  • nanima May 20, 2009
    I have the same problem. Am looking for solution
Wow! finally the solution that works! Holding the '+' sign for 4 seconds. We had our vent replaced by kitchenaid once and were about to call again and complain since our new one did just the same thing without resolution using the 'H' button as indicated in the manual! Thanks for help it's so appreciated!
Posted on Jun 12, 2009
Reset Filter Alert
After 100 hours of use, “C” will appear in the range hood display.
This “C” indicates that the filter must be cleaned. “C” will appear
only when turning off the range hood fan.
Reset Alarm Display
1.
Turn off the range hood fan and light.
2. Press the “plus” (+) button for 4 seconds. The “C” will
disappear from the display, and the counter will reset to “0.”
Posted on May 29, 2009
Pressing the plus sign + did take the C off.
Thanks
Your supposed to hold the "H" button down for 4 seconds and the filter hours clock is supposed to reset itself to 0 and remove the "C" display. But, I have the same issue and holding the "H" button for 4 seconds doesn't take the "C" away. I'm going to place a call to Kitchenaid and see if they have any suggestions. We even tried resetting it by turning off the power, still shows a "C"! Disappointing!! Hope this helps you.
Posted on Mar 20, 2009
I have a GE space saver microwave, JVM1653SH02, stopped working.
Sorry but at the price of repairs I would pitch .
Jan 19, 2015 | GE Kitchen Ranges
WhatdoesPFstandforondiplay
PF is power failure. usually touchin a pad will clear this. if it is popping up and you havent had a power outage,. there may be a bad connection in your power line to the stove or a bad connection on the control itself.
Oct 05, 2014 | Kitchen Ranges
Whirlpool accubake
follow this steps with VOM and fix it. God bless you
1. No power to the range hood
Make sure there's power getting to the range hood. Check for a tripped circuit breaker or a blown fuse. Check the wall socket (unless the hood is hard wired) for power with a voltmeter or by plugging something else in.
2. Fan switch
If your range hood only has a fan and no light or any other features, it won't start with a broken fan switch. Replace the switch if found defective.
3. Fan motor
If your range hood only has a fan and no light or any other features, it won't start with a broken fan motor. Replace the motor if found defective.
Read more: http://www.appliancepartspros.com/repair-help/rangehood-repair-help.html#ixzz2aSy5FKwN
Jul 29, 2013 | Kitchen Ranges
The fan in my has not stopped working in a few weeks now.what can I do to make it stop blowing air
test this steps and fix it. God bless you
2. Fan switch
3. Fan motor
Oven will not work.
This is what GE recommends for your oven:
“F—and a number or On models with a door latch, • The latch may have been moved, even if only slightly,
letter” flash in the display if a function error code appears from the locked position. Make sure the latch is moved
during the self-cleaning cycle, to the right as far as it will go.
check the oven door latch.
You have a function error code. • Touch the Clear/Off pad. Allow the oven to cool for
one hour. Put the oven back into operation.
If the function code repeats. • Disconnect all power to the range for 5 minutes
and then reconnect power. If the function error
code repeats, call for service.
May 18, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
Whirlpool Gold electric range.
Hello delmonico
Welcome to Fixya,
You said, when turning on the self clean option, after 1 minute, I get E 1 F5 on the display panel. What do I do?
Try this .
Turning off the power to the range at the breaker for 5 minutes and see if this will reset the system.
Display shows messages
Is the display showing a letter followed by a number?
Depending on your model, press OFF/CANCEL or CANCEL/
OFF to clear the display. See “Control Display” in the
“Electronic Oven Controls” section. If it reappears, call for
service.
Let me know how it goes.
Thank You,Huuum
Please remember to enter a rating!
Oct 02, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
LG Range #LRE30451SW
This happened to me on Christmas Day morning & it happened once before. I finally remembered how I fixed it. Push the "Clear" button & then push the "Start" & keep it held in until you see the lock button light up (takes awhile - be patient) & then push the "Clear" button again. After I did this the "Clock" worked again - reset the clock to the correct time & push "Start" Then click on "Bake" set your temperature & push "Start". Hope this works for you. It got me out of cooking Christmas Dinner!!!
Aug 28, 2008 | LG LRE30451ST Electric Kitchen Range
Jenn Air Range SVD48600W (Circa 1998?)
ja_question.gif Why are the oven indicator lights flashing? Answer: When power is first supplied to the appliance, a flashing time will appear on the display.
If a flashing time appears at any other time, a power failure has occurred. Press Cancel, and reset the clock if needed.
When the oven is not in use, the display shows the time of day.
If the indicator lights keep flashing after you have tried to reset the controls, then you may need to contact service person.
This is from the Jenn-Air website.
Mar 17, 2008 | Jenn-Air SVE47100 Slide-In Electric...
"FC" display
It has detected the door lock motor didn't respond. Check wiring to the motor. If wiring is ok then replace the door lock motor.
Nov 09, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
KitchenAid KWCU205HSS Kitchen Hood Logo
1,748 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
