Question about Insignia Digital-to-Analog Converter for Analog TVs
When I hooked the DTA800 to my RV atenna
I didn't get any signal. The system was working fine before I connected the converter. My understanding, I should be able to receive digital and analog if available with the box installed.
  • Anonymous Feb 26, 2009
    After carefully hooking up the DTA800, the screen tells me there is "no signal".  It's a roof top anntena and works very well without the converter box.
    thanks for your help here
    jim
My understanding is that the Digital signal is weaker than the analog, so need a stronger antenna to pick up the digital signal, and MAY still not get any reception at all. Have you considered satellite for you RV? Won't need the converter at all then.
Posted on Feb 22, 2009
What is the codes for a sanyo tv that will connect to a rca/dta800 converter box. I have lost my manual and need to the codes for a Sanyo television.
not for sure but try 007, i have a different brand converter box hooked to a sanyo tv and it's code is 007, i will try and find out more if i do i will post it
Nov 19, 2009 | Insignia Digital-to-Analog Converter for...
RCA DTA800 TV Converter Box I need TV codes for the remote to work. The TVs are a GE, phillips magnabox
Good day,
I might be missing something, but you are describing a converter box that converts digital signals from an antenna to analog.
The converter box will be set to channel 3, and you should set your tv's to channel 3 as well.
Using the remotes that came with the tv's go into setup and if available as an option, you will find an option to select cable/antenna or automatic. Select automatic or antenna and save. If there is a selector switch on the back of the tv's, set to 3.
Connect antenna cable into input, and use supplied cable to connect from the output of the converter to your tv.
plug in power supply for converter box, tune tv to channel 3 then follow instructions to setup converter box including channel scan.
When done, the converter remote will control everything. However, the tv volume control will work even though the converter remote will have volume as well. The tv remote as well is needed to shut off or turn on tv. These functions can on most tv's be performed on the set as well.
No codes are required. The converter remote will work on any tv.
If you want to use both tv's then you will need a splitter on the output of the converter to send the signal to both tv's. Only one channel can be viewed at a time.
Viewing separate Chanel's requires a second converter box and a splitter connected to the antenna cable for viewing separate channels.
More options are possible, but I hope this helps you get started.
The converter box takes place of the tv's tuner and in essence disables it.
Nov 05, 2009 | Tablets & eReaders
Same problem
Then I would say you have a problem with the Main Board in the 37". Have it looked at by a service company in your area if he wants to work on a Vizio. Parts are difficult to obtain at times.
Jun 08, 2009 | Vizio L37 Television
Need sanyo tv code to connect rca/dta800 converter box
sanyo 037,082.083.124.198,268.274 Press program, three number combo, ok, check volume control for function
Jan 01, 2009 | Insignia Digital-to-Analog Converter for...
I recently bought a converter box DTA800 to go with my sony tv Triniton mod.KV-20FV300. It doesn't seem to work; programing, set-up. Please advise.
Ah, the problem is likely your antenna. Make sure everything is properly hooked up, and that your TV is on and turned to either channel 3 or 4 (whichever the unit requires, or you can try both and see which works) then turn the converter on, and check the manual that came with it for a way to check for your antenna's signal strength.
If your signal is good, then use the menu button on the remote and look for an "autoscan" feature, or "autoprogramming", something along those lines, and let the unit look for channels for you (mine requires this before you can use it, not that it matters because my antenna signal is weak). From there you can access the channels manually.
Hope this helps.
Jun 26, 2008 | RCA Televison & Video
The instructions for our DTA800 digital to analog converter box for over the air waves for TV signals say since the signal is too weak that we need a SMART ANTENNA. What is that and what do you...
Hey boykinpierce,
The phrase "Smart Antenna" is often used to describe a multi-directional antenna or antenna array. These types of antennas are able to detect and automatically adjust to any changes in the TV signal strength you receive, and can generally be obtained through most major retailers. They primarily are used in areas where digital signals are weaker or somewhat inconsistent, and will attempt to optimize the signals they do receive before sending them to a TV or digital converter box.
Please keep in mind that while some DTV digital-to-analog converter boxes may have built-in Smart Antennas, this particular model (RCA DTA800) does not appear to have this feature.
If you're still not quite sure what to look for, please remember that you can always speak with a home theatre sales agent at your local Best Buy™ store for more information.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jun 19, 2008 | Televison & Video
Converter box
the digital box has to hooked up the rca plugs on the bac of the vcr if you want to use the vcr (you will only be able to pick up channels throught input and the box will have be set on the channel you want to record. You need a switch to hook the vcr and dvd player both up. the atenna cord can be attached to the back of the convertor box then attached to the tv.
Jun 15, 2008 | Insignia Digital-to-Analog Converter for...
Connecting to an RCA DTA800 digital converter?
I got the new RCA converter box I followed the on screen info but i'm not getting a signal from my antenna so it doesn't show any channels
Mar 10, 2008 | Symphonic SC3913 13 in. Combo
Insignia Digital-to-Analog Converter for Analog TVs Logo
101 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
