Question about Frigidaire FRT15G4B Top Freezer Refrigerator
To cool the compressor?? I do not have a problem, this is just a general discussion question I'm throwing out there. Every fridge I've ever owned, the compressor gets very warm/hot after running. I have a small 2cf fridge in the basement, I put a small personal fan in the back blowing right on the compressor. Now it no longer gets warm/hot, it stays right about room temp. Here's the question: Is this a good thing or a bad thing. I'm thinking that a cooler compressor will last longer than one that is not cooled. Would it hurt or help to do this with my big fridge??
  • Frigidaire Master
  • 3,361 Answers
Some compressors are designed to be externally cooled some are not.
They have to process the refrigerant to certain pressures to operate correctly.
The specific condenser and expansion device do the rest.
By cooling a compressor artificially you make it work harder to do its' job.
Cooler is not always better.
Posted on Feb 22, 2009
GE Artica PSS25NGMD Side by Side stopped cooling
Unplug the unit and pull the relay off the compressor and shake it to see if it rattles. If it does, the relay is bad and will need to be replaced. Here is that part to order.
Here is the overload relay that should be replaced also.
Is you pull the relay and it does not rattle, post back the results to me.
Here is a video to help you out.
Feb 09, 2013 | Refrigerators
Fridge isn't getting cold
If there is no cooling at all on the fridge section but the freezer works then it is confirmed that the compressor and gas pressure is OK. Now shut off the fridge and leave it powered off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge.
However if ice forms in the freezer then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked. Frost formation without defrosting could block the air flow and so shut the air passage to the fridge. Also the blower fan must work and if this is not working then the fan can be faulty. Also a fault on the control unit is a suspect to non functioning of any one of these components.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test using a multi-meter on the defrost timer and the thermostat and make your observations so that we come to the solution.
Please check the link below for tips to remove the panels/parts:
Jan 12, 2013 | Washing Machines
Whirlpool SXS.....1. compressor cooling fan quit so fridge and freezer stopped working. 2. replaced cooling fan and fridge and freezer working again. 3. Now the fridge and freezer works but runs nonst
Check to see if the sensor in the freezer compartment is encased in ice. If so, do a complete defrost and restart the unit. Another possibility is a bad thermostat and/or sensor.
Jul 25, 2012 | Whirlpool Refrigerators
I recently brought this fridge out of storage, it was working perfectly fine before i put it into storage. I plugged it in and the lights are on, i let it run for a few hours but it did not get cold or...
The cooling fans do not run unless the right temperature is reached. The important thing is to find if the compressor is running. If you do not hear a whirring sound when the fridge is powered on, then the compressor has a problem. Generally when you put in storage the refrigent can leak out and needs to be refilled.
If the compressor is running then check the thermostat settings. Might also help if you provide the make and model number of your fridge.
Oct 10, 2011 | Refrigerators
Hi, my Hotpoint ff200e fridge freezer is cooling but not freezing, compressor wires are warm and compressor itself is quite warm, top fridge is not cooling enough, then the lights on control panel start...
Hi.. feel the dividing rdge between fridge and freezer.. is it warm?.. chances are that the little fan at the back of the fridge freezer that helps cool the compressor, has snagged own it's own wire... it's a weak fan, like you get in a computer, but it does a lot of work.. without it, the coolent does not do it's job, which results in your device not cooling things properly
Apr 24, 2017 | Hotpoint HTM17BBSSA Top Freezer...
Exterior panel between freezer and refridgerator that magnetic strip sticks to is very hot.
Have seen it many times before especially on Whirlpool fridges before. It is not detrimental to the running of the fridge but has the tendency to warp the door fridge seals. In my opinion, when the fridge was piped up, instead of running the high side (hot pipe from the compressor), through the radiator first and then to the fridge body, they have done it in the opposite way. As a result, All the heat from the compressor is going firstly into the fridge frame to eventually exiting and then going to the radiator.(Thats why it is so hot between the doors). To rectify this, you need a technician to swap the pipes over at the back as already discussed, then regass..
Aug 28, 2010 | Whirlpool Refrigerators
Kenmore Elite Trio Refrigerator not cooling
No, it is not a failed condenser. You need to see if the compressor is running though. When it runs you shaould have a fan in the freezer running, a fan underneath the fridge running, and the compressor should be running. I would be willing to bet that either the compressor is bad, or the start relay on the compressor.
Sep 08, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
No Cooling in the Fridge section, freezer is icing
Generally on these models they rely on cold air being pumped fr\om the freezer to the fridge and have a adjusting device to control the flow, you need to locate and check this is free and working properly. Another reason for freezer ice up is a shortage of gas in the unit, this is usually unfixable as the leak can rarely be found as it usually occurs within the cabinet case. Sorry to say it would then be a throw away.
Jun 03, 2009 | Refrigerators
Every 2 mins the compressor tries to go on and after 15 seconds stops.
If the compressor tries to go on every two minutes, then the relay is functioning.
1. If the compressor has failed, it might be getting hot and tripping the thermal overload to shut itself down. It will cycle like you say and will be unable to cool the fridge.
2.It's also possible that you have lost refrigerant from the system. When the compressor goes on, the pressure drops below a threshold value. The system sees that there is not enough pressure, and shuts down. Once the pressure rebuilds, it tries again.
3. If the fins in the rear of the fridge are clogged with dust/debris, the system will not be efficient enough to cool. I doubt this is the case as the compressor would generally just stay on for a long time... longer than 2 minutes.
Try turning the thermostat to the coldest setting possible for both the fridge and the freezer. If the unit still cycles off after 2 minutes, consider repair.
Mar 14, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Frigidaire FRT15G4B Top Freezer Refrigerator Logo
127 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
