Question about Microsoft Internet Explorer 7
"use a proxy server for your lan (These settings will not apply..
I have had different users not be able to load webpages in Internet Explorer due to the setting "use a proxy server for your lan (These settings will not apply to dial-up or vpn connections)" being enabled under the connection tab in Tools, Internet Options.
I can have people go in and uncheck the box easy enough, but I haven't come across what causes it (it's usually occurring on a Windows Active Directory domain).
Does anyone have any advice on what causes it?
Thanks
  • 3 Answers
I assume you find this in Tools, Internet Options, Connections, LAN. This proxy server setting is only used when you are working through a network at a school or company. You need to have the checkmark next to "automatically detect settings" if you work through most broadband connections like cable or DSL.
Now, if you have the "automatic" checked and the Proxy check appears anyway, this must mean that you have some program that is trying to connect to some network or call home somehow. This could be a virus. Do you have a good AV program? Be careful because many of the websites that say they want to check your system are actually virus downloaders.
Posted on May 31, 2009
I can't get my LAN settings to automatically detect settings, box will not check.
Reset your proxy settings
Proxy servers, or proxies, act as intermediary servers between a Web browser and the Internet. According to Microsoft's website, proxies are mainly used by networks in companies to enhance the security and speed of their network connection.
Proxy servers can also be used to log Internet usage, mask the network address of a server or to apply global restrictions to a network.
Internet Explorer is set to automatically detect proxy servers by default.
You can reset the Internet Explorer proxy settings to their default settings from the "Internet Options" configuration.
I have found the easiest way to do this is to add the menu to the top of a webpage.
Create the menu tab on your homepage right click in the top toolbar you should see a number of toolbar options select the menu tab which will add File Edit View Favorites Tools and Help
Click on tools option then from the drop down list Internet Options
Select the "Connections" tab, and click the "LAN Settings" button.
Delete the proxy server address and port from the "Proxy Server" settings and clear the "Use a proxy server for your LAN" check box.
Clear the check box beside the "Automatically detect settings" and "Use automatic configuration script" options in the "Automatic Configuration" section of the "LAN Settings" dialog window. Click "OK."
Click "Apply" and then "OK" to save these changes and close the "Internet Options" dialog window.
Close all Internet Explorer browser windows for these changes to take effect.
http://windows.microsoft.com/en-US/windows-vista/Change-proxy-settings-in-Internet-Explorer
Sep 12, 2013 | Computers & Internet
An unknown error occurred (306)
http://discussions.apple.com/thread.jspa?threadID=2152912&start=90&tstart=0
Launch Internet Explorer
Click the Tools menu
Select Internet Options
Click the Connections tab
Click the LAN Settings button
Make sure that that "Use a proxy server for your LAN" checkbox is unchecked
Click OK till you are out of everything, and then close Internet Explorer
Try again in iTunes to load the store
or:
Okay, I found the solution when running CA Security Center for me. You need to open your Parental Controls - Advanced Settings. In the user/default tabs select Web Filters. The select "Custom List" under the allowed section. Then add the following sites individually: itunes.apple.com, ax.itunes.apple.com, albert.apple.com Be sure to select the checkbox to allow the entire domain. Then restart iTunes.
Mar 07, 2011 | Apple iTunes
The internet says it is connected but then it wont let me go in to any site it keeps saying internet explorer cannot display the webpage
Try this first:
In Internet Explorer
Go to Tools > Internet Options > Connections > LAN settings.
You most likely are not using a proxy server. Ensure your settings mirror the above, especially the "Use a proxy server..." setting.
Feb 23, 2011 | Acer Computers & Internet
Neither Internet Explorer or Firefox will connect to internet. Firefox say it cant connect to proxy server. How do I check proxy settings?
Open your Internet Explorer,
Go to Tools -> Internet Options -> Connections "Tab" -> LAN Settings -> Proxy server, uncheck the box -> OK
Restart your Browsers ie IE or Firefox, you don't need the proxy server if your are a home users.
Hope it helps.
Jan 29, 2011 | Microsoft Windows XP Professional
Not able to apply the proxy settings for internet explorer
Open Microsoft Internet Explorer and from the 'Tools' menu select 'Internet Options'. from the 'tools' menu.
Select the 'Connections' tab.
Select 'LAN Settings'. In the 'Proxy server' section select 'Use a proxy server for LAN ..., enter your proxy address, and enter port 8080. 'Bypass proxy server for local addresses' is selected if you are accessing network resources through a intranet. When complete, select OK twice.
NOTE:
After you apply your settings to the web browser test your Internet connection by attempting to access an external Web site such as http://www.google.com. Test more than one Web site. If you are unable to access external Internet resources, verify the spelling of your entries. If spelling is correct, contact your company's helpdesk to find out if there is a problem with the corporate proxy server.
Regards.
Jan 12, 2011 | Microsoft Computers & Internet
I've installed Explorer 8, but then it cannot display any webpage.
Which is the operating system?
Have you checked for the proxy servers?
Often times a piece of Malware will change your Proxy Settings to intercept all communications from your Computer. If you have cleaned an infection, and are still experiencing trouble loading web pages your Proxy Settings may have been changed. To check these settings do the following (Pictures taken from Windows 7, other versions have similar steps):
On the subsequent menu select "Internet Options." This will open the Internet Properties menu. (This is the same menu as the one accessed through Internet Explorer. I feel safer with this method though, as not opening IE will prevent a browser misdirect. Also note, these settings can affect all browsers)
Click on the Connections tab
Click the LAN settings Button. You can now see the Proxy Settings
Most home users will simply want to un-check the box next to "Use a proxy server..." If you connecting through a legitimate proxy you will instead need to contact your network administrator for the actual address to enter here.
Click okay
Click okay
Dec 24, 2010 | Computers & Internet
My wireless is working perfectly. But when i click on the Internet Explorer Icon to go on line it says " Internet Explorer Cannot display webpage". So I clicked on "Diagnose Connection Problems". The box...
to: Start > Control Panel > Internet Options > Connections > LAN Settings. Uncheck the "Use a proxy server for you LAN (These settings will not apply to dial-up or VPN connections). !
Sep 29, 2010 | Compaq Computers & Internet
How to fix error HTTP 403 Forbiden i can't log on bitsoup i keep getting 403 forbiden ....thanx for help
This error message means :-
403 - Forbidden - You can't access the page. You may not have access (it may require a password), or it may be blocked from your domain.
or your Internet site parent controlled site blocker.
Oct 28, 2009 | Dell Inspiron 1525 Laptop
Internet explorer browser ."..cannot display the webpage"
Please follow these steps.
1.clcik on start at the bottom left corner.
2.Go to control panel.
3.click on internet option.
4. you will seee internet options window
5. clickon connection at the top.
6.click on Lan settigns
7. now, check for the third check box--user a proxy server. If it it checked. --first uncheck the checkbox just below it which is saying, "bypass a proxy server". Now, uncheck the check box saying, user a proxy server,
Now, click on OK
click on OK again.
Now, close the internet explorer window and open it once again.
Jun 09, 2009 | Microsoft Internet Explorer 8
Microsoft Internet Explorer 7 Logo
1,407 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
